krisdahl
Kris Dahl
Integra, Civic
Re: Building a 97 Civic that's a popular rally car but not in US
May 01, 2009 02:10AM
> Just to clarify my own thoughts...
> Do you mean it's harder to turn because the shaft
> is pulling or pushing causing thrust on the
> bearings inside the quickener making it harder to
> turn?
Yeah pretty much is what I think is happening. Either that or it is pushing on the universal joint and making it kinda hard to turn. I'm not totally sure actually. It feels like it is dragging a bit, and we haven't had time to figure out the exact reason.
>-PS is going in when the motor is swapped. Have a 99 SI rack(supposed to be 3.3
>LTL) and a 98 EX rack that is 3.6 LTL. One trick I am going to try is swapping
>an Integra pinion into the EX rack. Supposedly it works and ends up having 3.0 LTL
How hard is it without power steering?
Hrm that would be a neat trick if you could swap the pinion. I've heard that there are some swaps that work, and some that don't. Haven't tried myself.
Going to use the OEM belt-driven pump or using an electric?
Morten2
Morten
1974 Dodge Colt
May 01, 2009 10:56AM
The Colt has an unassisted rack and a welded diff.
It's a bit of a pain to parallel park on pavement, but on gravel at speed you can't even notice it isn't assisted.
gkd
George Doganis
Civic
gkd
May 01, 2009 05:16PM
Drivable but not raceable, as it would be a continuous fight.
> electric?
OEM(with a cooler), hopefully rebuilt/modified by Howe to combat the usual Honda P/S cavitation at very fast inputs.
George
Civic Rally Car
