Shell Prep Q's
Posted by Daniel Buehler
hudson
Andrew McNally
Re: The dude I bought my compressor from..
February 20, 2009 04:31PM
SteveL Wrote:
> The Emglo I described would fit in the same space
> as the one
> you have now, You can hold a blower nozzle open
> and the damn
> thing will cycle off and on...
The space I made under my bench? It can't be the same physical size.
Mine will cycle on and off with a blower nozzle open smiling smiley Was pretty damn happy when I did that the first time!
> You can't have too much air...
Nope! Same with duty cycle on the ol welder! Mines only got a 20% duty cycle tho..
Andrew M
Onterrible
30ish
SteveL
Steve Leitch
Can't decide which to use...
February 20, 2009 10:52PM
heymagic Wrote:
> john vanlandingham Wrote:
> > And ya can't have too much hair.
> > John Vanlandingham
> > Sleezattle, WA, USA
> > Vive le Prole-le-ralliat
> > www.jvab.f4.ca
> Hair is highly over rated , you bohemian
> troglodite...
John has less hair than me... And I'm no troglodite,
just imagine the guy you don't want your daughter to
bring home...
SteveL
Seam Welding Q's
February 23, 2009 12:13PM
Allright... I am totaly new to welding. That being said, I have lots of scraps to practice on - including a legacy front clip.
In my couple of attempts to seam weld this past weekend, I ended up forming a bead on only one of the two sheets of metal. I'm talking specifically about the seams with a 1-2mm gap. What do I do to fill the gap and join the two pieces?
When the sheets are pressed together, I seem to be fine.
Any tips or tricks would be great. By the way, I am using a Lincoln MIG Pak 15 with Autoweld gas.
Thanks
Re: Seam Welding Q's
February 23, 2009 12:37PM
> fine.
> Thanks
> First rally car, a '94 Subarat is in progress...
I'm interested to hear from the experts on this too.
I found that if I hold it there just a little bit longer, let the weld pool get bigger, it will fill it in, then you can keep moving forward. Don't ever 'stop' moving, keep going back and fourth in a criss-cross motion, just move slower until the gaps are filled.
you can tell if you're going too fast, it'll start popping as if you're using the wrong wire speed.
At least that's what's been working for me and my toy mig.
Re: Shell Prep Q's
February 23, 2009 03:52PM
I have the same welder here.
Use .030" wire.
I can't remember the settings i used..i would probably use "b-4". I tend to use a little bit more heat than needed when seam welding, and "pulse" weld the panels. I find it lets the little bit of contaminants left in the seam burn out easier, i don't burn though, and i'm able to fill gaps better, because i can leave the pool in one spot longer, then stop for 1 second to cool, and go again.
Movement is key...
Re: Shell Prep Q's
February 23, 2009 06:16PM
> Use .030" wire.
pulse as in trigger on, trigger of, repeat?
I find it lets the
> and go again.
so, do you stop in the middle of the 'stich', let it cool for a second and continue the same stich? Because I was just trying to weld the stich in a single pass...
> Movement is key...
> Chris
February 23, 2009 08:24PM
Good job! you figured it out; the key to good welds is proper joint set up. (Or so I have heard) If you can't get clamps or vice grips in there, sometimes you can draw lapped pieces together with a little self tapping screw. After welding, take out the screw and weld up the hole. If you want to get fancy, airplane people use "Cleos", which are basically temporary rivets.
-Al
oh yeah, keep a ball-peen handy and just hammer those gaps tight.
Edited 1 time(s). Last edit at 02/23/2009 08:28PM by alkun.
February 23, 2009 08:30PM
> -Al
> those gaps tight.
ahh, that's what cleos are used for...seen them....knew what they did....didn't know what for.
hudson
Andrew McNally
February 23, 2009 08:49PM
> If you want
Al, thanks for turning me onto Clecos.. very cool!
Andrew M
Onterrible
30ish
Re: Shell Prep Q's
February 24, 2009 12:33AM
Yes.. Pull trigger...Zap....let it go....Pull Trigger...Zap....
You'll get the "rythm" down pretty quick.
In the end it looks better, is every bit as "strong", and you won't burn through as much.
Look at the pictures of the subie subframes on this forum..you'll get the idea.
Re: Shell Prep Q's
February 24, 2009 12:45AM
> Trigger...Zap....
> Chris
Sorry, but that's not quite right. While you can manually pulse the MIG gun and get away with it on thin sheet metal it's not every bit as strong. The welds on that subframe are a classic way to get welds that have cold laps in them. Strong MIG welds happen when the wire feeds into the leading edge of the weld puddle. Excessive weaving or pulsing make cold laps.
-Tim
Re: Shell Prep Q's
February 25, 2009 01:03AM
ok.. not every bit as strong.
But in the application it's not "structural" it's "supplemental" and i find it works much better, especially on the Subaru tin
Re: Shell Prep Q's
February 27, 2009 01:42PM
Chris, what did you do for prep befor you painted under the car?
And, Thanks for the tips on the seam welds. I'm finally getting results I'm comfortable with.
I'm re-thinking seam-welding the hole shell. I don't think my welding skills (two week old skills) are up to any difficult to reach or difficult angle welds... First car... we'll see.
Re: Shell Prep Q's
February 27, 2009 02:29PM
Nothing reaally. Just rough it up and make sure it's clean.
I did have my car outside in the driveway on it's side and powerwashed the crap out of it with some pretty serious chemicals.
I think they recommend a "sandblasted" finish
Re: Shell Prep Q's
February 27, 2009 02:36PM
Okay, You have to explain that... On its side? Like no rotissary, just on it's side?
