well, its about goddamned time!! (cage pics)
Posted by Jon Burke
Re: well, its about goddamned time!! (cage pics)
August 08, 2009 01:45PM
Gotcha. In the FIA rules the V in the rear of the car is only allowed if you have a V in the roof. V in roof is allowed either direction.
August 08, 2009 01:54PM
EricW Wrote:
> Reason I ask is that the V configuration in the
> roof requires an inverse V in the rear backstays
> to support the single stress point in the main
> hoop - at least in NASA rules.
Its actually the other way around....IF you want to do a 'V' config in the rear backstays, then you HAVE to have a V config in the roof
3.5.2 Diagonal Members between the Backstays
A minimum of one diagonal shall be placed between the
backstays. See figure 3.6.2-7.
Two diagonals may be placed in the plane of the backstays in a V
configuration as in figure 3.6.2-8 (based in FIA figure 253-22) if a V
configured roof reinforcement as in figure 3.6.2-8 is also used.
but to answer your question, yes, i'm building to NASA specs...which, is overbuilt for Rally America.
August 13, 2009 03:08PM
DONE! I'll put more pics up this weekend. 3 weeks and 3 days...not bad. Hoche came by and gave us the thumbs up...logbook on its way!
