Gear marking compound
Posted by Do It Sidewayz
April 28, 2009 01:19PM
Any "backyard" gear marking compounds someone could recommend.
i'm not sure i'll find the "real" stuff.
heard of people using White Lithium grease, or tooth paste!
Re: Gear marking compound
April 28, 2009 03:08PM
Prussian blue dye. You should be able to get it at any good auto parts store. I have a tube made by Permatex.
April 28, 2009 03:13PM
Whats this for? Do you coat the gears and then turn the box by hand to find high spots?
April 28, 2009 03:56PM
"good", and "auto parts store" should not be used in the same sentance.
i'll try Napa on the way home though...they are the best i've found.
April 28, 2009 05:09PM
Tim,
You use the prussian blue to see the gear tooth contact pattern.
April 28, 2009 08:46PM
How does it help? Is it for shimming the gears left and right to make them mesh better?
mack73
Jason Wine
April 28, 2009 08:50PM
> Feisty Peacock?
Tim, mainly used when setting up a rear end differential to ensure good tooth contact and long life.
http://www.differentials.com/install.html
-Jason
April 28, 2009 09:53PM
ahh, cool. Thanks for the link
April 29, 2009 02:10PM
Napa sucks just as much as everyone else apparently.
So?? White Lithium or Tooth Paste
April 29, 2009 02:30PM
> apparently.
> Chris
White lithium. Coat both sides of about 5 or 6 teeth in a row and turn at least a complete revolution of the ring gear both directions. Then you can see where the pinion redeposits the white lithium on the clean gear teeth.
April 30, 2009 09:15AM
White lithium worked...
but only after i tore the box open, found a completely broken Pinion gear, and missing teeth from the ring gear!!!
So much for the 4.44
Dropped in a 4.11 gear set, and changed my gear ratio also.
Still no idea what the diff is. Looks like it may be a cusco of some sort...
April 30, 2009 11:16AM
Well you can use a dab of White lithium on the end of a screw driver to reach in and pick up fragments.
> ratio also.
Might be better, I know Pat richard was saying sometimes he uses 4.1 if he needs some km/hr cause it sure ain't going do it with revs.
Hey Chris, you going help Dave Amor get his bushes in? They should be almost there and you still have the press tool and dingle ball hone (which I want back after Dave is done with it) Give him a call, would ya?
Thanks
> Chris
April 30, 2009 02:42PM
THe 4.44's break all the time. Even the Prodrive $700 allegedly strengthened (just look shot peened to me) ring and pinions break just as easily. I have stack of broken 4.44 R&P gears at my shop.
April 30, 2009 02:57PM
are the 4.11's better??
i figure with the super FLAT torque curve i've got, keeping it in the power band a little longer and using the torque instead of just spinning it up so quick might actually just be ok.
April 30, 2009 03:41PM
You're right, it may actually be better for your faster roads.
> Chris
