Completely stupid question...
July 20, 2009 12:27PM
that i should know the answer too...but it's monday
If i'm replumbing brake lines, and using t-fittings.
Should i try and keep the "branches" of the t's as equal in length as possible? Or does it matter?
the OEM routing has got the left front with about 24" of tube, while the right front has 6 feet.
Edited 1 time(s). Last edit at 07/20/2009 12:28PM by Do It Sidewayz.
Re: Completely stupid question...
July 20, 2009 12:40PM
Doesnt matter.
July 20, 2009 12:41PM
> monday
> t-fittings.
> Chris
Don't matter, hydraulics is about unit pressure, and that's the miracle of it. Pressure is same units evereywhere it could be 1000 miles long.
Or not, pressure same on the working end and for that matter inside the pipe.
it's just at the working end we turn the pressure into work, or movement.
> Edited 1 times. Last edit at Jul 20, 2009 by Do It
> Sidewayz.
July 20, 2009 12:58PM
that's what i thought...but as i said.. it's monday...and drank too much by the lake at the cottage this weekend
July 20, 2009 01:44PM
Just make sure you use as much hardline as possible.
July 20, 2009 01:52PM
It's going to mate up to the OEM length flex-lines...which have been replaced with Stainless lines.
Just need to replumb stuff because of the Hydraulic Handbrake.
Finally getting rid of the stupid Hill Holder which has been serving as a "union" for the past 2 years, and putting the bigger master cylinder on it.
I'm not affraid to bend up some tube, and flare the ends.
Plus hardline is like $0.85 a foot
fancy pants flex line is how much?!?!
July 20, 2009 02:19PM
> Stainless lines.
> it.
> the ends.
> Chris
Ok good, I've seen some real dumb ideas of running braided stuff and even dumber when they run -4.
July 20, 2009 03:00PM
I run -3 teflon braided in my entire system.
I've seen hard lines break and get beat up, especially near the handbrake areas.
But yes, it is more expensive for sure, but really easy to work with and way easier to do the whole car.
July 20, 2009 04:01PM
The reasoning behind it is compliance in the lines. They flex and expand when you press on the pedal, causing it to feel weird, and I suppose it probably takes some pressure away from the calipers, too.
July 20, 2009 04:04PM
I'm sure if you were using some weird line or rubber you'd get flex in the line.
My brakes feel rock solid with teflon braided lines throughout.
July 20, 2009 08:10PM
> lines throughout.
Mine are rock solid with the STEEL TUBE and cost maybe $18 to plumb.
Always do things for advantage, and I can't imagine what advantage to you by running Aeroquip all over the place.
I sure can see an advantage to the guy you bought it from!
> Grant Hughes
> Denver, CO
July 20, 2009 08:33PM
Wow. I must have been getting really ripped off for the hard fittings I did buy because mine came to way way more than $18. I was going to do all hard fittings, then watched a friend plumbing his and having a little of a pain in the ass and having to spend time doing all this crap with getting the flaring right etc. Around the same time I saw one of the top US Group N cars and they'd done all braided because it was easier. I'd already made all my own braided lines so I already new how easy it was.
Just looked, the hard line was 33.70 for 20 ft of 3/16" from Summit.
I spent around $115 total on fittings for hard lines and around $400 for soft lines and the soft line. So we can say it was about 2.5-3 times the cost, but a differential I was willing to pay personally.
I spent a total of $2845.70 on my entire brake system, including a few items that ended up being waste. I've traded most of that waste and gotten more value than I paid for them more often than not.
DirkaDirkaJack
Jack Russell
phil's GTI
July 21, 2009 12:08AM
it is a myth that not using hard lines gives you a soft pedal. maybe it was true 50 years ago, but not with the braided lines of today. if you have a soft pedal its because you suck at bleeding.
and John, you don't have to use aeroquip, you can use cheap ass parker fittings.
July 21, 2009 12:32AM
Well duh.
Parker-Hanifin, Weatherhead whatever. I was commenting about the cost, approx 20 times as much just for the HOSE, vs 3/16 steel tube at Schucks, or Auto Zoo.
Just becuase somebody else pee pee'd awy hundreds and hundreds of dollars isn't a reason to suggest iothers should be equally profligate when there is no know advantage to using flexible aero-quip/earls/whatever teflon stainless braided STYLE hose to connect fixed pars.
The master cylinders are fixed, the handbrake master ain't moving, the bulkhead unions where the flex hoses affix arent moving, so I fail to grasp why I need flexible hose---of any sort---running between fixed parts and positions.
July 21, 2009 01:43AM
> you a
> but
> have a
> can
> Well duh.
> or Auto Zoo.
> John Vanlandingham
> Sleezattle, WA, USA
> Vive le Prole-le-ralliat
> www.jvab.f4.ca
Wow.
I fully agree with you. grinning smiley hahah
