mack73
Jason Wine
Re: My build log.
August 24, 2009 12:00AM
urr Wrote:
> i find it funny how the evo forum kids think
> that's good fabrication! No offense but it looks
> like it was hacked together with steel scrap from
> a shipyard by a one-eyed drunken sailor!
> Designing fancy parts in Solidworks doesn’t mean a
> lot if you make them with angle grinder and stick
> welder!!
> Not to put form over function but good looking
> welds are “usually” better welds.
> A+ for effort though….
> Andew
Eh don't worry about this Tim. Everything that has been done on my build (minus the cage) has been with the following tools: hammer, haxsaw, 6" vice, drill press, 110v MIG and an angle grinder. No fancy brakes, bandsaws or lathes. Some of it looks like hell, but it will get the job done smiling smiley
-Jason
Edited 2 time(s). Last edit at 08/24/2009 12:01AM by mack73.
Re: My build log.
August 24, 2009 02:23AM
> looks
> from
> mean a
> stick
> > welder!!
> looking
> > Andew
> 94 Golf
> www.Mack73.com
> Edited 2 times. Last edit at Aug 23, 2009 by
> mack73.
Thanks, but he doesn't bother me. He can say what he wants about my work, or how I do it.
How's your car coming along? (ps, what were your original posts? grinning smiley haha)
Re: My build log.
August 24, 2009 06:12AM
What are you talking about? Those are exactly the same tools I used to build your cage! tongue sticking out smiley
(OK, not really...)
Re: My build log.
August 24, 2009 10:13AM
Doivi Clarkinen Wrote:
> that has
> been
> vice,
> (OK, not really...)
And an axe..don't forget the axe.
Re: My build log.
August 24, 2009 01:58PM
hahahaha, When all else fails, cut the tubing with an axe, hahaha.
cblakely
Chris Blakely
'92 VW GTI 16v on MSnS-E
Re: My build log.
August 24, 2009 02:40PM
don't forget the ford tool! all important in race car fabrication smiling smiley
http://www.ckrally.com
Re: My build log.
August 24, 2009 04:53PM
> Everything
> > that has
> has
> > been
> haxsaw, 6"
> > vice,
> grinder.
> exactly the
> > (OK, not really...)
Oh yeah. Dull axe.
Re: My build log.
August 24, 2009 04:54PM
> car fabrication
That's used for bending the tubing.
Re: My build log.
August 25, 2009 05:47PM
I usually take the tube and whack it over one of these trusty tools:
much more cost effective than one of dem hammer things you rich guys gots
Re: My build log.
August 25, 2009 07:53PM
Re: My build log.
August 25, 2009 08:13PM
I don't know what the deal is. looks good to me and those welds are not that bad
at all I have seen some cars hit the stage that should be pulled out and crushed
Also you know mig hard wire is not considered a structural weld anyway! it
deposits more weld than can be layed in its root any one that is good with a stick
and dual shield knows what I mean
so keep it up man
Re: My build log.
August 25, 2009 11:10PM
> so keep it up man
> http://www.tssfab.us/ eBay Store
I'm going on the guess that he was either giving me shit, or trying to provoke me. I'm going with the former.
When are you free? You should stop by sometime to check it out in person!
Re: My build log.
August 26, 2009 12:04AM
The little inside upper corner gussets on the half lateral
More weight saved! Here are all the pieces that reinforced the rear seat belts/mounts
Here is the entire pile
For those who are curious, the break down is this;
Each E brake rear cable guide was 2.9oz (2)
Each upper rear spring was 5.1oz (2) [one of mine was 4.7, but as you can tell from the pic... it didnt cooperate....]
Each frame rail upper 4 link mount was 5.9oz (2)
And then the seat plates were 17.3oz, 15.5oz, and 21.7oz
Total savings: 5.12 pounds... It's not super impressive but it didnt take that long to do, and anything to offset the cage weight helps
It lived here
And all the big holes on the frame rails are covered with these little thin discs
Re: My build log.
August 30, 2009 04:39PM
The 4 link channels
It's obviously not yet done, but its about 3/4 of the way there!
The new panhard rod, heim on one side, stock bush on the other
Re: My build log.
September 02, 2009 10:25AM
Go Dazey, Go!
You win the "go get it" prize for hardest working DIY rallycar. If all goes well you and I will have a 2-liter grudge match at Doo-Wops this year. (uglyvolvo is coming along.) Keep it up.
-Alberto Gordo
