Volvo Build?
Posted by Paul Buck
Re: Volvo Build?
October 19, 2015 02:32PM
Robert Culbertson
And how's the fit? In other words, what's the side to side distance inside the box section relative to the nifty spacers that you have for the upper eyelet?
Or isn't that important?
The outside measurement for the spacers when stuck into the bearings was 32mm, correct?
They are what they are. The only thing I asked was how's the fit.
How's the fit?
Robert Culbertson
Out of this dumpster fire
Re: Volvo Build?
October 19, 2015 02:36PM
Robert Culbertson
How's the fit?
A nice slip fit using 1.5 x .120 wall box tubing. Might need some massaging after welding though, or they could pull out the sides a bit for more squeeze before tightening up.
Paul Buck
Paul Buck
Volvo 242 in progress
Re: Volvo Build?
October 19, 2015 07:44PM
The fit is excellent. Maybe a half mm movement which i figured we could eliminate by torqueing the crap out of the bolt when it's all done.
Re: Volvo Build?
October 21, 2015 11:01AM
Paul Buck
Hey did you make a stab at changing the bearings yet? I have to do that today and though mabee I should splain how to make it less hairpullingly annoying.
Paul Buck
Paul Buck
Re: Volvo Build?
October 21, 2015 02:02PM
I have not. I've been in California driving the living crap out of a 2002 M Roadster and a 2013 550i with the dual turbo V8. It's been my first opportunity to show my 12 year old son what real acceleration and modern automotive craft is like. The looks on his face after gunning it up an onramp in the 550 or his first burnout ever in the M Roadster, those are looks I'll never forget. Terror, excitement and glee all mixed into one as our stomachs wrap around our spines. Ahhh, fatherhood.
We'll be back to our Honda and Volvo tomorrow and I would love some instruction on getting those bearings out.
Paul Buck
Paul Buck
Re: Volvo Build?
January 17, 2016 06:41PM
Back to heading in the right direction...
Towers finally done, lower mounts done, trailing arms boxed in. Just have to clean up the arms, mounts and axle and paint them. Any paint suggestions?
Also got pre-bent main hoop and half-lateral bars for a REALLY good price from a lunatic 240 rallyist.
Time to put in towers and start on cage.
open | download - 20160117_161852.jpg (33.6 KB)
open | download - 20160117_162054.jpg (27.2 KB)
LexusFman
Yengi Lado
Age: Party Animal
I Ain't rich!!!!
Re: Volvo Build?
January 19, 2016 06:38AM
I got a paint suggestion for you paint that fucker red! I'm so jelly I wish I could be putting fuckin towers in my fuckin Volvo...FUCK
Where the fuck was rally anarchy when I bought a fucking rustbox cavalier for waaay too much vanlandingham should have slapped the shit out of me.
RollyRally
Re: Volvo Build?
February 01, 2016 11:43PM
good progress. any updates on this build?
Paul Buck
Paul Buck
Re: Volvo Build?
April 16, 2016 04:19PM
So, trying to get back on track now that the weather is nicer.
Made a 17.3" wood template to act as a fully collapsed coilover. I left the old trailing arms and shocks on and jacked the trailing arm till the stock shock had no more travel. Bolted the template into the tower and onto the trailing arm and tacked the tower in.
Then it was just a matter of taking off the old trailing arms and bolting on the arms i boxed in, then bolting in coilovers.
I left an extra two inches so i can raise the towers if need be... gonna bolt in the completed 1030 axle with 4.88 gearing tomorrow when i have help. Then i'll check wheel clearance and check all the bumpstops before the final trimming and welding in.
Edited 1 time(s). Last edit at 04/16/2016 04:54PM by Paul Buck.
open | download - 20160416_122350.jpg (32.8 KB)
open | download - 20160416_122431.jpg (37.6 KB)
open | download - 20160416_140343.jpg (38.6 KB)
Re: Volvo Build?
April 16, 2016 07:12PM
Got me worried.
You planning on mounting the shock to the axel with those nice tabs I make?
You planning on using circle track swaged links upper and lower?
