Ascona73
Bob Legere
1971 Opel Ascona
Re: rule changes
November 07, 2008 11:13AM
Doivi Clarkinen Wrote:
> I thought about how cool it would be to build a
> mid engined turbo Omni long ago but then figured
> that would be too much work when it really
> wouldn't be any faster than a turbo FWD Omni...
But at least the gravel would be spewing from the correct end of the car! Worth it IMO...
Bob
Opel is a 4-letter word...
http://www.flickr.com/photos/10498579@N07/sets/
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
Re: rule changes
November 07, 2008 01:35PM
Did you guys also see the open lite class the RA just released. It seems like RAs classes are about 1-2 years behind what NASA has been doing.
jameseshepherd
Jim Shepherd
Location: A few hours north of Seattle in the state of confusion
2001 Toyota Celica GT-S
Re: rule changes
November 07, 2008 03:13PM
How about a Hayabusa powered Suzuki Alto Works?
4WD and lots of power?
open | download - japanoid_works_keicar_p.jpg (28.1 KB)
Phlyan Pan
Travis Sleight
Moved on....wasn't much of a rally car anyway
Re: rule changes
November 07, 2008 07:26PM
I haven't read the rulebooks in a while, but is there any rule that a car has to have only 1 engine?
How about a civic with a 900RR engine at each corner? You could do crazy things with weight distribution. Pretty lightweight I would think, N/A so no restrictor(s), Good horsepower (those things make like 100+ a piece right?), sequential shifting, no diffs to break, if you break something in 1, you got 3 more to drive home on. How 'bout it?
"Time to unpimp ze auuto."
sleightc (A.T.) Yahoo {DOT} com
Re: rule changes
November 07, 2008 08:25PM
> engine?
That'd be one hell of a loophole.
"Sure, the engine under the hood is a 1.8l 8 valve engine. It's not the one actually powering the car, though."
acrane
adam crane
corolla GT-yes
Re: rule changes
November 11, 2008 03:36PM
motor cycle engines are stupid,
but after reading the rules again,
mike hursts' mustang is now in group 2.
so is a NA rx7,
so is 3.5L nissan in a 240sx
so is a 3.2L v6 in a volvo (ditch the turbo john Lane)
Welcome to a new "super power" era in rallying.
your 1.6L is worthless here.
begin shitting bricks. - STOP SHITTING BRICKS - your right andrew.
3. Replace the following definitions in Article 1.9 with the following:
Group 2
Two-wheel drive cars with normally aspirated, small displacement engines with
Open class style modifications allowed. [STRIKE]Adjusted displacement is limited to
2400cc.[/STRIKE] Refer to Article 10.2.B.9.
"I put the hurt on dirt" - adam crane
http://CraneRallyCrew.com
corolla gt-s "Patches"
Op: S.S.
Edited 2 time(s). Last edit at 11/11/2008 07:18PM by acrane.
Andrew_Frick
Andrew Frick
Re: rule changes
November 11, 2008 04:00PM
How are you getting this? In the RA rule book the 10.2.B.9.b still contains the GpF style displacement to weight chart. The Mustang exceeds the maximum displacement of 3,080cc
So 1.6L cars can still have an advantage because of the lower weight they are able to run. I still don't know if a motorcycle engine is the way to go but all is not lost for small displacement cars.
Edited 1 time(s). Last edit at 11/11/2008 04:02PM by Andrew_Frick.
Lurch
Eric Burmeister
Mazdaspeed3 and Mazda Protege
Re: rule changes
November 11, 2008 04:25PM
Tom, keep building.
Like Doivi says, someone's gotta drive it, and even more important, someone's gotta build it and make it finishable. Ask NatuRally about their build. Or me about mine. It takes time to develop a car from scratch even when you have the engine in the same spot.
You can drive your ass off. Getteth thee a quick, reliable, light rally car and let the beatings commence.
Lurch
Eric Burmeister
The west coast...of Michigan
mellow65
Oliver Klozoff
Nada
Re: rule changes
November 11, 2008 07:50PM
> so is a NA rx7,
> Lane)
> your right andrew.
> Group 2
> Open class style modifications allowed. Adjusted
> 2400cc. Refer to Article 10.2.B.9.
> adam crane
> corolla gts
> Op: S.S.
> Edited 2 times. Last edit at Nov 11, 2008 by
> acrane.
you were reading it the same way i was, it sounded like they lifted the size limit for G2, in reality they were just removing the 2400cc sentence because it contradicted the new size of 3,080.
Re: rule changes
November 11, 2008 08:26PM
Yes there is still the 3000cc limit on G2, yes you can put the engine in the glove box....and if you can prove the thinnest of connections for engine parentage you should be fine.
Open class for G2/G2 is now pretty much a reality. The new Open Light class is also pretty exciting.
Now let me assure you if a car comes in with flakey construction it will not get a logbook. Go ahead make a mid engine Bunny or Golf, just make sure the work is sound.
Re: rule changes
November 11, 2008 08:32PM
Free the ties to the manufacturer and I will stop rallying for a year (or two) to build an incredibly well built monster....seriously, what is the point of keeping within the make now?
In the mean time I will be tidying up our beast to start a Cody v. Burress v. Lane local 2wd war at Doo Wops.
Re: rule changes
November 11, 2008 10:16PM
> Doo Wops.
> __________________________________________________
> _________
> Fine Tuning | DemonRally
> "If everything seems under control, you're just
> not going fast enough." -- Mario Andretti
Really there is no point to my thinking. I talked with Hurst about this a few times. I still will work on it. He did mention once (I think) that if the parentage rule were dropped it would be on a regional only basis. Hey we're making progress though !
mellow65
Oliver Klozoff
Nada
Re: rule changes
November 11, 2008 10:51PM
i think hear old group B rally days again, holy crap i would be all sorts of giddy to see some monsters out rallying,
Re: rule changes
November 12, 2008 12:03AM
> start a Hughes v. Lane local 2wd war at
> Doo Wops.
Fixed that for you. Hey a guy has to have hallucinations right. I mean aspirations. Though I was probably closer at first.
Re: rule changes
November 12, 2008 01:57AM
I don't understand the parentage thing at all with the ability to put the motor where ever you want....Gene, you get it going at the regional level, and I will leave, sell pretty much everything I have and return in a bad way, stupid way....as long as I could compete nationally in the regional car I could care less where I am scoring points.
Grant, get the fuck out here and get going, there is some fun 2wd boys out here to get down with...plus Canada is right here, like ^^^^
come RACE.
