eyesoreracing
Dave Coleman
Mazda3, SE-R Spec-V, 510
Re: Fixing focus? any one intrested
May 20, 2008 06:55PM
Hey JVL, where's that bushing supplier? My band saw is itching!
-Dave
May 21, 2008 12:04AM
> saw is itching!
I'd get a oinment and be more careful or it's drip drip drip........
http://www.deucefactory.com/index.asp?PageAction=VIEWPROD&ProdID=80
> -Dave
eyesoreracing
Dave Coleman
May 21, 2008 11:15AM
Perfect! These guys are 4.0 miles from me as I type. Guess I know where I'm going for lunch...
-Dave
Sofa King
Monika Hawkinson
2006 Tacoma
May 26, 2008 08:24PM
Dave! Did ya get some of those things?
What's the width (of the bush)?
Monika Hawkinson
Seattle, WA
eyesoreracing
Dave Coleman
May 26, 2008 11:09PM
> Kevin Hawkinson
> Seattle, WA
> 83 Volvo 240 Gp5 (in progress)
> 34-ish
I went to the address on the website and found myself in the middle of suburbia. Then I looked at the google maps page I had printed out, and I think I had typed in an incomplete address. Then I had to get back to work. And then, and then, and then... I suck.
-Dave
May 27, 2008 02:09AM
> > Kevin Hawkinson
> > Seattle, WA
> > 34-ish
> then... I suck.
You know if you had written the name and address on paper......
well get over there at lunch and post what the width of the damn thing is
and you'll be less sucky.
> -Dave
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
May 27, 2008 09:16AM
Since this is a Focus rear suspension thread. I have had yet another DMS shock problem so I am looking for a more affordable spare / replacement options.
I was thinking about going with a Bilstien shock in the back since I like the DMS spring rates / ride height. The DMS rear shock is a pin mount on top and a single shear rod end on the bottom. Since the mounts are somewhat customized on both ends does anyone have a good way to find a shock that will work from Bilstien's catalog. Should I just call them? I only seem to be able to find circle track shocks in the catalog that have measurements.
I will take measurements this evening but I think as long as I can get a pin mount shock that is close I should be able to modify the mounts to make it fit on the car.
eyesoreracing
Dave Coleman
May 27, 2008 10:15AM
> options.
> measurements.
Call them and talk to Bret Norgaard. He has a rear shock figured out, on paper at least...
You had a rear DMS shock failure?
-Dave
Andrew_Frick
Andrew Frick
May 27, 2008 11:47AM
It was not a failure but it is hemorrhaging fluid. It is still damping but every time the car was in for service the shock was covered in fluid and if you let the car sit it will create a puddle under the shock. I know this type of leak has happened a couple of times on one of the other spec foci.
May 27, 2008 12:04PM
The overall lenth of the stock Fucci shock is same as stock Xratty shock, this would lead me to think Hmmmmmmmmmmmmmmmmmmmmm we can use the same unit. All but that miserable top pin mount......
Makes me wonder "What did I do fir all those VWs that I supplied suspension with pin mounts? What what WHAT!!!!!!!!!"---cause i sure sent a lot of VW Golf, and some old Subarus and some other junk with pin mounts, so i must have done something!
Call if you'd like, this one is toooooooooooo easy.
eyesoreracing
Dave Coleman
May 27, 2008 07:57PM
That's a failure...
-Dave
eyesoreracing
Dave Coleman
May 27, 2008 08:01PM
What's the back of an Xratty weigh?
Just wondering if we're in the right ballpark.
What kinda shocks do you have for the Xratty?
-Dave
May 28, 2008 10:56AM
> Total weight, minus skid plates and passengers =
> 2669
> Front left = 745, right = 694
> rear left = 595, right = 635
Bilstein 50 mm shock in rear.
I believe it's valved 260/90. Don't recall spring rates.
Edited 1 time(s). Last edit at 05/28/2008 10:58AM by NoCoast.
open | download - Apr12rearbrake.jpg (49.4 KB)
mothra
Matt Smith
xr4ti
May 28, 2008 12:34PM
My XR springs are 175 lbs in the rear.
Matt Smith
eyesoreracing
Dave Coleman
May 28, 2008 06:33PM
The last Mazdaspeed3 I weighed was 588 on each rear wheel. This should be similar to a Fukus (Mazdaspeed3 front is MUCH heavier, but rear should be on par). So it looks like we're in the right ballpark with the XR stuff.
Hey Andrew, what are the DMS spring rates for the Focus? Is the rear a coil-over, or is it in the stock perch?
That 175 on the rear of the XR looks like something more in the 200 neighborhood when it gets to the wheel. You've got a >1 motion ratio back there.
-Dave
