Morten
Morten
1974 Dodge Colt
Worn valves
March 01, 2006 11:14PM
I'm not sure if you remember the thread that I had going on ss.com about noise in the top end of my motor. In taking the rockers off, I think I've found the source of the noise.
Would worn valves cause a racket in the top end ?
open | download - left-good-valve-right-worn-valve.jpg (80.4 KB)
open | download - worn-valves.jpg (80 KB)
Re: Worn valves
March 01, 2006 11:57PM
Did you measure valve lash first?
The heads generally aren't what wear, the seats wear and the valve guides wear, which kinda compounds seat wear. They usually don't make noise in and of themselves, just have crappy sealing or fog for mosquitoes.
I did have one guy with heavy valvetrain noise over and beyond what his ill-concieved Rhoads Lifters would normally account for, it turned out half of the exhaust valves were sunk 1/4" *or more* into the heads...! But somehow I don't think this is your problem, or even possible on that type of cylinder head.
