JVAB suspension install
May 05, 2009 08:14PM
Not too rough, we had to make some slight adjustments to the subframe and A-arms to account for a bit more droop, but after clearancing and some minor reinforcement, everything is a perfect fit.
the lineup:
Bilstein rear on the left and a custom front on the right for a comparo to the JVAB goodness
We used our already pretty neat Selholm Tuning Strut bearings in conjunction with John's stuff for a pretty awesome setup.
rear tops are some cool stainless goodies
They fit real well into the back end
LONG!
Full droop is fully awesome
and the car sits off jack stands for the first time this year....some minor ride height adjustments and we will be ready for testing and tuning
Edited 1 time(s). Last edit at 05/05/2009 08:15PM by Tom B.
Re: JVAB suspension install
May 05, 2009 09:51PM
I seem to remember a couple guys used to rally with the same last name as yours....
Congrats on some major progress!! You are going to make Idaho aren't you?
Haztoys
David Rodgers
90 Mitsu truck ..And needing something new just not sure what..???
May 05, 2009 10:06PM
Good to see you get them on ..
Wow JV ... those are really nice .. hats off to you on those ..
David
Hazardous Toys inc
May 06, 2009 12:28AM
Lookin good Tom! Good to see its starting to look more car like and less shell like
Josh Wimpey
Josh Wimpey
Sneak the Golf
May 06, 2009 06:45AM
Nice B-Boys!
You will love the JVAB stuff. We have been loving ours since 2003 or 2004. No problems at all except that our stock ears have begun to wallow out from too many big jumps.
Can't wait for Rally Idaho... MaxAttack!!!!
One. Class -- 2WD
www.quantumrallysport.com
May 06, 2009 07:22AM
Gene, you start cutting checks and I am right back out there again...
We WILL be at Idaho no matter what.
You'd be surprised at how much work we really put into this car....still some significant work to do, but you gotta take solice in the little stuff that makes a big difference. Now, back to the wiring!
May 06, 2009 10:55AM
I got your check for ya....I'll be checking that car top to bottom in Idaho winking smiley
It'll be great to see you on stage again, been a tad boring of late.
Rob McFadyen
Rob McFadyen
1989 VW GTI
May 06, 2009 12:41PM
Very Nice. I can't wait till I get mine. It looks like I'm coming off a similar setup to what you had as well. What did you do to the subframe to get the axle to clearance?
May 06, 2009 02:07PM
The A-arms needed to be adjusted in the inner rear corner next to the bushing (the stamped metal just needed to be bent down a bit to allow for clearance at full droop).
And the subframe needed to be adjusted down about 1/4" on the passenger side where the front portion of the A-arm bolts up. I just used a bit of heat, a sledge and a long piece of DOM to make the necessary clearancing adjustments, then when I was done I put a bead on the seams to keep everything in place.
the average person probably wont need to do this, we had to because we used our fancy pants strut tops, Johns tops would've allowed the right clearance and you probably wouldn't have needed to clearance anything.
May 06, 2009 02:12PM
> clearance anything.
Next time you get some inserts, get them thru me and then we have about an inch shorter upper body for the same shaft travel, m'ky?
Ron McF and Ozgur and JoshieW got Ford 41mm inserts which have shorter bodies and same travel
Hey Rob!! What top mounts you using again???
> __________________________________________________
> _________
> Demon Rally Team :: Fine Tuning
> RalleyTuned | Meister Gauge Faces | Spitfire EFI |
> Product Apparel | Techtonics Tuning
> Myspace or Facebook
> Next Event: Max Attack!!! Idaho Rally July 7-9th
> 2009
May 06, 2009 02:17PM
oh yes, our inserts are a bit different than John's too, but the same valving now.
Hey john, the rear thingies are pictured up there and fit perfect.
toss me an e-mail back so I can give you more cashola too
Rob McFadyen
Rob McFadyen
1989 VW GTI
May 06, 2009 02:37PM
I was going to use the subie top mounts as per your advice. Haven't had a vw fail on me yet... I'd like to keep it that way! I know nothing of the subie mounts. Is there a difference in year or can I just grab a pair off any impreza? Those struts look like fun. John really does do nice work.
May 06, 2009 02:56PM
> work.
THe front ones are all the same but it's woth it to get the Group N ones (Might be the same as U.S. STi, I dunno) because they are made of harder durometer rubber and much firmer and not so likely to fail.
Rob McFadyen
Rob McFadyen
1989 VW GTI
May 06, 2009 02:59PM
Ok. I'll keep that in mind. Front Gp N STI mounts?
mack73
Jason Wine
May 06, 2009 03:12PM
Wow good looking stuff there Tom.
John - how long of threads do you normally cut on the top of the front struts? it looks like Tom needs a bit more to get to the nylon portion of the top nut? The Brumeister strut tops I've got need quite a bit of length to get all the way through the bearing, the OEM length was barely enough to get a thread started.
-Jason
