Ford sierra cosworth group A strut?
Posted by SNestor
Re: Ford sierra cosworth group A strut?
March 13, 2009 09:47PM
SNestor Wrote:
> Bilstein did not have the part number for my rear
> shock also! I have a 36N/mm spring on the rear
> shock.
That's OK, we know what it is, and we know if you kill them we can get steel bodied replacements easy.
> What valvings can you provide for a new 40mm
> insert without a Bilstein revalve? Can we ask for
> any valving from Bilstein for a new insert?
When I do new 40s I can ask for various length and any valving we want.
Do you
> make struts with Bilstein's P36 inserts?
No just the 40, 41 and 50mm inserts
Those P36 things seem very weak (if we are thinking of the ones VW boys get. Also the P36s are very short, maybe 155mm travel and i do 90% gravel.)
> Thank you for the fast replys. I am in Sault Ste.
> Marie Ontario. The "Soo".
I do have a good choice of the second hand 41mm in valving that would be fine for you.
March 13, 2009 10:14PM
Seb, I'm one of the ontario guys using Johns stuff. Johns stuff is really the only logical choice in rally suspension. I've used some very high end stuff and Johns stuff is just as good and in many cases better. Best value in suspension period.
SNestor
Sebastian Nestor
March 16, 2009 04:33PM
I am returned from a fast vacation!
** No just the 40, 41 and 50mm inserts. Those P36 things seem very weak **
OK. When Bilstein asks what insert I am sending for revalve someday, what do I write on the form?
Can you provide a new 40mm Bilstein insert with droop stoppers? I do not want to install droop straps.
