Gravity Fed Alex Staidle Mega Moderator Location: Δx = ħ/2Δp Join Date: 08/21/2009 Age: Midlife Crisis Posts: 1,719 Rally Car: Various Heaps |
For the four link upper links, mounting to the chassis....
How tall should the brackets be. Meaning, if i have the lowest hole of the mount at say 0 degrees for the sake of visualixztion, how far should the upper most hole be for maximum angle adjustment? Afco sells ready made brackets with 5 holes that are 7" tall. Thry also have 6 hole at 9". Would these work well for the upper link mounts and thus determining upper link angle or should i make something? First Rally: 2010 First RallyX: 2004 (a bunch) Driver (0), Co-Driver (7) Organizer (3), Volunteer (3) Cars Built (2.5), Engines Blown (2) Cages Built (0) # of rotations (3.5) Last Updated, Apr 9, 2023 |
The power of math suggests a 0 to 20 degree range of adjustability. Thoughts?
jrally Jon Rood Super Moderator Location: Phoenix, AZ Join Date: 10/19/2010 Age: Possibly Wise Posts: 154 Rally Car: '94 Escort GT (sold) |
Most people will likely disagree, but when I built my 4 link on the Celica, I went with the 70% length up arms to the lower arms, then 80% height on chassis pivot to axle pivot points. I then made it adjustable, 1" down, 1" up to dial in the anti squat for getting the best traction. I've never moved the upper links from the middle position, the car has amazing bite off the line, so why mess with it. Most rally car builders, OLD SCHOOL RWD, will tell you parallel equal length links. It works, but could it be better..?
-Jon |
I think he means upper link 70% length of the lower . That way it will end up tracing a different arc than the lower.. Same thing is accomplished moving the upper front link down.. I guess. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
I wouldn't have thought that would work very well as a 4 link, since it would bind up once you tried to articulate the axle. And if the axle isn't articulating, then you're driving too slowly to care about what the suspension can or can't do.
Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. Edited 1 time(s). Last edit at 11/22/2014 02:10PM by Pete. |
tdrrally edward mucklow Senior Moderator Location: charleston,wv Join Date: 05/31/2011 Age: Possibly Wise Posts: 763 Rally Car: ford mustang LX 5.0, 1973 VW Beetle |
this may help
http://www.how-to-build-hotrods.com/parallel-4-link.html http://www.how-to-build-hotrods.com/triangulated-4-link.html I would rather drive a slow car fast as a fast car slow! first rule of cars: get what makes you happy, your the one paying for it! Edited 1 time(s). Last edit at 11/22/2014 02:41PM by tdrrally. |
wildert Brian Klausen Elite Moderator Location: Denmark Join Date: 03/21/2006 Age: Possibly Wise Posts: 388 Rally Car: VW Golf GTi 16V |
As long as both wheels are moving up and down the same (i.e. no body roll or bumpy/uneven surface) it doesn't really matter. So you are likely to see it on drag racing cars, where that doesn't matter a lot, and often due to regulations stating that the floor pan must be stock => not giving room for longer upper arms. Since gravel rallying is all about articulation, roll and uneven surfaces, equal length should be the thing. Brgrds Brian
Drag cars often/usually have ladder bars here. Two A-frames between the rearend and chassis. The axle can only move up and down. It is simple, proven, and tends to be stable.
What is more fun, every setup I have seen used clevises as the pivot instead of a rod end. Rod ends are not as strong as a clevis, so a clevis is used and you just use a Nyloc style nut on the bolt so you don't have to tighten it. The suspension rotates around the bolt. Drag racing is often an amazing example of what you can get away with. Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. Edited 1 time(s). Last edit at 11/22/2014 04:16PM by Pete. |
I'm pretty sure with all heim joints, my rear axle articulates just fine. John is correct, I was refering to top arm length to lower arm length, then axle pivot points vs chassis. (15/20 and 7.5/6.0)
That's 10" of travel with minimal pinion change. I would have gone with longer lower arms, but stuck with stock when I built it. The factory top arms where something like 9 or 9.5 inches long, to accommodate having the back seat in a sporty car. -Jon Edited 1 time(s). Last edit at 11/25/2014 04:35PM by jrally. |
Yah, I'm not suggesting that it doesn't work, just that I didn't think that it would, and therefore there's knowledge to be gained.
My 3-link has lower links 19.5" long and the upper is 14" and I don't know what the height difference is, I just kept making it lower and lower and grip kept going up and up, and I can't go any lower for space reasons. Pinion angle definitely changes over the course of suspension travel. Stock RX-7 4-links have the upper links pretty short and the axle and body flex in order to allow it to work, and if you unbolt one link and articulate the axle, you'll see a 2"+ discrepancy between the body and the link. No wonder the upper mounts tear off of the car, or the rearends twist and flex and take a permanent set. Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. Edited 1 time(s). Last edit at 11/25/2014 08:06PM by Pete. |
