Doivi Clarkinen Wrote:
> SEANT Wrote:
> > john vanlandingham Wrote:
> > > Jon Burke Wrote:
> > > > Odi at Feal Suspension put these on
> a
> > shock
> > > dyno
> > > > and said there's only a 15%
> difference
> > > between
> > > > full hard/full soft on the
> compression
> > > > adjustment....so I would assume
> the
> > rebound
> > > is
> > > > close.
> > > However they ARE adjustable which means
> boys
> > can
> > > diddle with a knob, and believe they're
> > doing
> > > important things.
> > > I believe it's called "the placebo
> effect",
> > and
> > > should never be discounted.
> > > We are all, after all, extremely
> sensitive
> > and
> > > finicky drivers and can all tell the
> > difference in
> > > handling from the slightest weight
> change.
> > > I for example can feel huge difference
> in how
> > the
> > > car handles after the co-driver takes a
> big
> > dump,
> > > so i make sure they don't wait to mid
> event.
> > > Even a big peeee changes everything.
> > > of course....
> > > > Jon Burke - KI6LSW
> > > > Blog:
> > > > 'Holy Shit!' @ 4:10
> > > John Vanlandingham
> > > Sleezattle, WA, USA
> > > Vive le Prole-le-ralliat
> > > www.rallyrace.net/jvab
> > > CALL +1 206 431-9696
> > > Remember! Pacific Standard Time
> > > is 3 hours behind Eastern Standard
> Time.
> > Obviously you have NO sense of feeling what
> so
> > ever JVL. Such huge changes that you are
> talking
> > of would make the car COMPLETELY UN-DRIVABLE!
> I
> > find that a rock stuck in a tire groove makes
> the
> > cars handling worthless and causes me to
> crash in
> > a fiery ball ! The co-driver once lost a hair
> from
> > his head and we chased suspension setting
> all
> > event try to get the handling back !!
> > As always IMHO
> > SEAN TENNIS
> > SEATTLE, WASHINGTON
> > SAAB 99, SAAB 850
> Fawk, JV hardly even notices when a wheel comes
> off the car...
When did JV start running wheels???
What are the rear springs rates? If they are too stiff the car will hop anyway. I remember following another RX7 on a transit one nite and we could see air under his back tires. He had just switched to Mazda Comp rear springs. The car was handling terrible. We told him what we saw, he went back to softer springs and started beating me again...
It is easy to get caught up in the adjustable 'frenzy' . On tarmac it is a viable action. On gravel where surfaces can change drastically every 200 feet not so much.
You might have someone follow you and see what exactly is going on. Maybe just one shock is failing or some such.
