SteelSolutions William Timmins Junior Moderator Location: Redmond WA Join Date: 02/26/2008 Age: Midlife Crisis Posts: 648 Rally Car: 3 xr4ti/74 capri/02 bug eye |
thought I would post my project and what im doing to it I went to doo wops and got
stoked out of my mind and want to get it moving i have way to many resources to just let it sit next to my black xr this is going to be my first xr cage and mounting so input would be killer I plan on doing a new stand alone computer it it since theirs no motor harness in the car. I will throw in plenty of pics soon just need some sort of motivation!! and if any of you have tips on reinforcements I haven't seen yet that would be awesome too. I'm half tempted to move the motor and tranny back 4 inches with a new removable tunnel but that just an idea. TSSFAB.US No HYPE just parts!!!! And check us out on Facebook!!! ![]() |
Not worth the effort. Weight balance isn't too bad and the firewall would need modded to move anything back which is not legal in rally.
Reinforce the front strut tops somehow. Double skin, use your VW to Subaru mounts, or something of that nature. Mimic the Subaru WRC front top mounts. ![]() Grant Hughes |
------------------------------------------------------- > Not worth the effort. Weight balance isn't too > bad at 51F/49R empty, slightly better with 2 crew, and the firewall would need modded to move > anything back which is not legal in rally. > > Reinforce the front strut tops somehow. Ford didn't. I asked some guy named Blomqvist or Bloomintwist or something about that specifically. Double > skin, use your VW to Subaru mounts, or something > of that nature. Mimic the Subaru WRC front top > mounts. Yeah cause we're as bad as the current WRC losers. Have you had some problems with the top mounts? > > > Grant Hughes > www.nocoastmotorsports.net > Denver, CO John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
No I've not had any problems with the current ones, other than them rattling loose over time.
The paint is broken all around the base of the 'volcano' or whatever you want to call it. That's why I say double skin it, which I plan to do eventually before the next full stage rally if I still own the car at that point. Grant Hughes |
sweet that's what I'm talking about I wouldn't of thought of skinning down low! the
motor thing is just me trying to think of doing something because I can? if anything come to mind I want something crazy to stand out car fab wise. TSSFAB.US No HYPE just parts!!!! And check us out on Facebook!!! ![]() |
Independent rear suspension using a Toyota diff, custom adjustable arms, and Subaru uprights.
Convert the front to a better, more widely available upright with a good bearing setup, aftermarket brake and suspension support, and ability to easily make an adjustable control arm. Evo or Subaru are the first ones that would come to mind. Grant Hughes |
FREE!!! T5 camaro V8 so that is going in the red car
![]() ![]() TSSFAB.US No HYPE just parts!!!! And check us out on Facebook!!! ![]() |
------------------------------------------------------- > Independent rear suspension using a Toyota diff, > custom adjustable arms, and Subaru uprights. Why? > > Convert the front to a better, more widely > available upright with a good bearing setup, What's wrong with Sapphire knuckles? > aftermarket brake and suspension support, and > ability to easily make an adjustable control arm. > Evo or Subaru are the first ones that would come > to mind. You have too much time on your hands or too much money Grant. > > Grant Hughes > www.nocoastmotorsports.net > Denver, CO John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Doivi Clarkinen Banned Mega Moderator Location: the end of the universe Join Date: 02/12/2006 Age: Ancient Posts: 1,432 Rally Car: 1980 Opel Ascona B |
William, I've got tons of pictures of the Merkur Sierra Cosworth 4x4 I built for the Shraders back in 1998. No expense spared, lots of Group A parts, it was pretty cool. Probably $60,000 in parts went into that car. The pics are in analog form but you should come down to my shop sometime. You could get some ideas.
Thanks I will have to take you up on that, what did they do for a dash? I don't want
to do anything merker engine management wise so eliminating the dash and making a sheet metal dash is what I'm opting for I'm kinda set in that choice but if you know any tricks? Doivi Clarkinen Wrote: ------------------------------------------------------- > William, I've got tons of pictures of the Merkur > Sierra Cosworth 4x4 I built for the Shraders back > in 1998. No expense spared, lots of Group A > parts, it was pretty cool. Probably $60,000 in > parts went into that car. The pics are in analog > form but you should come down to my shop sometime. > You could get some ideas. TSSFAB.US No HYPE just parts!!!! And check us out on Facebook!!! ![]() |
They? Dave used a standard dash. Added to it what he wanted, cut a bit away where it was needed to clear the tubes.
Same as 99.9% of people---because there's nothing to be gained--no time, no speed, no ease of fab, no nothing to be gained in a car which HAS a dash in throwing that away, the making some ---any--replacement. In some 100% tube frame thing maybe then bending up some sheet metal is worthwhile, but the only thing more worthless in terms of investment of time and return of nothing in a car that already has dash is maybe doing door panels. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
> diff, > > custom adjustable arms, and Subaru uprights. > > Why? So you can have lots of spares, you don't have to worry about bending the rear beams, you have full adjustability instead of none, you have easy brake options, you have good final drive and limited slip options. > > Convert the front to a better, more widely > > available upright with a good bearing setup, > > What's wrong with Sapphire knuckles? I don't know anything about the Sapphire knuckle. Other than I don't have any of them, and other than getting a bigger bearing, it still leaves you with the fixed stock camber. There is excellent options however for brakes and suspension on the front of these cars already from JVAB. It's the lack of adjustability that's my real complaint and why we've focused more on making adjustable arms that use the stock upright, but could easily use the Sapphire as well. But if you ever hope to sell any parts to US folk, it has to work with US stuff out of the box. > You have too much time on your hands or too much > money Grant. It's time right now. I was just throwing out the ideas that we've had. Once I have some more money I'll start actually doing some of these ideas. We're already on the look out for a Merkur shell that we can cut up into pieces. I've got a live in engineer that wants to design and build things. Our current project is to find a new rear beam, reinforce it so I stop bending it, and fit the Supra diff into it. The adjustable arms will probably be prototype made in May or June and tested so we can run them in Idaho. Grant Hughes |
Yeah, what he said. It's not like the stock dash is especially heavy or anything. Just cover it in anti glare material. I did make a center console thingy to mount all the circuit breakers and whatnot.
john vanlandingham Wrote: ------------------------------------------------------- > They? Dave used a standard dash. Added to it what > he wanted, cut a bit away where it was needed to > clear the tubes. > > Same as 99.9% of people---because there's nothing > to be gained--no time, no speed, no ease of fab, > no nothing to be gained in a car which HAS a dash > in throwing that away, the making some > ---any--replacement. > > In some 100% tube frame thing maybe then bending > up some sheet metal is worthwhile, but the only > thing more worthless in terms of investment of > time and return of nothing in a car that already > has dash is maybe doing door panels. > > > > John Vanlandingham > Sleezattle, WA, USA > > Vive le Prole-le-ralliat > > www.jvab.f4.ca |
Lost a nickle bet to john on how heavy my radiator holder was to his aluminum one.
I said it was 8 oz heaver turned out it was little over 2 lbs at 3.5 lbs!! I think i can live with that ![]() ![]() Also did up some tower braces they turned out nice I'm really trying to find time for my two cars there needs to be more time in the day! ![]() ![]() TSSFAB.US No HYPE just parts!!!! And check us out on Facebook!!! ![]() |
