409industries Aaron Ekinaka Ultra Moderator Location: Southern California Join Date: 04/04/2008 Age: Midlife Crisis Posts: 17 Rally Car: 2001 Subaru Impreza 2.5RS |
DirtyImpretzel is at it again!
![]() Click here to watch: In this episode of the DirtyImpreza.com Project Rally RS build we cover the events from much of 2008. The 2001 Subaru Impreza 2.5RS was stripped down, seam welded, caged, painted, and re-assembled with a donor motor and transmission from another 2001 2.5RS. Big thanks goes out to everyone who helped out this year with the car. -Aaron http://www.dirtyimpreza.com |
DR1665 Brian Driggs Junior Moderator Location: Glendale Join Date: 06/08/2006 Age: Midlife Crisis Posts: 832 Rally Car: Keyboard. Deal with it. |
Car looks bad ass, Aaron. I am totally jealous of your progress.
I don't see gussets in the roof X and the rest of the gussets don't have inspection holes or the 1/2 moon notch at the inner junction. If you look at the FIA drawings the gussets have 1/2 moon notches on the inner V. How is someone supposed to inspect the welds if you can't see them?
gilbrock Eli Gilbert Infallible Moderator Location: San Diego, CA Join Date: 03/30/2006 Age: Midlife Crisis Posts: 307 Rally Car: 91 Galant, 02 WRX |
gilbrock Wrote:
------------------------------------------------------- > Look at some of the other welds/projects this guy > has done. I challenge you to find a better > rollcage welder. EVERY weld looks like a stack of > dimes. Flat doesn't matter does it ? Every cage, every weld has to be inspected before log booking. We don't just say "so and so welds good" so we don't need to look at it. I've seen some of the best pros around miss a weld or forget a needed bar. |
Ratfink Daniel Llewellyn Professional Moderator Location: SanBernardino Join Date: 10/14/2007 Age: Possibly Wise Posts: 26 Rally Car: I ride shotty in a huge truck |
Jon Burke Jon Burke Super Moderator Location: San Francisco, CA Join Date: 01/03/2008 Age: Possibly Wise Posts: 1,402 Rally Car: Subaru w/<1000 crashes |
heymagic Wrote:
------------------------------------------------------- > I don't see gussets in the roof X and the rest of > the gussets don't have inspection holes or the 1/2 > moon notch at the inner junction. If you look at > the FIA drawings the gussets have 1/2 moon notches > on the inner V. How is someone supposed to inspect > the welds if you can't see them? uh-oh.... Jon Burke - KI6LSW Blog: http://psgrallywrx.blogspot.com/ |
heymagic Wrote:
------------------------------------------------------- > I don't see gussets in the roof X and the rest of > the gussets don't have inspection holes or the 1/2 > moon notch at the inner junction. If you look at > the FIA drawings the gussets have 1/2 moon notches > on the inner V. How is someone supposed to inspect > the welds if you can't see them? The exact same gussets were used on another car that was log booked recently. I wasn't aware that this was going to be a problem. We can drill holes if necessary for inspection. Thanks for the tip. -Aaron http://www.dirtyimpreza.com |
mack73 Jason Wine Professional Moderator Location: Seattle, WA Join Date: 02/20/2006 Age: Midlife Crisis Posts: 448 Rally Car: Started a Golf... Never Finished It |
heymagic Wrote:
------------------------------------------------------- > Yes I have seen a cage or two logbooked with > similar gussets. It is an issue that is being > discussed amoung scrutineers. If you could drill a > hole or two I'm sure it would be appreciated. Gene, I don't think Dave made any holes in my gussets, so I'll need to drill some before you look at it. Do you have an example picture of what you will need? -Jason |
'there's a hole in my gussett, dear liza, dear liza'
'there's a hole in my gussett, dear liza, a hole' 'then inspect it, dear henry, dear henry, dear henry' 'then inspect it, dear henry, dear henry, inspect it' yes, i'm bored at work. Jon Burke - KI6LSW Blog: http://psgrallywrx.blogspot.com/ |
Jon Burke Wrote:
------------------------------------------------------- > 'there's a hole in my gussett, dear liza, dear > liza' > > 'there's a hole in my gussett, dear liza, a hole' > > 'then inspect it, dear henry, dear henry, dear > henry' > > 'then inspect it, dear henry, dear henry, inspect > it' > > > > > > yes, i'm bored at work. > > Jon Burke - KI6LSW > Blog: > 'Holy Shit!' @ 4:10 Frickin hilarious ! If a person could mebbe drill a 3/4 hole in at least one side of the gusset that should be adequate. |
Doivi Clarkinen Banned Junior Moderator Location: the end of the universe Join Date: 02/12/2006 Age: Ancient Posts: 1,432 Rally Car: 1980 Opel Ascona B |
Did I miss somewhere in the FIA rules where it says there must be holes in the gussets for the welds to be inspected? Because I don't remember seeing that. Could someone maybe quote that rule or post a link, please? I'm not trying to be an asshat, I just wanna know if I missed something because this is the first I've heard of it. Maybe it's a new rule I haven't seen yet.
In the case of X style door bars made with two V bars (as opposed to intersecting bars) I think it's a bad idea to have holes because the only thing holding the two bars together in a side impact is the gusset. There is not enough weld contact between where the two bends meet alone to hold them together. Mike Hurst likes to go on about how Nascar style doorbars are bad because if you hit a tree sideways the bars will bend far into the cockpit until they are in tension. He wants a bar to be in tension to prevent this. Yet he favors the two V bent bars for the X style door bars. These are not in tension! They will bend even farther into the cockpit in a side impact with a tree! You are completely relying on the gusset to hold those two bars together. That's why the gussets I use on that style of door bar are the same thickness as the tubing and have no holes. If you look at other cages I have done with intersecting tubes I have used thinner gussets with nice dimpled holes. And if you think I'm hiding unwelded tubes underneath closed gussets then I just don't know what to say. |
Doivi Clarkinen Wrote:
------------------------------------------------------- > Did I miss somewhere in the FIA rules where it > says there must be holes in the gussets for the > welds to be inspected? Because I don't remember > seeing that. Could someone maybe quote that rule > or post a link, please? I'm not trying to be an > asshat, I just wanna know if I missed something > because this is the first I've heard of it. Maybe > it's a new rule I haven't seen yet. > In the case of X style door bars made with two V > bars (as opposed to intersecting bars) I think > it's a bad idea to have holes because the only > thing holding the two bars together in a side > impact is the gusset. There is not enough weld > contact between where the two bends meet alone to > hold them together. Mike Hurst likes to go on > about how Nascar style doorbars are bad because if > you hit a tree sideways the bars will bend far > into the cockpit until they are in tension. He > wants a bar to be in tension to prevent this. Yet > he favors the two V bent bars for the X style door > bars. These are not in tension! They will bend > even farther into the cockpit in a side impact > with a tree! You are completely relying on the > gusset to hold those two bars together. That's > why the gussets I use on that style of door bar > are the same thickness as the tubing and have no > holes. If you look at other cages I have done > with intersecting tubes I have used thinner > gussets with nice dimpled holes. And if you think > I'm hiding unwelded tubes underneath closed > gussets then I just don't know what to say. Well Dave it isn't just about you ![]() |
