Re: anyone in the nw need a cage?
March 26, 2009 02:59PM
I've done about 5 cars worth of gussets including mine and have made maybe $150-175 and paid maybe $90 for the die and $60 worth of metal for around break even.
I personally just like the look of the cool guy gussets to the a and b pillars, the extra support/stiffness is just an extra benefit. With a car as puke worthy as a Merkur you gotta do all you can to make it look cool.
March 26, 2009 03:07PM
hahaha. Very true...
Where did you pick the die up from? 4x4 fab site?
March 26, 2009 03:24PM
I want to say it was called Miller Machinery or something like that. It was like 3 or 4 years ago. It had a bolt and I did a few with a wrench then said fuck it and ground off the threads and used a hydraulic press from then on.
So I just started to type Miller and realized it was actually Mitler brothers as I was typing. My memory works sometimes.
http://www.mittlerbros.com/punch__flares.htm
$95 now. I'd loan mine out if someone wanted to use it though probably.
March 26, 2009 04:13PM
Or!!!
for all you non-high roller guys further down Mittler Bros list are these where you use a hold saw first. Less than half the price.
Qty: $40.00
1300-001 1/2" Flare Tool
2Lbs.
Qty: $40.00
1300-002 5/8" Flare Tool
2 Lbs.
Qty: $40.00
1300-003 3/4" Flare Tool
2 Lbs.
Qty: $40.00
1300-004 1" Flare Tool
3 Lbs.
Qty: $40.00
1300-005 1-1/4" Flare Tool
3 Lbs.
Qty: $45.00
1300-006 1-1/2" Flare Tool
4 Lbs.
brianallmotor
Brian R. Barton
Mazda 323 BP-T
March 27, 2009 01:28AM
john, for us uber cheap guys--- what do you charge to borrow your hole-saw and flare tools??? =)
March 27, 2009 08:46AM
> Grant Hughes
> Denver, CO
Yes, but you welded them in with the dimples 'upside down'!
March 27, 2009 10:08AM
I know. I was so pissed at myself. I did the other side the other way I think. I'll have to go look one of these days.
March 27, 2009 10:36AM
starion887 Wrote:
> guy
> With
> all
> > Grant Hughes
> > www.nocoastmotorsports.net
> > Denver, CO
> 'upside down'!
But they look good from the inside....
Topi
Topi Hynynen
RWD Rollator GrF
March 27, 2009 10:57AM
The best source for best info is original homologation papers. The factories spend 100s of hours designing the best possible protection for best weight for any body style. These ideas can be copied to other cars.
Here's some from Mitsu: http://www.ralliart.com/GRN/homologation/x.html
Rigth now most improvements are side protection and A-pillar support. The reason is many insuried and deaths.
I don't see you got straight-up support at door. It doesn't help to weld brazes when windshield pillar is very slanted. It needs an extra support. See Mitsu pics.
NOTE: Many secondary support pipes DOES NOT need to be same thickness as in the US is common. It just makes the cage heavy. Again, see the factory cage pics.
Good luck with your business! We need more quality minded fabricators. Dave Clark and other good "old times" have to retire one day...
- RWD rocks -
March 28, 2009 11:21AM
heymagic Wrote:
> > 'upside down'!
Ya know, I never thoguht of that! You're a "glass half full" type of guy, Gene!
ob
OBrian Mason
Mazda 323 GTX, Merkur xr4ti
ob
Re: anyone in the new need a cage?
March 29, 2009 11:54PM
Thanks for the info. I agree that the factories know what each car needs better than most guys like me could ever figure out. I don't think that one manufacturer has all the best ideas though. I like to steal the best of them for my own financial gain, ha ha. That xr4ti in the picture is my car that doesn't need to be RA legal, and the a pillar support is in the way just to much. I didn't put sill bars either. They could be added later if I needed to. Thank to all of you guys for the good advice and support. Talk to ya later OB
open | download - new shop pics gravell spec 022.JPG (194.3 KB)
