Volvo 164?
Posted by teamjlp
teamjlp
Justin Pritchard
Open class WRX( sold it before I driven it!), 2002 WRX PGT (now a parts car), 1966 Mini rolled.
Volvo 164?
February 22, 2009 09:20PM
I've found a 1970ish Volvo 164 almost rust free, and cheap, is this a ok candidate? Or am I better off with a 240 Volvo? I know it's got a heavy engine, but what about the rest, it is a stick.
Justin Pritchard
Re: Volvo 164?
February 22, 2009 09:39PM
> Justin Pritchard
One thing I like about the 240s is the nice weight balance.
It's engine is about 4" farther rearward than the engine in my Xratties relative to the spindle/center of front wheel.
And the Xratties are well balanced.
A 164 with the loooooooooooooooooooooooooooooooong CAST IRON 6 will not be as well balanced.
The 240 has pretty good rack and pinion steering.
The 164 you may as well drag a 2x4 against the wheel on the side you hope to eventually provoke the car into veering slightly in that direction.
The 240 has a nearly indestructible engine with 4 cylinders,
The 164 has a nearly indestructible engine with 6.
WHEN you decide to rebuild it one day, it will cost 50% more.
For no good reason (and don't compare stock motors).
There are incredibly simple brake upgrades for the 240.
Not so for the 164.
Thousand of 240s are waiting in the "Future Rally Car Spare Parts Depots" which some coarse bastards call "junk yards" so there';s lots of doors, hoods, front core supports, headlights, rooves etc, just the thing an aspiring hero needs.
I have seen 2 164s in the yards in the last 4 years.
164s just a funky old car.
The 240 is something you can progressively build up to a truly fast car whic,. if you're good, could take you into the top 5 at any event in the country.
teamjlp
Justin Pritchard
Re: Volvo 164?
February 22, 2009 09:51PM
So nothing swaps? It had four wheel disks, but that's all I know. Won't steer 'cause it's too heavy or another reason? I would likely swap motors for something lighter, I think you'd said a b23. Is the suspension the same as a 240? If no good I'll keep looking. Just can't find rust free cars in Ohio cheap, yet.
Thanks!
Re: Volvo 164?
February 22, 2009 10:31PM
I'm guessing they don't steer so well due to some 8,945,432:1 ratio recirculating ball setup that makes turning sort of like spinning the big wheel on The Price Is Right.
But I'm just making an educated guess on the mechanical end of it.
A little old lady who I used to do yard work for had a pristine 69 or 70 Volvo wagon with just 65k miles on it, if it hadn't been an automatic, I would have bought it from her. I did take it around the block once, and do remember the steering was slllllloooooooooowwwwwww. Man, that was 17 years ago now...
hudson
Andrew McNally
Re: Volvo 164?
February 22, 2009 10:35PM
> Thanks!
You can convert it to 240 brakes easily enough.
It won't turn, because it's got an absolutely terrible steering setup.. aside from the 4 links it's got a horribly slow worm and roller steering box with a ratio that's somewhere around 5 thousand turns lock to lock.
The 164 and the 240 share a lot of sheet metal.. but all the front end stuff is 164 specific and not the easiest to find.
All in all, they are neet old cars, but you will find you will have turned it into a 240 with harder to find front end sheet metal by the time you've finished your build.
Andrew M
Onterrible
30ish
Re: Volvo 164?
February 23, 2009 11:10AM
> Thanks!
Because the steering is closely related to this:
Re: Volvo 164?
February 23, 2009 02:20PM
So does the same go for the 144?
Does it have the crappy steering?
or is the 140 series more 240 like?
hudson
Andrew McNally
Re: Volvo 164?
February 23, 2009 05:35PM
> Michael LeCompte
Completely the same animal as the 164 steering wise.
The 140, 164 & 240 are essentially all the same from the firewall back. The 140 & 164 have essentially the same suspension and steering.
You could make a rack to fit for the 140.. although it has to be a damn small rack. Or you could convert it to a 240 front end (a lot of work).. or you could start with a 240.
Andrew M
Onterrible
30ish
teamjlp
Justin Pritchard
Re: Volvo 164?
February 24, 2009 06:45PM
Ok, no 164 then.
Edited 1 time(s). Last edit at 02/24/2009 08:19PM by teamjlp.
Re: Volvo 164?
February 24, 2009 09:26PM
teamjlp Wrote:
> Ok, no 164 then.
Justin, if you really want a 240 I have a friend in Richmond, VA that certainly can find you a cheap more or less rust free one.
Call (email is on the fritz just now) and I'll put you in touch.
> Edited 1 times. Last edit at Feb 24, 2009 by
> teamjlp.
Re: Volvo 164?
February 24, 2009 09:32PM
Why did you edit the subaru comment out?
mack73
Jason Wine
Re: Volvo 164?
February 24, 2009 09:41PM
> Feisty Peacock?
Oh snap calling him out
-Jason
Re: Volvo 164?
February 24, 2009 10:54PM
mack73 Wrote:
> > Feisty Peacock?
Well what did he say?
> 94 Golf
> www.Mack73.com
Re: Volvo 164?
February 25, 2009 10:50AM
Justin, my comrade from Virginia I mentioned somewhere is online now.
His name is "Fidel" aka Lawrence Knox aka Knox Motorsprout.
Get hold of this guy!
Fidel say hi!
fidel
lawrence knox
78" volvo 242
Re: Volvo 164?
February 25, 2009 11:08AM
i can defiantly help in finding a 240. i saw this post the other day and was waiting to see what y'all had to say before i posted.
i daily drive a 164, and would never think of prepping it for the dirt. it has a heavy front weight bias , the b30 is as heavy as a big block Merican motor. it does have a ton of torque but the crank will bend and snap above 7000rpm if you run some real compression. the stock trans has better ratios than a 240 and holds more power, but wear out quickly and all the bearing, ect are NLA. it would take a good amount of fab work to get a nice ratio T-5 compared to a 240. i have power steering in mine so its the same ratio as a 240, still to slow to have fun with. the front suspension would take a lot more work to strengthen it compared to a 240 also.
body part are hard to find for the 164, 240's (except 242's) are a dime a dozen.
lawrence knox aka fidel
knox motorspors
knoxmotorsports.us
