david amor david amor Elite Moderator Location: Stoney Creek Ontario Join Date: 03/22/2006 Age: Possibly Wise Posts: 458 |
Doivi Clarkinen Wrote:
------------------------------------------------------- > Rob McFadyen Wrote: > -------------------------------------------------- > ----- > > I was going to use the subie top mounts as > per > > your advice. Haven't had a vw fail on me > yet... > > I'd like to keep it that way! I know nothing > of > > the subie mounts. Is there a difference in > year > > or can I just grab a pair off any impreza? > Those > > struts look like fun. John really does do > nice > > work. > > > > THe front ones are all the same but it's woth it > to get the Group N ones (Might be the same as U.S. > STi, I dunno) because they are made of harder > durometer rubber and much firmer and not so likely > to fail. > The Grp N are harder than the USDM Sti. you can check the durometer markings molded into the rubber. Gone fishing |
david amor Wrote:
------------------------------------------------------- > Doivi Clarkinen Wrote: > -------------------------------------------------- > ----- > > Rob McFadyen Wrote: > > > -------------------------------------------------- > > > ----- > > > I was going to use the subie top mounts > as > > per > > > your advice. Haven't had a vw fail on > me > > yet... > > > I'd like to keep it that way! I know > nothing > > of > > > the subie mounts. Is there a difference > in > > year > > > or can I just grab a pair off any > impreza? > > Those > > > struts look like fun. John really does > do > > nice > > > work. > > > > > > > > THe front ones are all the same but it's woth > it > > to get the Group N ones (Might be the same as > U.S. > > STi, I dunno) because they are made of > harder > > durometer rubber and much firmer and not so > likely > > to fail. > > > > > The Grp N are harder than the USDM Sti. you can > check the durometer markings molded into the > rubber. OK OK sure the GropeN rubber is harder, but aren't those Sub-a-arts like 3200lbs? And have rip snortin, a rootin and a tooting powerz? I really think for weeeeenie little low powered 2400lb Golves the standard reasonably fresh from the wrecking yard any Subie from 89 on top mount oughtter do just dandy. And cost $5. Five dollah, mang! Five dollah, make you hollar!! > > "this is certainly not a game for flyweights or > ping-pong players-all arguments to the contrary" > -C.B. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Do It Sidewayz Chris Martin Junior Moderator Location: Toronto, Ontario Join Date: 01/15/2006 Age: Midlife Crisis Posts: 567 Rally Car: E-85 powered Impreza |
I've never run the Group N mounts, but probably should if you listen to all the interweb speak.
I just run reasonably fresh mounts from whatever i've got around. Replace them if i find an issue, as i normally have the struts off for a regrease after every 2nd rally...sometimes sooner. Only problem is when the bearings start going a little bit ronchy...but you can fix that up with some brake clean and clean grease. Chris |
Do It Sidewayz Wrote:
------------------------------------------------------- > I've never run the Group N mounts, but probably > should if you listen to all the interweb speak. > > I just run reasonably fresh mounts from whatever > i've got around. > > > Replace them if i find an issue, as i normally > have the struts off for a regrease after every 2nd > rally...sometimes sooner. > > > Only problem is when the bearings start going a > little bit ronchy...but you can fix that up with > some brake clean and clean grease. > > Chris Seeee!!!!!!?? Neeener neener!!! And Chris is faster than all youse guys, to, so there. 5 dollah! Hey Chris did Dave get holt of you about the bearing installer and hone? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Doivi Clarkinen Banned Professional Moderator Location: the end of the universe Join Date: 02/12/2006 Age: Ancient Posts: 1,432 Rally Car: 1980 Opel Ascona B |
Sure, put $5 top mounts on your $1500 or even $5000 suspension. Now your top mounts are softer than the suspension and moving around, not letting the shocks do the work. Stock ones do fail (though the fronts aren't nearly as bad as the rear) and an entry fee is a lot more than the cost of what you saved on the mounts. The stock ones are pretty soft and old ones can already be partially sagging. Do what you want, just throwing some advice out there...
