Paddy1337
Tim Patrick
Galant VR-4
Clever setups for door handles & windows?
December 09, 2015 04:47PM
So, my cage is designed in such a way that the oem door handles cannot fully extend and open the door from inside the car. Minor oversight...
While I'm not located with my car, I'm curious if anyone has pictures of some K.I.S.S. solutions to this problem.
Additionally, my car has power windows and I'm also throwing around ideas to easily remedy that. My current plan relies on gravity to open the windows, and it just occurred to me this would be useless upside down, and if the door has been rendered inoperable and I'm upside down- no bueno.
I like pictures of people's unique solutions...
Robert Culbertson
Out of this dumpster fire
Re: Clever setups for door handles & windows?
December 09, 2015 05:01PM
I have seen nylon straps or wire rope used for door and latch pulls.
Something like this. You can also make a loop section to pull the door closed with.
Edited 2 time(s). Last edit at 12/09/2015 07:10PM by Robert Culbertson.
Paddy1337
Tim Patrick
Galant VR-4
December 09, 2015 05:28PM
Nylon strap has been the solution to everything so far, as I envision it in my mind. Maybe I'm not so far off base...
tdrrally
edward mucklow
December 10, 2015 08:08AM
paracord will save the day!
Josh Wimpey
Josh Wimpey
Sneak the Golf
December 10, 2015 10:15AM
What is wrong with the power windows? Just relocate the switches to between the seats for easy access for the co-driver to open any window.
One. Class -- 2WD
www.quantumrallysport.com
December 10, 2015 11:12AM
Josh Wimpey
You mean aside from the cost of the motors and the certainty of the motors and/or the switches failing?
Maybe I've just been lucky...Since 1969 I have had zero manual winders fail and seen 1 fail on a Saab that the guy lost the screw in the middle of the handle and cleaned the splined toofies off..so thats lazy owner error..
Electric winders: all of them fail eventually. And the switches too
December 10, 2015 04:20PM
It would cost more to ship the manual crank audi window shit across the pond than it would to just yank em and go with plastic. Plus I put the co-drivers window out of his reach with the belts tight. lots of fun going up and down as he tries to pass little cards through the window.
Josh Wimpey
Josh Wimpey
Sneak the Golf
December 10, 2015 04:32PM
I have seen plenty of manual window failures. but, I suspect the biggest problem in most cars is that with an "X" door bar plus the A-pillar brace, you often have no access to the manual winder without the door open. So, it doesn't matter if manual regulators are reliable or not if you cant use them.
FWIW, on the Audi units, generally, the VW MK2&3 stuff can be made to fit and is readily available for cheap (like $20ish per door)
One. Class -- 2WD
Paddy1337
Tim Patrick
Galant VR-4
December 10, 2015 04:57PM
I honestly never thought power windows would pass tech. Never read anything on it, must have just assumed since they don't work without power.
But either way, they're slow as dogshit and heavy, and I've planed to be rid of them since day one.
tdrrally
edward mucklow
December 11, 2015 06:49AM
power windows are "OK" WRC cars have them !
and if the "FIA" is OK with them it's all good
December 11, 2015 10:23AM
tdrrally
Oh. Really?
So solly lound eye but that's not a sure thing in any of the 3 sactioning bodies..
Local sometimes obstinate unique interpretations abound.
Mad Matt F
Matt Follett
December 11, 2015 10:45AM
Just for giggles...
From the CARS rule book.
12.3.9.2 In all classes it is permitted and encouraged to replace electric winders with manual ones. In all cases,
the competitor must be able to describe to the satisfaction of the event scrutineer the ability to escape
from the car with the doors closed.
December 11, 2015 11:49AM
Josh Wimpey
why my car has electric windows and a window breaker hanging on each belt (remember when those were required???). also, depending on where you are and what you need to do get on the road legally the windows need to go up and down with the doors closed for state inspection as well.
tdrrally
edward mucklow
December 11, 2015 12:38PM
i would guess that is why the wrc cars use power windows, do to the cage being in the way of a crank. a window breaker is a good idea even with non-power windows, but what to do with lexan windows?
December 11, 2015 12:48PM
Mad Matt F
Just for giggles...
Oh rules schmules...Silly Wabbit...
I would have thought at cage design time that people figure out a way for ordinary cranks to clear the door bars...That old ex-works Sapphire Cosowth I bought for my friend Jamie Florence had manual winders that worked just dandy, so it can be done.
