nick the brit
Nick Taylor
1995 Subaru Impreza WRX
Re: EVO Project
March 17, 2006 04:10PM
Dave Clark - coming to LA?
marvellous!
Welcome to the dark side Dave!
Nick Taylor.
Knobhead.
Los Angeles, CA.
sagsert
Mustafa Samli
Gaylant VR4
Re: EVO Project
March 17, 2006 04:43PM
It was coming here in one piece until some asshole decided to declare 10 conatiners of cars as furniture. He got busted in LA. I had to get the car cut in half and import as used parts.
The Mirage is a Japanese built car with a US VIN, kinda difficult to find but they exist. It is the VIN, title and unibody donor.
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
EVO III GSR (Stolen)
Rallies are no place for traitors
Skye
Skye Nott
Xratty
Re: EVO Project
March 17, 2006 06:44PM
Hahahah two clips for the price of one
Furniture... nice one Homeland Security! It's an outrage that they would catch you, must have been one of those foreign owned ports.
www.rallyrace.net
Kirby
Kirby Read
1981 Volvo 242
Re: EVO Project
April 01, 2006 04:00AM
what year is that mirage mustafa?
sagsert
Mustafa Samli
Gaylant VR4
Re: EVO Project
April 01, 2006 08:08AM
95. That's the trick. If you have an intention to do what I am doing, that's the only year that will work. MAKE SURE YOU ARE GETTING THE REAR HALF OF THE EVO TOO.
Spare tyre well and rear subframe from the EVO has to be grafted to the Mirage and you will also use the EVO fueltank. After that it's all smooth sailing.
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
gilbrock
Eli Gilbert
91 Galant, 02 WRX
Re: EVO Project
April 07, 2006 02:30PM
moose, will that motor fit into a 91 galant? (the mirage one)...silly question I know but....
sagsert
Mustafa Samli
Gaylant VR4
Re: EVO Project
April 07, 2006 03:06PM
Not a silly question at all.
And the answer is yes, absolutely but you may want to consider getting the center diff and gearbox that mates with that engine aswell, not that a Galant one would not. I can help you source one if you need.
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
gilbrock
Eli Gilbert
91 Galant, 02 WRX
Re: EVO Project
April 07, 2006 03:07PM
This would be for a FWD Galant...
sagsert
Mustafa Samli
Gaylant VR4
Re: EVO Project
April 07, 2006 05:19PM
It will fit under the hood no problem, mounting brackets and engine mounts are identical. I don't have a FWD gearbox so i don't know if you can mount it to the engine without an extra challenge. OTOH, 4G63 blocks have the same transmission mounting dowel and bolt holes therefore it shouldn't be a problem.
What evil tricks do you have up your sleeve ?
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
gilbrock
Eli Gilbert
91 Galant, 02 WRX
Re: EVO Project
April 07, 2006 06:14PM
I'm buying the zero car from Seed 9 (the one that lost a wheel) to fart around with in Pstock. Should be fun, i'm getting it for a good price, and I assume the parts are reasonably easy to find and hopefully with some local expertise I can make it so it goes through an event without blowing up!
Eli
Re: EVO Project
April 12, 2006 03:13AM
Hey Mus,
Does this mean the Evil Possessed Gaylant is toast and we'll be seeing you in the left seat at Gorman?
sagsert
Mustafa Samli
Gaylant VR4
Re: EVO Project
April 13, 2006 10:25AM
Nope, the EvoL Posessed Gaylant is not kaput yet, the EVO will be a daily driver/recce car. However the Galant is getting a new shell soon, it already got a new engine.
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
Re: EVO Project
April 13, 2006 11:39AM
Did you get the Teeter car? That was a good buy if so.
sagsert
Mustafa Samli
Gaylant VR4
Re: EVO Project
April 13, 2006 12:25PM
I talked to Teeter yesterday again. I want to get the car but the drive from Phoenix to Portland is a bitch. If I can get the logistics arranged I want to get the shell from him. Jeff over at Chaste is going to OTR and may be able to trailer it back to CA and if that works out I will pick it up on the way back from RIM.
If anybody has any ideas or can help me get the car fom Portland to PHX I'm all ears and a check book.
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
gilbrock
Eli Gilbert
91 Galant, 02 WRX
Re: EVO Project
April 13, 2006 12:55PM
Did you see all the rust in that shell though Mustafa? I'd talk him down to $1,500.
Eli
