Transmission cooler pump
Posted by Rallyho
Rallyho
Mike White
Saab 900 - aka-The Swedish Rally Tractor
February 23, 2006 10:32AM
I would like to circulate the trans/diff fluid out of my saab gearbox through a cooler. In the past I've seen folks do this with a $200ish Tilton (I think) fluid pump. Is there a cheaper way to accomplish this?
Thanks
She's screamn' fer eet!
Rallyho
Mike White
http://www.facebook.com/rallyhomotorsports
tedm
Ted Mendham
Re: Transmission cooler pump
February 23, 2006 11:02AM
Only 25.99!
Place it within reach of the navvie.
http://www.northerntool.com/webapp/wcs/stores/servlet/NTELargeImageView?xsell=true&rfno=7737&storeId=6970
Ted Mendham
www.rensport.net
Rallyho
Mike White
February 23, 2006 11:17AM
That's the same link you sent me when I was looking for the low-budget co-driver stomach pump. Nice find on the Dual Use device.
Rallyho
Mike White
tedm
Ted Mendham
February 23, 2006 12:03PM
SHUT UP AND CRANK!
Ted Mendham
www.rensport.net
Rallyho
Mike White
February 23, 2006 12:22PM
"My Fast demands more crankn' less yackity-yackn'."
Rallyho
Mike White
February 23, 2006 12:35PM
Jesus fucking Christ Mike, I showed you the goddam pumps in the trunk of the 96 that Ola Stromberg said that they used
Rallyho
Mike White
February 23, 2006 12:58PM
Damn...you probably did but it musta dribbled out of my ear one night.
So maybe pn# 480545 here?
http://www.aircraftspruce.com/catalog/eppages/interrupterpump.php
Well, there is no freakn' ice for racing on the ponds...which is damn frustrating, but other than that Maine is going well.
I'm thinking I ought build another Swedish POS.
Rallyho
Mike White
February 23, 2006 02:05PM
http://www.kollevold.no/images/476087e.jpg
Edited 4 time(s). Last edit at 02/23/2006 02:11PM by john vanlandingham.
open | download - 532.jpg (0 bytes)
February 23, 2006 02:13PM
jesus all the taxes and cold weather and they can't even arrange any fuckin ice!
A FRONT wheel drive POS or a RWD pos?
I just got a super nice 79 99 I've known since 1984.
> Rallyho
> Mike White
Rallyho
Mike White
February 23, 2006 02:54PM
FWD POS. I've got an 84 900 shell with most of a cage in it. I'm thinking most of the stuff from the 99 can br thrown in the general direction of the car and match up good with a minimum amount of work. Probably be harder to make the cage legal than anything else.
I will want to see what my boinger/damper options are. I think the stuff from Groo's car is going on there....which I think consists of those west coast springs and some revalved Bilsteins.
Rallyho
Mike White
February 23, 2006 03:04PM
seems pretty evident that circle track springs can be forces into service as fronts.
you HAVE to double-skin the upper mounts in front.
Consider rack travel limiters. front motor mounts will be needeed and the sheetmetarl there should sans doubte wants doubling at least.
Gp5???
Rallyho
Mike White
February 23, 2006 03:10PM
I like the roundy round catalogs. They've got all kinds of springs that look like they'll fit the front..and weight jacker buckets, and these long stroke bilsteins.
Yeash on the double/triple walling stuff around the shock/motor mounts. I think we ended up putting angle iron on the a-arm "towers" that caught the bolt holes too...
travel limiters on the rack...as in steering rack?
Gp2 for now...cause I've got that motor with the rebushed rods/veedub plugs/etc.
Rallyho
Mike White
February 23, 2006 03:32PM
> stroke bilsteins.
Get INSIDE the boxy "wheelhouse" and look where the upper bolts go thru into the little square nuts which are stuck in with dried snus on 96s and 900s.
Then go look at the hefty 3/8th inch bar spanning the 2 holes on the 99.
Do something similar. It'll look like a 3/8th inch thick alignment shim drilled and tapped to M10 x 1.5 or if you want to be classic 99, 3/8th UNC
> rack?
Yeah, the 900 is 2 inches longwer (if you use the 99 upper link on the rear) and yet has same turning radiius, I think they let the wheels crank over more and 900s certainly blow more outer CVs on street cars than 99s.
Ola concurred way back when.
Didya ever get a Volvo 240 turbo fuel distributor?
> Rallyho
> Mike White
Rallyho
Mike White
February 23, 2006 04:12PM
> 900s.
Yup...know what you're talking about. That area is wimpy on the 900.
> > rack?
No kidding...interesting. So the 99 rear end links are shorter than the 900?
> the
> distributor?
uhhhhh, shit...did I? I cunt remember actually. Don't think so.
> > Rallyho
> > Mike White
> John Vanlandingham
> Sleezattle, WA, USA
> Vive le Prole-le-ralliat
> www.jvab.f4.ca
Rallyho
Mike White
February 23, 2006 06:57PM
> with
> > the
> > distributor?
> Don't think so.
I thought I gave you a Mercedes 380 SEL fuel distributor out of some clunker in some other friend's yard that had 8 ports or something similarly stupid to try!!!!
