Logbooked volvo 242 rally car
Posted by Drmike
DexterVW
David Baker
95 GTI TDI
Re: Logbooked volvo 242 rally car
June 09, 2017 07:47AM
I see you've signed up for the next rally sprint! Can't wait to see this Swedish tank bomb through the woods!
Drmike
Michael Pettengill
1982 Volvo 242
June 11, 2017 08:39PM
DexterVW
Yeah! Really looking forward to it. Stop by and say hi if you see me.
DexterVW
David Baker
95 GTI TDI
June 12, 2017 08:35AM
Deff will, I'll be in the blue diesel golf.
Drmike
Michael Pettengill
1982 Volvo 242
July 08, 2017 07:45PM
Survived my first rally sprint! Had a great time and didn't break anything. All in all a great success.
I'll be competing in NEFR in just under 2 weeks so I'm working on a bunch of small prep stuff.
Today I installed my wide-band o2 gauge and sensor. According to the sensor I'm running pretty rich. In low RPM it's pretty much pegging the gauge on the rich end, and gets up to about 11.5 from 3500-7000. Cruising its hovering around 12.5, idle is similar.
Jetting:
Main - 145
Emulsion Tube - F13
Idle Jet - 55 F8
(forgot to check the venturi's)
The 145 is the smallest main jet I have at the moment, don't have any others for the idle or emulsion tube. I'm thinking maybe I need a smaller main and idle? Open to any thoughts or suggestions.
open | download - 19467690_10154636168351332_1479999373552926480_o.jpg (32.7 KB)
Robert Culbertson
Out of this dumpster fire
July 09, 2017 12:39AM
That's super rich! My turbo car would hit 11:1 at 15psi!
Aim for no richer than 12.5-13:1 at WOT, and stoich in cruise. 13:1 will probably gain you more power.
Drmike
Michael Pettengill
1982 Volvo 242
July 10, 2017 10:23AM
Update, current choke/venturi is 36mm.
I have a 38mm which based off some reading may be a better fit? Might swap them out after work tonight and see what happens, along with new plugs as I'm sure the current ones are not doing their best with it running so rich.
Drmike
Jetting:
Main - 145
Emulsion Tube - F13
Idle Jet - 55 F8
(forgot to check the venturi's) Choke/Venturi 36mm
July 10, 2017 03:16PM
Drmike
Drmike
Jetting:
Main - 145
Emulsion Tube - F13
Idle Jet - 55 F8
On the very top of the jet stack is the "hair corrector", then the "emotional tube" and at the bottom is Main Jet..
Whatchoo have for hair correctors?
July 10, 2017 03:32PM
Formatting...grrrrrrrrrrrrrrrrr.
motor..carbs...vent....aux vent...e-tube..air corr...idle..accell...pump..float needle jet
B21 2 x 45DCOE............. 34 ..4.5 135 F9 200 55F8 45 60 175 6
B21 Rally 2 x 45DCOE..... 36 ..4.5 145 F2 170 45F8 45 70 175 6
B21 Race 2 x 45DCOE..... 40.. ..4.5 145 F2 130 65F8 50 100 225 6
B23 std 2 x 45DCOE.... 34 4.5 135 F9 175 65F8 45 60 175 7
B23 rally 2 x 45DCOE.... 36 4.5 145 F9 175 60F8 45 60 200 7
B23 race 2 x 45DCOE..... 38 4.5 155 F9 165 65F8 50 60 2255 7
B23 Rally-cr2 x 48 DCO... 42 5.0 180 F9 140 65F8 45 40 225 14
B23 Rally 2 x 50 DCO.... 42 5.0 170 F9 155 60F8 45 40 225 14
B23 /Race 2 x 50 DCO... 46 5.0 180 F9 180 65F8 45 40 225 14
Emotional tube of F9 or F16 is about the most all round works good thing you can use.
Want to go back and check really carefully about the F-number???
Edited 1 time(s). Last edit at 07/10/2017 03:36PM by john vanlandingham.
Drmike
Michael Pettengill
1982 Volvo 242
July 10, 2017 08:35PM
Alright most of the jetting numbers:
Jetting:
Venturi - 38
Aux Vent - 4.5
Main - 145
E-tube - f16
Air correction 155
Idle 55 f8
Changed the venturi from 36 to 38 tonight. Seemed to help a little bit, overall a/f is closer to 13 through most of the range. I put new plugs in although the old ones looked pretty good. I might try messing with the timing a little bit. Maybe a valve adjustment. The thing rips pretty good anyways so I'm not gonna experiment too much until after NEFR.
ElectroTech
Steve Wheeler
1992 Golf
July 10, 2017 11:14PM
http://www.lainefamily.com/images/WeberTuningManual.pdf
Drmike
Michael Pettengill
1982 Volvo 242
August 16, 2017 10:56AM
Alright, not much time for an update. Ran NEFR. Made it through most of the event before going off into some small trees. Damage is limited to cosmetic and we drove it back on the trailer under it's own power. Lucky for getting away as clean as we did.
Now I'm on to BRS prep and one of the things that I would like to do is get some new struts/shocks. It has Bilstein B6's in there now. It appears there are a few options regarding valving and I know pairing them with spring rate is key. That's out of my area of experience so I'm hoping someone here can point me in a direction. (Paging J.V.)
Ultimately I will replace it with something more robust, but for now with my budget/time-frame I would like to keep it simple.
I calculated spring rates based on measuring wire, overall diameter, and effective coils.
Front: 140lb
Rear: 100lb
B6 Options are:
Front:
34-030806 - 305/206
34-030837 - 350/150
34-031520 - 300/175
34-181539 - 131/83 (according to google, oe replacement)
Rear:
24-022118 - 275/200
33-067230 - 225/150
24-002967 - 225/107 (according to google, oe replacement)
Any thoughts/suggestions are appreciated.
Robert Culbertson
August 16, 2017 03:46PM
Ordering stateside or from Sweden?
August 18, 2017 04:52AM
Here are some Bilstein rally struts for your Volvo:
http://shop.forza.se/stotdampare-1/rally-rallycross-racing/volvo/240-75
August 18, 2017 05:03AM
And from another site, but also available rear rally rate springs and a threaded coil over strut housing for the front inserts. https://www.motorsportshop.nu/epages/motorsportshop_nu.sf/sv_SE/?ObjectPath=/Shops/motorsportshop.nu/Products/B46Volvo240
August 18, 2017 10:35AM
Those are great links..if this was 1995.
But still thatäs great++only nearly double what those would cost if sourced here in US.
And GREAT.. insats like that..´short lifespan..
There IS a reason why people use thick wll 4130 DOM for the tubes...
