Pin jack stands
May 29, 2009 03:01PM
I'm talking about building the actual stands. We need a how to like we've got for cage gussets and so many other useful topics here on Anarchy.
Okay, so let's see it Burke. I want pictures, drawings, dimensions, materials, angles, how long it took, etc. smiling smiley
Re: Pin jack stands
May 29, 2009 04:22PM
ha! ok...I'll get on it this weekend and upload all my shit. I don't know if I have the original diagram I sketched, but I can probably recreate it easily enough.
Re: Pin jack stands
May 29, 2009 05:22PM
So, did you stick with your plan, copied below from an old thread. Let's see some pics of everything. If you can put them on facebook, you can put them on here. smiling smiley
Design...I'm basically going to copy these guys:
http://www.motorsport-tools.com/index.php?main_page=product_info&cPath=56&products_id=632
For the sill:
11 gauge support plates
1 OD x .065 wall x .870 ID 1020 DOM Structural Round Steel Tube
For the Jack stands:
.75"OD 1020 DOM solid bar
'Support' (2" long, solid bar inserted/welded into support, which is welded to top of stand)
1 OD x .120 wall x .760 ID 1020 DOM Structural Round Steel Tube
for the stand and lower cross-bar support:
1-1/8 OD x .065 wall x .995 ID 1020 DOM Structural Round Steel Tube
23" high, 16" base. I'll probably put in the gussett too, but no fancy 'dish'.
Re: Pin jack stands
May 29, 2009 05:33PM
yup, that's about it...but the sill receiver I switched to 1"x.120wall for a tighter fit with the .75"diam pin.
The sill support plates were 5x2". The inside of the rear sills didn't need to be reinforced, it was much thicker than the outside metal.
stands turned out to be 24" high , but that's easily controlled by how much you cut off the bottom.
The angle of the top cut was 18 or 20 degrees...something like that. My 'notches' for the cross supports were ghetto.
pics coming...facebook only has a few, I"ll put them in some kind of order.
Re: Pin jack stands
May 30, 2009 03:22PM
I Ordered materials from www.allmetalsinc.com
4 piceses of the 1.25"x 6ft long...that gives you enough for each leg and the cross support.
Cut each 6 foot piece into 2 26" pieces, the leftover is your support.
2 ft of the .75"dia solid bar...cut into 4 even pices, 6" each.
32" of the 1x.12wall bar.....4 pices x 6" long (for receivers) and 4 pieces x 2" long.
Metal bandsaw....cut each piece at a 70 degree (from perpendicular). Weld the tops together:
1" hole saw, drill the top off perpendicular....weld the 2" piece of tubing to the top of it:
Insert the 6" .75"dia rod in...flush to the rear, and weld:
the 'gussetts' are 2"x1" triangles. weld accordingly.
______________--
for the cross support, just measure and cut accordingly....you can set your height however you want.
my ghetto notches...I just made some straight cuts on the band saw and then hit it with a grinder.
finished welds...now just cut the feet however you want...flush, etc.
I don't have pics, but I put little feet on the bottoms of the main tubes so they don't dig in. lots of options there.
Re: Pin jack stands
May 31, 2009 03:09PM
FEA coming soon. Mark misread my specifications and did everything in 1" tubing, but okay. The shear of the pin is the weakest spot anyhow... Now to find a band saw...
open | download - pinstand.jpg (88.2 KB)
Re: Pin jack stands
May 31, 2009 05:29PM
Or a chop saw, angle grinder, hacksaw, sawzall, torch, etc...
Edited 1 time(s). Last edit at 05/31/2009 05:29PM by Carl S.
Re: Pin jack stands
May 31, 2009 06:01PM
^^that's nice....and your gussets are prettier than mine.
Re: Pin jack stands
May 31, 2009 07:08PM
Actually, the severe angle is nearly impossible to cut with any of the methods you've listed there Carl. You can use a combination, like use the chop saw, then grind on it with an angle grinder and other such nonsense. A band saw is the easiest way to cut the angle probably...
krisdahl
Kris Dahl
Integra, Civic
Re: Pin jack stands
June 01, 2009 01:00AM
Yeah cutting the angles was a bitch. I made some wooden angle pieces on a mitre saw and clamped them into the chop saw--allowed me to get much closer to the acute angles I needed, although had to do a lot of touch-up with a grinder to get it consistent.
Shoulda used round tube for the adjustable height socket. Only real regret.
One socket on the car was off by 1/4" (perhaps wasn't level when we put it in or something), which also sucks. But overall works quite well.
Complete Gallery
Re: Pin jack stands
June 01, 2009 01:22AM
adjustable = key
I didn't event think of that. nice.
cblakely
Chris Blakely
'92 VW GTI 16v on MSnS-E
Re: Pin jack stands
June 03, 2009 09:26PM
Am I crazy or just missing something? why not triangulate the stand to give you a little more lateral stability on something less perfect than your shop slab?
http://www.ckrally.com
Re: Pin jack stands
June 03, 2009 10:51PM
> your shop slab?
like these?
bit harder to make (for me at least)
I can't find these for sale ANYwhere either.
My receivers have a slight downward angle, so the jack stands angle OUT just a few degrees for a little more stability.
Re: Pin jack stands
June 03, 2009 11:06PM
More to fabricate and not as easy to transport. smiling smiley
Re: Pin jack stands
June 03, 2009 11:11PM
I guess you could always put in a 3rd leg? just drop it straight down from the top? maybe at a slight angle? little to the left?
