You can get most of the advantage by just using stainless bolts... and you get almost none of the advantage WITH the gasket, if you DON'T use stainless bolts!
As far as clearance goes, I wonder why nobody just uses shorter injectors. There's some seriously short injectors around now... and they're fairly cheap, like $100 new for some nice 1700-2200cc/min injectors with fast response times and E85 friendly... might want to consider running E85 on that ten valve, needs all the octane help it can get! Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. Edited 1 time(s). Last edit at 04/15/2016 12:13PM by Pete. |
egdinger Eric Dinger Junior Moderator Location: PDX Join Date: 05/07/2012 Age: Settling Down Posts: 14 |
The stock column bearings were hosed, so I shortened a universal column from speedway. The quickener uses the lower section of the stock column housing to seal everything up from the elements. |
Mad Matt F Matt Follett Super Moderator Location: La Belle Province, Montreal Join Date: 03/13/2006 Age: Possibly Wise Posts: 646 Rally Car: Don't Laugh, the Justy is Fun! |
Now see how I did that...
Best couple of pages eva! ![]() Fun stuff... um, we're building a pond sail boat from a log we found washed up on the beach... I need a drill, any drill, a motor that spins?... maybe I'll just buy a bit and tape up the end to spin it by hand. if I convince the munchkin, it will be R/C ![]() Home in 3 months... Justy exploits await! |
aj_johnson A.J. Johnson Professional Moderator Location: Pendleton OR Join Date: 01/07/2011 Age: Midlife Crisis Posts: 1,381 Rally Car: 88 Audi 80 |
I finally found e85 nearby. It's on the list of to-do's, and short injectors are on wish list. On the stainless bolts, the new spacer actually came with phenoloic washers and long bolts. |
What the hell was I thinking! Dad snagged this as a parts car, turns out it's totally complete titled and doesn't have any bondo! Floor pans are shot, and the battery tray is rotten but all the panels are straight and the body doesn't appear to have any rot.
In some ways, not as bad as it looks, in other ways it's just as bad as it looks. Got the motor to bark, now going to pull it and spit the thing to replace floorpans and battery tray area. Going to upgrade the frame rails while I'm at it. Vroooom! Time to pack up and head to OTR. |
