What I did on Adam's Crane's Toiletta today
May 04, 2008 11:20PM
Specifically on his Volvo Dana 30 halfshafts.
First, Adam way bad and delivered them all dirty, they must have laid in a swap for years and for some reason he didn't want to spend HOURS taking the bearings off so Kevvie and I spent hours getting them off.
Then we plug welded all the holes on the flage and I kissed the front and back clean then we made the centering spigot Toyota size.
They're ready!!
You made your drilling jig yet???
Better get it right!!!!
They look spiffier than shit.
Sofa King
Monika Hawkinson
2006 Tacoma
Re: What I did on Adam's Crane's Toiletta today
May 05, 2008 12:42PM
Dual-shield MIG makes for some nice welds.
Monika Hawkinson
Seattle, WA
May 05, 2008 01:04PM
pix or it didn't happen
May 05, 2008 02:53PM
Fix the "upload" part of the SPGM Webministration and i will, it was a pretty nice process. Simple but nice.Kevvi's scotch-brite: Gooooooooooooooooood.
Sofa King
Monika Hawkinson
2006 Tacoma
May 06, 2008 03:46AM
There's one of Adam's Volvo axles next to one of my Toyota axles.
And here's what dual-shield MIG looks like:
Monika Hawkinson
Seattle, WA
Edited 1 time(s). Last edit at 05/06/2008 03:49AM by Sofa King.
May 06, 2008 12:41PM
Hey John,
Did you weld in plugs, or just fill in with rod? Just trying to figure how to do mine.
Thanks,
Mark B.
Sofa King
Monika Hawkinson
2006 Tacoma
May 06, 2008 01:16PM
John did the machining, while I was welding.
Clamped a copper plate to one side, and then from the other side, plug welded with the MIG. (Dual-shield is flux covered wire plus shielding gas.) Then, weld again on the backside to fill in any little holes.
Monika Hawkinson
Seattle, WA
eyesoreracing
Dave Coleman
Mazda3, SE-R Spec-V, 510
May 06, 2008 06:27PM
> gas.)
Thanks for the explanation, that was my next question. Looks remarkably splatter-free. Is that the miracle of dual shielding, or just getting your settings right?
-Dave
May 06, 2008 07:08PM
When dual shield is set properly it's basically spray arc welding. Very smooth with none of the short arc MIG spatter just a cone of tiny metal droplets flying off the wire. I love welding with 0.045" Lincoln Outershield 71 (and the equivalent in other brands) wire because you can lay down a 3/8" fillet in one pass and it will still freeze quickly in out of position welding.
Tim
acrane
adam crane
corolla GT-yes
May 08, 2008 12:16PM
drill jig worked! i now have a toyota pattern on my volvo axles,
though the high interference of the wheel studs may not make it
drilled - .531
stud shoulder - .542
knurl dia - .551
I'm gonna ream to .543 i think.
pictures to follow, tonight.
"I put the hurt on dirt" - adam crane
http://CraneRallyCrew.com
corolla gt-s "Patches"
Op: S.S.
acrane
adam crane
corolla GT-yes
May 11, 2008 01:29PM
without further ado,
http://picasaweb.google.com/acrane/VolvoTssTabs
Op: S.S.
Edited 1 time(s). Last edit at 05/11/2008 01:30PM by acrane.
open | download - small axle.JPG (5.8 KB)
May 11, 2008 03:26PM
> ex. madmann28
> adam crane
You get my email about the fittings for the master cylinder?
You around now?
acrane
adam crane
corolla GT-yes
May 12, 2008 05:16PM
5.3 is FUN!! power -shift- power - shift- power
i did get your mail. would you like me to stop by in the car tomorrow?
in the evening there will be beer as a pre rally fun at the redhook brewery near woodinville, redmond. i'll only have an hour or less.
so a ring and pinion carrier with a volvo 3.7 gear was handed to ritch at driveline service in b'ham. (he's the man- building a one piece driveline later)
it was the same size as the 3.5 carrier that was pulled from my axle. math was done to get the dana gear meshing properly.
as far as which axle to pick? any volvo is the exact same width. same input flange to axle length too. i'll picture the adapter ring that was made so my driveline bolted right up.
the volvo brakes fit under the 14" wheels, but pedal travel is too long, then very "grabby" does anyone know if a supra had a similar mc with larger bores?
would a residual pressure valve 2psi wilwood thing help by keeping the pads close to discs?
problem is alot more volume to the rear brakes than previous.
Op: S.S.
