JVL stuff damn your email john and mine
Re: JVL stuff damn your email john and mine
December 14, 2008 03:37PM
Also I have heard there like 4 different pulley’s and need different offsets I
want to solve the problem for everyone with like spacers or washers or something I
don’t want to send them out and they need something for a v belt when I send them
a serpentine setup.
All I would need the car for would be max 3 days, I’m in Redmond though Redmond
ridge and my number is 425 463 5307
December 14, 2008 08:32PM
If I had a running vw I would bring it over in a heartbeat...I have a junk vw 16V head and some bracketry I could dig up....?
Josh Wimpey
Josh Wimpey
Sneak the Golf
December 14, 2008 09:51PM
I gave a bit of thought to this VW Power Steering pump bracketry today and....
--I think it would be best to make a mount that is universal for mk2 and mk3 VWs regardless of whether they choose to run 8v, 16v, stock intake, carbs, ITBs, alternator in stock location or shere the AC compressor goes....etc etc
---The ONLY solution I can think of that would be the close to universal for the various NA setups people run is to mount the PS pump tucked BEHIND the motor. Perhaps the mount can come off of the arm coming off the block that attaches to the right rear motor mount.
Disclaimer:
I don't have a car here to look at so I can't check to see if I am totally crazy or not...
One. Class -- 2WD
www.quantumrallysport.com
December 14, 2008 10:13PM
I think moving the PS pump up would be huge....I think the alternator would be cheaper to run in the rear though, although the size of the alternator might be an issue...?
mack73
Jason Wine
December 15, 2008 12:15AM
Ditto, don't put the PS on the back - I wouldn't want my powersteering fluid any hotter than it already is. ALternator to the back
-Jason
December 15, 2008 10:58AM
William,
I can drive my car out to your place but them you would either need to give me a ride back to West Seattle or do all the measuring there. Can you do what you need to do on a Saturday?
As far as relocating any components.........there ain't much room on the back side of the 8V engine. I recently changed a rear motor mount and it was tight. It would be worse with headders. I think that it would be better to keep the same general locations and go with a more solid mounting system that also protects the pulleys better. I have a good skid plate, but on the Totem rally I was getting massive belt slip in the deep snow. Could we incorporate a small guard and belt guide for the PS?
Eddie Fiorelli
Eddie Fiorelli
mk2 VW GTI
December 15, 2008 11:02AM
Why not put the PS pump where the AC compressor should be? Seems like a 9A or ABA solution would cover 99% of cars out there.
Josh Wimpey
Josh Wimpey
Sneak the Golf
December 15, 2008 12:23PM
because lots of people---although not us---put the alternator where the AC is so they can run carbs or ITBs or just to move the alternator down low for center of gravity reasons...
In addition, there are at least a few different brackets that go there depending on your arrangement (AC vs non AC, Serpentine VS v-belts) so it is not possible to make a universal bracket that will work in that spot.
One. Class -- 2WD
Edited 1 time(s). Last edit at 12/15/2008 12:27PM by Josh Wimpey.
turoc
Ozgur Simsek
working on a Veedub
December 15, 2008 12:25PM
> compressor
> would
> arrangement so it is not possible to make a
I would like to reserve that area for the alternator for future itbs or carbs
Josh Wimpey
Josh Wimpey
Sneak the Golf
December 15, 2008 12:26PM
> 94 Golf
> www.Mack73.com
I would certainly rather have heat issues with PS than have an alternator that fails regularly from being baked.
Failed PS==tired arms
Failed alternator==DNF
Plus, the PS pump is smaller and could be easily sheilded with a bit of aluminum or a soft reflective " heat jacket"
One. Class -- 2WD
mack73
Jason Wine
December 15, 2008 02:04PM
Certainly true Josh.
And since I'm going carbs, my Alternator is currently mounted where the AC was. But not enough clearance from the bottom of the alternator and the radiator so it's way down low. Something has to go to the back or stay on the bottom for ITB/Carbs.
-Jason
turoc
Ozgur Simsek
working on a Veedub
December 15, 2008 06:17PM
Josh Wimpey Wrote:
> wouldn't
> it
> > 94 Golf
> > www.Mack73.com
> being baked.
I ran 3 events so far without ps for various reasons and my arms never got tired. I do like running with a functional alternator however smiling smiley
mack73
Jason Wine
December 15, 2008 07:50PM
Yeah but did you have a 2:1 quikener in it? I don't think I'm manly enough to try it tongue sticking out smiley
-Jason
turoc
Ozgur Simsek
working on a Veedub
December 15, 2008 10:54PM
> like
> 94 Golf
> www.Mack73.com
Have you seen my forearms? grinning smiley
December 16, 2008 02:49AM
