Exhaust swage?
April 12, 2009 02:35AM
looking to have some parts of my exhaust be semi-removable. There a tool out there to expand the exhaust parts for a slip fit?
Re: Exhaust swage?
April 12, 2009 04:16AM
These work a bit, depending on how much bigger you need to go.
Or take the pipes to an exhaust shop and have them do it on one of their big machines.
Re: Exhaust swage?
April 12, 2009 09:59AM
The tool that Carl shows works but tends to break easily if you only insert it part way into the pipe; it should be fully inserted. And it does not work too well (in my experience at least) with thick walled exhaust pipe. We have moved away from slips fits to flanges over the years; slip fits never seem to come apart well in a midnight service.
Regards,
Mark B.
Re: Exhaust swage?
April 12, 2009 11:48AM
> need to go.
Those expanders were only meant to straighten the old pipe under a car or a dent in the end of a new pipe. They do break fairly easily as they are a cheap cast iron in the fingers.
Slip ons (snicker) work ok, many teams use them with springs to hold together. There is less for rocks and such to bang off of. Leave the joint a bit loose and the spring tension will hold the seal at the bottom of the swage.
Flat flanges are easy, 2 or 3 bolt. Use a common flange and gasket such as a big block Chev at 3 holes and 2 1/2 in diameter. Ford and Chrysler used 2 holes and gaskets are available also in 2 1/4 and 2 1/2 in most part stores. Castlelated nuts help keep things from coming apart, keep the threads towards the back of the joint. I usually use flanges myself.
Ball and socket joints take up a little more room but afford better pipe flex and exhaust movement without cracking stuff. Spring loaded bolts work best.
The big trick would be to build a couple systems at once. I built spare catalytic converters for ACPs Evo while everything was new . Takes just a minute to unbolt and change.
If you wanted to make the trek way down here I would be happy to help you guys out for materials only.
Re: Exhaust swage?
April 12, 2009 04:26PM
> only.
Do those materials include beer?
Re: Exhaust swage?
April 12, 2009 05:55PM
Oh and one point on flange bolts: we use grade 2, never grade 5 or 8. They alwasy get corroded on after the rally car sits a while; 3/8" grade 2 bolts are pretty easy to just rip apart with a coupla wrenches. Ditto for using lightweight exhaust u-bolts rather than the heavey duty ones.
Totally different story on spring loaded nuts-on-bolts holding together ball flanges; grade 8 only for us. Makes them usable multiple times, and can be turned off with an impact wrench and flexy socket adapter without destroying the bolts. Always use some anti-seize on these to make them release a bit better.
Regards,
Mark B.
Re: Exhaust swage?
April 12, 2009 06:27PM
I like slip fit tube connections if the are really loose and held together with springs. Otherwise V-band clamps are the only way to go.
Re: Exhaust swage?
April 12, 2009 08:17PM
> I
> materials
> > only.
> John Vanlandingham
> Sleezattle, WA, USA
> Vive le Prole-le-ralliat
> www.jvab.f4.ca
No beer...'tis the drink of peasants. Rum, a proper refreshment steeped in history and approved by pirates everywhere ('ceptin maybe those holey ones in Somolia)
noypiesky
Donald Wong
1980 Toyota Corolla
Re: Exhaust swage?
April 12, 2009 08:57PM
What do guys think of these? http://store.summitracing.com/partdetail.asp?autofilter=1&part=DTC-60-912250S&N=700+115&autoview=sku
www.performanceoptions.net
open | download - dtc-60-912250s_w.jpg (9.9 KB)
Re: Exhaust swage?
April 12, 2009 09:28PM
They work, kind of pricey . The T bolts can strip or get damaged from rocks.
Re: Exhaust swage?
April 12, 2009 10:18PM
Those are V-band clamps. I use them all the time on the exhaust systems at work (Caterpillar). The are extremely strong. I usually turn them so that the bolt is up and out of the way.
mack73
Jason Wine
Re: Exhaust swage?
April 12, 2009 10:27PM
This was on my exhaust list as a possible joint - same issue as the summit one, but cheaper as it's agricultural designed http://store.airflo.com/casttcostfor.html
-Jason
Re: Exhaust swage?
April 13, 2009 09:23AM
I use V-bands in my exhaust, as is most of the other Denver based cars and I'll personally never use anything else. Sure a bit pricey, but these are rally cars, what's not pricey. Plus time and effort have a value too.
Re: Exhaust swage?
April 13, 2009 10:46AM
> 94 Golf
> www.Mack73.com
I'd spend the extra $14 and get the the stainless one. Way stronger and only needs one wrench ( deep socket) to take apart.
Re: Exhaust swage?
April 13, 2009 10:51AM
heymagic Wrote:
> joint -
> it's
> > 94 Golf
> > www.Mack73.com
But Gene, do you ever see problems with the SS bolts threads galling with heat and exposure? When SS otl threads start to gall, you are typically hosed, 'specially in rally service. Just wondering.
Mark B.
