basic diff choice question
Posted by Jon Burke
Re: basic diff choice question
July 02, 2009 11:44AM
I put 2 rallies on it. The before the 2nd i took it apart and re-stacked it, so it was a little "weaker". Everything inside looked very good and had very very little wear.
If i had to put it on Nasioc today..i'd put it up for $300 US.
July 02, 2009 12:26PM
Do It Sidewayz Wrote:
> I've also got a rear "mechanical" center section
> from a diff i could have up forsale as well. It
> was fantastic, and gets rid of the spider gears
> and makes the R160 alot stronger.
> Also got an STI 20KG center diff....but you'll
> have to use the "old" rear transfer case section
> to use this.
Hey Chris. What do you mean on the rear side of things? Is that like the Loyale Turbo style clutch pack rear diff that can go into the R160 cases with just a little machining.
We may be interested in the front and center. Maybe rear too. Package deal maybe?
July 02, 2009 12:39PM
well..actually..it might drop in..i've never tried. You'd have to use the 1:1 transfer gears at the very least.
it's the "old" (pre-98 centre diff).
July 02, 2009 03:22PM
$300? damned.....seems like a good dealio to me. For that price I might even be able to pick it up earlier than 'end of the year'.
I'm getting a nice commission check at the end of July, let me see if I can budget for it....just to confirm, this will fit in a stock 2004 WRX tranny?
Edited 1 time(s). Last edit at 07/02/2009 03:23PM by Jon Burke.
