Kristof
Kristof Kiraly
1986 VW GTI
Re: VW Strut mount ?
May 03, 2013 11:07PM
What year/model Subaru front strut mount will work for a 1986 VW GTI MK2?
Maybe post a link and description, please?
I plan to get JVAB rally suspension in the future.
Thank you,
Kristof
May 03, 2013 11:24PM
Kristof
Thank you,
Kristof
Any 1988 or later Le-gassy or Impretzeled
Kristof
Kristof Kiraly
1986 VW GTI
May 04, 2013 09:34PM
Anyone know the inside diameter? Will it fit a Bilstein HD strut mk2/3 as well?
Robert Culbertson
Out of this dumpster fire
May 05, 2013 12:59AM
You will have to machine a spacer to run a Bilstein HD in the Subi top mounts. I think there is a 4mm or so difference in diameters.
May 05, 2013 11:09AM
Kristof
Of course I know it, but I won't tell you until you edit your name and location.
Kristoff who?
What town/city in SoCal?
Edit your name and then we can talk.
May 07, 2013 03:26PM
easy to make at home
Kristof
Kristof Kiraly
1986 VW GTI
May 07, 2013 07:48PM
Now, I dont remember what the mk2 strut tower looks like.
It looks like you modified the top and the sides to strengthen the strut tower to accept the roll cage? correct?
Edited 1 time(s). Last edit at 05/07/2013 09:03PM by Kristof.
fliz
Chad Eixenberger
1988 VW Golf #687
May 07, 2013 09:12PM
I believe that's an entire replacement for the top.
http://www.specialstage.com/forums/showthread.php?30988-VW-Strut-mount-options&p=324772#post324772
Subaru and Burmeister both mean cutting the sheet metal to get a flat surface to attach them.
May 07, 2013 09:13PM
Kristof
Now, I dont remember what the mk2 strut mount housing looks like.
It looks like you modified the top and the sides to strengthen the strut mount housing to accept the roll cage? correct?
That car was done like that to raise the point the top mounts hit the tower---because that guy got some nice suspension that was about 210mm travel... that was up from the "normal' Bilstein yellow things which were right at 160mm travel---so 2 full inches more travel..
More travel is good.smileys with beer
Kristof
Kristof Kiraly
1986 VW GTI
May 07, 2013 09:36PM
How to get the nice curved section done at home?
Possible to buy prefabbed?
May 07, 2013 09:53PM
sigh I should make a hand full of them i have gotten quite a few emails about them
they are fun too install space them bolt them weld them and then air chisel the old
one out its a afternoons job.
they where 130 I think last I remember ill ask the laser shop about making some for
me I know I can get rid of about 5 sets there are about 15 cars with them around.
May 08, 2013 01:13AM
Kristof
You have long travel suspension?
Or want to lower the car?
Or are you just after the top plate?
Kristof
Kristof Kiraly
1986 VW GTI
May 08, 2013 01:27PM
Well, I've upgraded to the vr6 style mounts and they are a piece of crap. I still haven't fixed the issue of clacking in the front. The top hat is an inch or two above the body and whenever the suspension drops, it creates a clack sound and is unsafe.
So, I wanted to get burmeister, but then I read about the Subaru mounts and I'd rather go that way. But I also need the plate, and I don't know how I would be able to make something like that above.
I plan on getting JVAB suspension.
May 08, 2013 03:03PM
Kristof
Kris, I type slow and mistype a lot, you know, cause I've been a machinist of mechanic since 1970 and have big manly strong hands, a handshake that crushes the majority of guys most of who are girly-men, so i hate typing
Too many questions about what you now have, but do this. Call lets see what you have and what can be done while making sure that we don't creat problems for later or make you spend money twice...
I've re-done an awful lot of guys who have the ordinary VW Bilsteins and saved collectively thousands of bucks...and one easy thing to do is to chop up the threaded pin and shoulder as they come to work with my upper spring seats---this saves a lot of Over All Length, so we can get more travel in a same length package.
Talk to me.
DG_Rally
Dave Grenwis
'92 VW Golf
May 08, 2013 05:06PM
I'm going the subaru mount direction and getting the spacer and bilstein's JVAB'ed as we speak. I grabbed some strut tops off a car at the junk yard, it might have been a forester? Like John said, it looks like all the subaru tops are the same after '88. The junk yard bearings are like new compared to my vr6 bearings that have seen about 5 events. The junkyard tops themselves look like they came from well... a junkyard but that's cool with me.
I haven't drilled the holes yet but I don't think cutting the top off will be necessary. It looks like the suby top should fit right in. The picture shows my high-tech template. The holes that are shown are from my old strut bar, which doesn't fit since I did a ABA swap. I plan to fill those in. If it turns out that the tops will need to be cut, I'll try to remember to post on here again.
Dave Grenwis - DG Rally - www.dgrally.com
