Re: Fuel Pump Wiring?
April 01, 2010 01:28PM
i'm sure it has something.
The XDi likely has something to turn the coils on/off.
So treat the Fuelpump as a "coil".
Honestly i wouldn't loose too much sleep over it....i know that Gene is a tech guy...but the chances of someone every checking this...not very likely.
acrane
adam crane
corolla GT-yes
April 02, 2010 09:34PM
depending on your idle, your oil pressure could dip just enough, and often enough to turn your pump on and off, a lot.
I've got an oil pressure warning light that comes on at ~10-15psi? and it flickers at stoplights.
the stock toyota is a switch in the mass air flapper unit, as soon as the flapper moves, it turns on the pump.
"I put the hurt on dirt" - adam crane
http://CraneRallyCrew.com
corolla gt-s "Patches"
Op: S.S.
mack73
Jason Wine
April 03, 2010 09:53AM
> turns on the pump.
Yes I agree - so I've picked up a oil pressure switch that is rated for 7psi. I'm going to run the idle a little high (1000 -1200) so we'll see what happens. I'll have an override which I'll probably use for any time I'm not on stage.
-Jason
Chad Wallin
Chad Wallin
97 Chevy Cavalier
April 14, 2010 12:33AM
just a little more info. I just put in a Facet in my 02 and I am using a VW Fuel pump relay that I ordered from AutohausAZ. Here is a link - look at the 6th post down for the info. Very simple.
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,338470/highlight,wiring+electric+fuel+pump/
