Gear marking compound
Posted by Do It Sidewayz
Re: Gear marking compound
April 30, 2009 10:07PM
Do It Sidewayz Wrote:
> Napa sucks just as much as everyone else
> apparently.
> So?? White Lithium or Tooth Paste
> Chris
Try a regular machine shop, not just ones that do auto stuff but ones that do production machining. Prussion Blue dye or 'bluing' is what you want.
April 30, 2009 11:53PM
Prussian blue and blue dye are two different things. I doubt if the dye will work very well.
Haztoys
David Rodgers
90 Mitsu truck ..And needing something new just not sure what..???
May 01, 2009 01:03AM
I'm going to pull rank here ..Kids
The blue stuff is wrong the white grease is wrong ... Can be used sure and has .. "I" never really could use the blue stuff ...And I'm fucking God to gear train .. Captain Gear Box ...Some know me here ..
There making the stuff out now ...Find a beat to snot Jeep ...Ask were the gear guys hiding..You may need shims they will have them .. I have boxes and boxes of them too.. I've got a box full of marking paste packs at the shop ...Get one with every new gear set .. Any Gear shop should have the stuff all over too..One pack should last you for ever... Can mail some real stuff... Find a Jeep OEM books from the 60's is ware the "only" complete and full info in writing is living ... All other books are off.. Heres one .. Before marking past .. We took red cement die and 90w .. We had a jar red die for years .. Just a table spoon of 90w.. add die to mix to paste goo.. small paint brush ..paint on paste goo.. did three diff's a week for ten years that way and had been done that way senses the 40's in real gear shops...Everyones shocked when they find this out..LOL.. Before that it was "red lead" and oil.. Ford used that on the Model A.... But thats nasty stuff..( I'm speaking of drops of oil here.. And table spoons of die .. Not much needed at all..Never drys out ever.. )
Diff set up can be voodoo .. Your off .002 it could and can cook ... Lots pull it off .. Lot do not .. You drop the ball gear set up wise .. Dollars burn..
Find help..
David Rodgers
Hazardous Toys inc
May 01, 2009 06:26AM
OK old man... lol
> here ..
You're Captain Gear Box Fucking God and you can't use prussian blue? Hmm, works fine for me. Or even white lithium in a pinch.
> Dollars burn..
Too bad you're not Captain Coherent Sentence because none of that made any sense. Kinda like a cell phone with bad reception and you're only getting bits and pieces of what the person is saying. But yeah, the red cement dye stuff works really well, too.
> Find help..
Um, yeah...
May 01, 2009 08:28AM
White lithium worked just fine here... You could clearly see what you needed (ok, maybe not super clear as using the "right" stuff, but clear enough that you new what was going on)
May 01, 2009 10:43AM
Concrete dye...I learn something new everyday!
May 01, 2009 10:55AM
David,
Well captain gear box.........I work at a Caterpillar dealer and set up quite a few gear sets that cost more than most cars. I use what Cat recommends, prussian blue.
Pulling rank.......hummmm.......I'm 39 with 15 years Cat experience and am a certified field service anylist. I also have a degree in diesel and heavy equipment technology and have been an instructor at the local tech school. I feel well qualified to recommend prussian blue as an efective gear marking compound.
