JVAB Suspension
Posted by gpbullock
Re: Bad Ass BMW
May 05, 2008 11:45PM
gpbullock Wrote:
> It's A. Zenardi's new ride! Sweet. I would like to
> get a set of handcontrols that he has. The Duck
> clutch and the throttle on the steering wheel.
> Although he can still use his right foot for
> braking. I will have to set brakes up on the
> steering wheel also for driving with both hands on
> the wheel.
Sounded good! But they didn't get sideways once! No JUMPS! What's going on there?
Are they pussies or what?
Hey Mark, what's happening with your project?
gpbullock
Mark Bullock
Re: Bad Ass BMW
May 06, 2008 12:30PM
So far not too much. Paul, the owner of the car is saving his dough, selling a bunch of stuff he doesn't need to save for his suspension and roll cage, so we are in standby mode. He was given a donor car with a few bits that were better than what he had, so he's stripped the donor, sold everything he didn't want or need. We have the focus in the lift right now without a front suspension and sub frame so we haven't been able to get his car in the lift for suspension photos yet. I found a four cylinder motor that was the same year as his car and tried to convince him to get it for his car but he didn't bite. After seeing that new 320is you posted though convinced me. That engine sounds sweet.
tmadison
Tim Madison
Re: JVAB Suspension
May 13, 2008 06:34PM
I'm hoping I don't come off like a douchebag here but have you considered looking into the motor from the 318? Its a 1.9L four-cylinder and it already comes in the car so California won't mind the motor swap.
Sofa King
Monika Hawkinson
2006 Tacoma
Re: JVAB Suspension
May 13, 2008 07:17PM
No, you don't sound like a douchebag, but I probably will if I ask "Did you even read the rest of the fawkin thread???"
Monika Hawkinson
Seattle, WA
gpbullock
Mark Bullock
Re: JVAB Suspension
May 13, 2008 08:29PM
Yes, the 90-91 year models would work probably in CA. for an engine swap. Looked into it already so we'll see.
tmadison
Tim Madison
Re: JVAB Suspension
May 15, 2008 02:34AM
haha, I did but apparently I missed that part somewhere, my bad. in my defense it was late and I was tired.
A1337STI
Alex Rademacher
93 GC with an 01 RS swap!
Re: JVAB Suspension
February 23, 2012 06:47PM
what car is he driving (ignorant sorry) and what racing series?
and wow holy gear whine! wow!
wonder if i should set that to my ring tone... hehehe
alosix
Jason Powers
Re: JVAB Suspension
February 24, 2012 10:46AM
Wow.. this thread is fun.. I really think I read John stating that Communism is BETTER than CA.. I'd have to agree (thought I haven't really experienced communism, but I have experienced CA)...
A good friend of mine has a 87 325is. I really liked driving that when he got it. The trans actually wants to shift (unlike my common blue car).
Now my GF has a 92 318ic. The ic's came with a silly low gear ratio of something like 4.27. The little car is a blast to drive (even without the power of my common blue car's turbo). You can also find lsds in the ises, so getting a useful rear under the car is possible.
If the car needs a swap, that M42 isn't a bad little engine at all. Seems pretty easy to work on and parts aren't all that hard to reach.. Though if you don't want to take the intake apart you have to be a bit creative to change the starter.
Now, if one was building a rally car.. I'd probably wait on the swap until you've got everything else done. A proper referee'd CA swap might be enough to derail a rally car build from being finished.
This isn't floor mat anarchy
Edited 1 time(s). Last edit at 02/24/2012 10:47AM by alosix.
gpbullock
Mark Bullock
Re: JVAB Suspension
March 01, 2012 07:59PM
Well, this is a pretty old thread. The BMW ended up getting wrecked before too much effort was put into it and the owner decided to part with it. I ended up building an offroad car for someone else in the meantime. Here are some pics..
open | download - RIDE-HEIGHT.jpg (132.8 KB)
open | download - DROOP.jpg (136.4 KB)
gpbullock
Mark Bullock
Re: JVAB Suspension
March 01, 2012 08:00PM
Couple more..
open | download - COMPRESSION.jpg (138.5 KB)
open | download - SIDE.jpg (137.5 KB)
gpbullock
Mark Bullock
Re: JVAB Suspension
March 01, 2012 08:01PM
open | download - SIDE2.jpg (118.9 KB)
open | download - SUSP.jpg (110.4 KB)
gpbullock
Mark Bullock
Re: JVAB Suspension
March 01, 2012 08:02PM
Took longer than I had expected but ran into all sorts of issues..
open | download - SUSP2.jpg (102.3 KB)
open | download - SUSP3.jpg (94 KB)
Re: JVAB Suspension
March 01, 2012 09:30PM
OMG soooooo cool!!!!! I want to do a locost someday, but maybe do long travel suspension for hooning about.
gpbullock
Mark Bullock
Re: JVAB Suspension
March 02, 2012 06:44PM
This build was on a real tight budget. Started out as someone's huge (6.5' wide) 4 seat crawler project. I cut the front and rear end off the original chassis, dropped the floor 12" and added the front and rear ends to accomadate A-arm long travel and rear trailing arm suspension. It was also my first full suspension from design to completion. It was intimidating to build the front J-arm & rear trailing suspension arms from scratch but a little research on suspension design and the slot tab/box method and they worked out great. I did the rear trailing arms and links also. Front is around 22+" of useable travel but could go as high as 26" if you're willing to go into higher +camber, Rear is 32". 37" BFG Bajas, 2.5" Class 1 hubs. Ford 9" with 4.88. I only did the roller but it will end up being LS powered front engine, rear wheel drive. 144" wheel base, 8'6" in total width.
