Re: Rear axle options for small RWD
May 06, 2018 09:44AM
Hell, Demon-Tweeks also has fiberglass arches and they are known to ship to the US no problem. So that problem is sorted (aside from money of course).
New problem: I want to locker all the things now.
May 08, 2018 01:14PM
i kinda wish i went Ford 8.8 for my rear axle in the Rx7 instead of the toyota 8"
May 08, 2018 09:55PM
The 8.8 IRS in my friend's Exploder has howled like mad since nearly new. Replace all bearings, check lash, etc., and it gets quiet for 20k miles, then howls again. POS.
May 09, 2018 02:00PM
No you don't. You just think you do..
May 09, 2018 02:07PM
well now i have to redrill rotors for the front and use a spacer for the rotor to have the right brakes, then the rear has a wonkly combo of parts to make something that looks like disc brakes, which currently i have more rear braking piston area than front (i want to redo the rear brakes eventually).
May 10, 2018 10:34PM
The grass is always greener on the other side of the fence.
On the other hand, the grass is greener if you water it.
May 11, 2018 02:24PM
9" grass?
May 14, 2018 03:41PM
What's wrong with the 8.8?
May 14, 2018 06:00PM
Bigger, heavier by a good deal..
And a shitty 2 pinion design..
Diffs you gonna beat on you want 4 pinion/planets..You want some plates and more lock-up..
And you don't want or need something that big and did I mention HEAVY
( I am making the increasingly foolish assumption that the subject is about a RALLY car and not a theoretical or idealized imaginary car)
Ascona73
Bob Legere
1971 Opel Ascona
May 14, 2018 06:17PM
Best part about the Toyota 8"...cheap available parts, PLUS easy setup.
Front loader with threaded side bearing cups means fast setup time. And gear ratios can be swapped rapidly if you buy another center chuck/LSD/gear set. About 20 minutes.
It is much lighter than an 8.8 too.
Opel is a 4-letter word...
http://www.flickr.com/photos/10498579@N07/sets/
May 14, 2018 09:15PM
The nice thing about the 8.8 is that it uses the same axle spline counts/diameters as the Ford 9", so if you wanted, you could put 9" bearing ends on the 8.8 so as to eliminate the C-clips, and then you can run any diff you wanted.
On the other hand, you're pretty much limited to spools, lockers, shit limited slips, or Torsens, since I don't think anybody ever geared up for the "real clutch type diff for pervs who put retained bearing ends or better yet floater ends on a Ford 8.8 rear". Because people who have a choice and need a rearend that big just go straight for the 9". People run the 8.8 because they have to, not because they want to. (Admittedly, it IS a lot lighter than a 9", if you're using iron parts. On another forum when I mentioned that my all-up 9' rear was about 180-190lb, I was asked how the fuck did I get a 9" that LIGHT....)
There's a company that makes pumpkins that plug into a 9" rearend but use Chevy 12-bolt guts, which are almost as strong but have a lot less frictional loss since the pinion is a lot closer to axle centerline. Worth a tenth or two on a drag car. Relevance here: Zero. But interesting nonetheless.
Edited 1 time(s). Last edit at 05/14/2018 09:19PM by Pete.
May 21, 2018 04:50PM
aaaaaaand the 9" lasted six runs before I blew it up.
It wasn't so bad I can't make it home but clearly there are Unhappy Things in the diff.
Vincent Gagnon
The same thing that I just wrote
Volvo 240
May 21, 2018 08:48PM
Yeah, I feel like we are saying the same shit over and over again.
You know, things like : CHECK YOUR FUCKING EMAILS NOW!!!!!!!
Ask for work.
If they don't give you work, ask for bread.
If they do not give you work or bread, then take bread.
- Emma Goldman
May 25, 2018 10:10PM
Vincent Gagnon
Didya get the tracking number?
