DMS rebound adjust
Posted by brianallmotor
Re: DMS rebound adjust
January 19, 2010 10:55AM
Doivi Clarkinen Wrote:
> SEANT Wrote:
> > john vanlandingham Wrote:
> > > Jon Burke Wrote:
> > > > Odi at Feal Suspension put these on
> a
> > shock
> > > dyno
> > > > and said there's only a 15%
> difference
> > > between
> > > > full hard/full soft on the
> compression
> > > > adjustment....so I would assume
> the
> > rebound
> > > is
> > > > close.
> > > However they ARE adjustable which means
> boys
> > can
> > > diddle with a knob, and believe they're
> > doing
> > > important things.
> > > I believe it's called "the placebo
> effect",
> > and
> > > should never be discounted.
> > > We are all, after all, extremely
> sensitive
> > and
> > > finicky drivers and can all tell the
> > difference in
> > > handling from the slightest weight
> change.
> > > I for example can feel huge difference
> in how
> > the
> > > car handles after the co-driver takes a
> big
> > dump,
> > > so i make sure they don't wait to mid
> event.
> > > Even a big peeee changes everything.
> > > of course....
> > > > Jon Burke - KI6LSW
> > > > Blog:
> > > > 'Holy Shit!' @ 4:10
> > > John Vanlandingham
> > > Sleezattle, WA, USA
> > > Vive le Prole-le-ralliat
> > > www.rallyrace.net/jvab
> > > CALL +1 206 431-9696
> > > Remember! Pacific Standard Time
> > > is 3 hours behind Eastern Standard
> Time.
> > Obviously you have NO sense of feeling what
> so
> > ever JVL. Such huge changes that you are
> talking
> > of would make the car COMPLETELY UN-DRIVABLE!
> I
> > find that a rock stuck in a tire groove makes
> the
> > cars handling worthless and causes me to
> crash in
> > a fiery ball ! The co-driver once lost a hair
> from
> > his head and we chased suspension setting
> all
> > event try to get the handling back !!
> > As always IMHO
> > SEAN TENNIS
> > SEATTLE, WASHINGTON
> > SAAB 99, SAAB 850
> Fawk, JV hardly even notices when a wheel comes
> off the car...
When did JV start running wheels???
What are the rear springs rates? If they are too stiff the car will hop anyway. I remember following another RX7 on a transit one nite and we could see air under his back tires. He had just switched to Mazda Comp rear springs. The car was handling terrible. We told him what we saw, he went back to softer springs and started beating me again...sad smiley
It is easy to get caught up in the adjustable 'frenzy' . On tarmac it is a viable action. On gravel where surfaces can change drastically every 200 feet not so much.
You might have someone follow you and see what exactly is going on. Maybe just one shock is failing or some such.
January 19, 2010 02:18PM
I found that I could tell the change in handling of the DMS adjustments mostly compression, not rebound...
I use one setting for fast open stages and another for tight twisty and slow stages, surface conditions did not play into my settings. I guess I am sensitive or something, be careful not to hurt my feelings.
I got pretty good at knowing when a wheel departed the car too, When the co-driver asked me what was up I could say with confidence that we had lost a wheel, no question about it, no reason to stop and look.
January 19, 2010 02:59PM
I only stopped cause the wheel I sheared off was a real Saab Min-lite and a GOOD used tire.
Soon as we found that we continued (after arguing with dave to get into the car cause I was leaving---had to put it in gear and snatch the clutch before he actually got in)
January 19, 2010 04:47PM
Yeah,and then a few sideways corners later at nearly full speed, "Hey, this isn't so bad. Maybe we should put our helmets back on!"
