JVAB suspension install
Posted by Tom B
Re: JVAB suspension install
May 07, 2009 11:28AM
Doivi Clarkinen Wrote:
> Rob McFadyen Wrote:
> > I was going to use the subie top mounts as
> per
> > your advice. Haven't had a vw fail on me
> yet...
> > I'd like to keep it that way! I know nothing
> of
> > the subie mounts. Is there a difference in
> year
> > or can I just grab a pair off any impreza?
> Those
> > struts look like fun. John really does do
> nice
> > work.
> THe front ones are all the same but it's woth it
> to get the Group N ones (Might be the same as U.S.
> STi, I dunno) because they are made of harder
> durometer rubber and much firmer and not so likely
> to fail.
The Grp N are harder than the USDM Sti. you can check the durometer markings molded into the rubber.
May 07, 2009 02:27PM
> as
> > per
> me
> > yet...
> nothing
> > of
> in
> > year
> impreza?
> > Those
> do
> > nice
> > > work.
> it
> U.S.
> harder
> likely
> > to fail.
> rubber.
OK OK sure the GropeN rubber is harder, but aren't those Sub-a-arts like 3200lbs?
And have rip snortin, a rootin and a tooting powerz?
I really think for weeeeenie little low powered 2400lb Golves the standard reasonably fresh from the wrecking yard any Subie from 89 on top mount oughtter do just dandy.
And cost $5.
Five dollah, mang! Five dollah, make you hollar!!
> "this is certainly not a game for flyweights or
> ping-pong players-all arguments to the contrary"
> -C.B.
May 07, 2009 02:31PM
I've never run the Group N mounts, but probably should if you listen to all the interweb speak.
I just run reasonably fresh mounts from whatever i've got around.
Replace them if i find an issue, as i normally have the struts off for a regrease after every 2nd rally...sometimes sooner.
Only problem is when the bearings start going a little bit ronchy...but you can fix that up with some brake clean and clean grease.
May 07, 2009 02:49PM
> i've got around.
> Chris
Seeee!!!!!!??
Neeener neener!!!
And Chris is faster than all youse guys, to, so there.
5 dollah!
Hey Chris did Dave get holt of you about the bearing installer and hone?
May 07, 2009 02:58PM
well. plus i can generally get them for free off Subaru club guys who upgrade to the group N's and have the stock mounts for 7 km on them sittin in a box.
May 07, 2009 04:02PM
Sure, put $5 top mounts on your $1500 or even $5000 suspension. Now your top mounts are softer than the suspension and moving around, not letting the shocks do the work. Stock ones do fail (though the fronts aren't nearly as bad as the rear) and an entry fee is a lot more than the cost of what you saved on the mounts. The stock ones are pretty soft and old ones can already be partially sagging. Do what you want, just throwing some advice out there...
May 07, 2009 04:53PM
mack73 Wrote:
> Wow good looking stuff there Tom.
> John - how long of threads do you normally cut on
> the top of the front struts? it looks like Tom
> needs a bit more to get to the nylon portion of
> the top nut? The Brumeister strut tops I've got
> need quite a bit of length to get all the way
> through the bearing, the OEM length was barely
> enough to get a thread started.
> 94 Golf
> www.Mack73.com
I think John's stuff is setup a bit better, if you bring down your tops he can make sure you have enough clearance. The struts I used were my own, so I just have to deal with what I got cause we didn't cut the threads.
May 07, 2009 06:04PM
> cut on
> Tom
> of
> got
> way
> barely
> > 94 Golf
> > www.Mack73.com
Yeah, I make mine to the length needed for some kind of bearing--either the Subaru top---preferred--or a spherical bearing like I did for Robert "Rallymech" Service Nazi.
In Tom's case he had the truly beyond Sooooper Bitching Sellholm top mounts which are beautiful bet complicated parts with a spherical bearing like normal, but also a radial needle bearing, and a tall roller bearing and while it is slicker than shit, it costs length. His inserts were what everybody always starts with and those are cut at the top for the ultra-cheezoid "two circles of an old beer can and 5 BBs" OEM VW bearing which is maybe 4mm thick max.
The Sellholm top mounts really want their own top pin, and seeing the whole thing assembled I now know where we could shave off a coupla mm to get the nyloc engaged.
In Roberts case it was just making spacers to fill the gap between the 14mm VW pin and the ID of the 7/8" spherical bearing I use (7/8" being about .005 from 22mm which is what works Fords used, so big enough for Ford at WRC level in a 1230kg car, ought to be good enough for mere mortal Vee wee guys)
Clearly a big FAT 19-20mm diameter pin lives linger than a 14 x 1,5mm threader pin but the fat thang demands some sort of custom top mount and that costs ~~150+ bucks
Hence the suggestion of the Subie mounts---which naturally presumes one actually LOOK AT the junk yard ones and see if they're tip top shape. Plenty in the yards, no reason to grab the first car you see and its just 4 quick nuts to spin off to pull them in position.
By the way when you guys wonder why I say "Well it's about this much or so" on cost, look at this: last three or four Golves all had different configurations of the strut inserts, top mount pins and ears. That's why there's always some uncertainty in what the final bill will be.
It always depends on the particulars of the installation.
> __________________________________________________
> _________
> Demon Rally Team :: Fine Tuning
> RalleyTuned | Meister Gauge Faces | Spitfire EFI |
> Product Apparel | Techtonics Tuning
> Myspace or Facebook
> Next Event: Max Attack!!! Idaho Rally July 7-9th
> 2009
Lurch
Eric Burmeister
Mazdaspeed3 and Mazda Protege
May 09, 2009 02:08PM
NICE.
Lurch
Eric Burmeister
The west coast...of Michigan
May 09, 2009 06:24PM
Did you need longer axles for all that droop?
What rates and lengths are the springs?
What are the rear shocks? Off road dealies like bilstein 7100's?
May 10, 2009 12:00AM
The axles seem like they will be fine, testing will tell here in a month or so.
Rates are 250lb front 175 out back 14" springs front and rear
Rear shocks are from John, I have no idea what they are....prolly some offroad dealies
Rob McFadyen
Rob McFadyen
1989 VW GTI
May 15, 2009 09:50AM
Tom, I noticed that the new struts don't have the fancy little clip guy for the brake line. What are you doing about that? Are you just not restraining the line? Are you zip tying it to the strut? Forgive my ignorance, I'm going to be getting my new JVL's soon and I would rather not blow a brake line because I'm stupid. Any help or advice is appreciated.
Thanks!
May 15, 2009 02:41PM
zip ties will probably go on, I didn't even think of that, but it shouldn't be too big of an issue, I really don't see the need to zap on the brakeline holder up frontthey might rub against the tire on occasion but that would be about it I think
Rob McFadyen
Rob McFadyen
1989 VW GTI
May 15, 2009 02:44PM
Ok. Thanks!
May 15, 2009 08:42PM
i'am in no position to make an offer on your old set up... but if i were, and you were willing to part with such old setup, what would one seek for monies?