Tom B Tom B Mod Moderator Location: Douche Canoe, WA Join Date: 02/27/2006 Age: Midlife Crisis Posts: 780 Rally Car: VW Golf |
mack73 Wrote:
------------------------------------------------------- > Wow good looking stuff there Tom. > > John - how long of threads do you normally cut on > the top of the front struts? it looks like Tom > needs a bit more to get to the nylon portion of > the top nut? The Brumeister strut tops I've got > need quite a bit of length to get all the way > through the bearing, the OEM length was barely > enough to get a thread started. > > 94 Golf > www.Mack73.com I think John's stuff is setup a bit better, if you bring down your tops he can make sure you have enough clearance. The struts I used were my own, so I just have to deal with what I got cause we didn't cut the threads. -Tom DemonRallyTeam | Fine Tuning | CTS Turbo & RP Turbos | RalleyTuned | JRM | Meister Autowerks Spitfire EFI | Product Apparel | JVAB Imports | NLS | AP Tuning | USRT Add us on Facebook | Next Event: 2013 Olympus Rally June 22-23 Olympia, WA |
Tom B Wrote:
------------------------------------------------------- > mack73 Wrote: > -------------------------------------------------- > ----- > > Wow good looking stuff there Tom. > > > > John - how long of threads do you normally > cut on > > the top of the front struts? it looks like > Tom > > needs a bit more to get to the nylon portion > of > > the top nut? The Brumeister strut tops I've > got > > need quite a bit of length to get all the > way > > through the bearing, the OEM length was > barely > > enough to get a thread started. > > > > 94 Golf > > www.Mack73.com > > > I think John's stuff is setup a bit better, if you > bring down your tops he can make sure you have > enough clearance. The struts I used were my own, > so I just have to deal with what I got cause we > didn't cut the threads. Yeah, I make mine to the length needed for some kind of bearing--either the Subaru top---preferred--or a spherical bearing like I did for Robert "Rallymech" Service Nazi. In Tom's case he had the truly beyond Sooooper Bitching Sellholm top mounts which are beautiful bet complicated parts with a spherical bearing like normal, but also a radial needle bearing, and a tall roller bearing and while it is slicker than shit, it costs length. His inserts were what everybody always starts with and those are cut at the top for the ultra-cheezoid "two circles of an old beer can and 5 BBs" OEM VW bearing which is maybe 4mm thick max. The Sellholm top mounts really want their own top pin, and seeing the whole thing assembled I now know where we could shave off a coupla mm to get the nyloc engaged. In Roberts case it was just making spacers to fill the gap between the 14mm VW pin and the ID of the 7/8" spherical bearing I use (7/8" being about .005 from 22mm which is what works Fords used, so big enough for Ford at WRC level in a 1230kg car, ought to be good enough for mere mortal Vee wee guys) Clearly a big FAT 19-20mm diameter pin lives linger than a 14 x 1,5mm threader pin but the fat thang demands some sort of custom top mount and that costs ~~150+ bucks Hence the suggestion of the Subie mounts---which naturally presumes one actually LOOK AT the junk yard ones and see if they're tip top shape. Plenty in the yards, no reason to grab the first car you see and its just 4 quick nuts to spin off to pull them in position. By the way when you guys wonder why I say "Well it's about this much or so" on cost, look at this: last three or four Golves all had different configurations of the strut inserts, top mount pins and ears. That's why there's always some uncertainty in what the final bill will be. It always depends on the particulars of the installation. > > __________________________________________________ > _________ > Demon Rally Team :: Fine Tuning > RalleyTuned | Meister Gauge Faces | Spitfire EFI | > Product Apparel | Techtonics Tuning > > Myspace or Facebook > > Next Event: Max Attack!!! Idaho Rally July 7-9th > 2009 > > John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Lurch Eric Burmeister Mega Moderator Location: Michigan Join Date: 02/14/2006 Age: Possibly Wise Posts: 307 Rally Car: Mazdaspeed3 and Mazda Protege |
Carl S Carl Seidel Mega Moderator Location: Fe Mtn, MI Join Date: 02/10/2006 Age: Midlife Crisis Posts: 765 Rally Car: 1993 honderp |
The axles seem like they will be fine, testing will tell here in a month or so.
Rates are 250lb front 175 out back 14" springs front and rear Rear shocks are from John, I have no idea what they are....prolly some offroad dealies -Tom DemonRallyTeam | Fine Tuning | CTS Turbo & RP Turbos | RalleyTuned | JRM | Meister Autowerks Spitfire EFI | Product Apparel | JVAB Imports | NLS | AP Tuning | USRT Add us on Facebook | Next Event: 2013 Olympus Rally June 22-23 Olympia, WA |
Rob McFadyen Rob McFadyen Super Moderator Location: Reston, VA Join Date: 08/06/2008 Age: Midlife Crisis Posts: 24 Rally Car: 1989 VW GTI |
Tom, I noticed that the new struts don't have the fancy little clip guy for the brake line. What are you doing about that? Are you just not restraining the line? Are you zip tying it to the strut? Forgive my ignorance, I'm going to be getting my new JVL's soon and I would rather not blow a brake line because I'm stupid. Any help or advice is appreciated.
Thanks! |
zip ties will probably go on, I didn't even think of that, but it shouldn't be too big of an issue, I really don't see the need to zap on the brakeline holder up frontthey might rub against the tire on occasion but that would be about it I think
BJosephD Brian j Dyer Elite Moderator Location: southern maine Join Date: 05/01/2009 Age: Midlife Crisis Posts: 381 Rally Car: 04 Rocky Mountain MTB... |
