NBS2005 Jeff Rivera Professional Moderator Location: Toronto, ON Join Date: 01/31/2006 Age: Ancient Posts: 54 Rally Car: 1993 Mazda 323 |
well John i think im going to remain steadfast with the XR4TI and see where it takes me. Once i get myself out to Idaho, well start of some kind of process. I plan on volunteering for the next local rally event. Been in touch a coordinator out of mountain home for the idaho rally.
has anyone given any thought to old toyotas? They seem similar to the old datsuns. Been since i have rarely seen any im assuming there is a reason. Flimsy body? Not looking to go for it but just curious in the spirit of the thread.
First Rally: 2010 First RallyX: 2004 (a bunch) Driver (0), Co-Driver (7) Organizer (3), Volunteer (3) Cars Built (2.5), Engines Blown (2) Cages Built (0) # of rotations (3.5) Last Updated, Apr 9, 2023 Edited 1 time(s). Last edit at 09/12/2009 11:48PM by Gravity Fed. |
Dazed_Driver Banned Ultra Moderator Location: John and Skyes Magic Love liar Join Date: 08/24/2007 Posts: 2,154 |
AE86 corolla's arent very good for tall people. I'm 5'10" and I lowered the floor and its STILL tight up by the roof bars... then again, mine ARE kinda goofy.
I dunno anything about the older ones, other then they're even harder to find parts for then the ae86's... so I wouldnt rally one. But thats my opinion Welcome to the cult of JVL drink the koolaid or be banned. |
as far as live axles go, what are some of the setups people are running?
I'm running a celica supra 7.5 rear axle for mine. Stock LSD, KAAZ gen 2 supra LSD fits in it, I can get a good selection of final drives, and the axles are much bigger then the 6.7 AE86 stuff.
Oh, bigger brakes too. Welcome to the cult of JVL drink the koolaid or be banned. |
Gravity Fed Wrote:
------------------------------------------------------- > any changes in the overall suspension design? > > ------------- > "The beatings will continue until morale improves" Alex 20 years ago when late 70s/early 80s Japonaise stuff was common as shit on the lawn, when it hit the wreckers, they'd pull the copper rads and often set the over in the crush now pile. The motors NEVER really died so no market for them---not with the Japanese Engine Import thing supplying clean 3 y.o. motors and boxes. Then, inexplicably the inscrutable Oriental bastids stopped making RWD cars and nobody knows why.....it just happened............. That said there are a liot of common things with them, nearly all: ~crappy recirculating ball steering with about 15-18 turns lock to lock new, 20-22 turns now, even if the did rack and pinion as Toiletta did a couple of years prior to the AE86, its slower than sheeeeut. ~tiny brakes from using 13" forever ~ gearbox ratios that make Xratty's seem ultra close. ~ small, flimsy suspension since it was a 78bhp grocery getter A hugely annoying tendency to copy eaxchother in each car generation and the critical last years virtually everything the Nipponaise sold HERE had these heads like Toiletta 22R, Ratsoon NAPS-Z, Misterbitchy G32, Maz-dog's little shitboxes a whole slew with SOHC and LONG fawkin rockers and valve angles nearly 60*or more included angle. Here: 22R ![]() Naps-Z ![]() Mitsu Colt ![]() Typical chamber; ![]() All these long rocker designs were all horribly intolerant of changes in cam base circle. Tiny change and the rockers were pointing wrong so cams became a huge problem---reduced circle re-grinds guaranteed bad guide wear, And those huge open chambers made making any half-un-lame compression difficult, and we all know that without lots of static compression, we can't go to cams with later intake closing cause later intake valve closing means the time left to make compression is less. (As an example, I did a Normal aspirated Cosworth YB 16v with intake valve closing around 80 degrees after BDC....think about it: normal method for finger compression is piston down at BDC, measure cylinder v + gasket v + chamber v ---for our example no dish or dome of valve reliefs---then run piston to the top and measure gasket v + chamber v + and deck v if the piston isn't flush. Then devide the one by the other and presto!!! Youse gots a whopping 11.5 compression motor. But remember it only goes 180 degrees from BDC to TDC and until that damn intake valve closes you are making zero compression. The 80 degree figure means the piston is damn near halfway up, so the corrected compression is a girly-manly maybe 9.8-10:1 max So there was problems making good snappy serious power out of the last of the Japonaise rwd powerplants. And of course, as usual we didn't get the good stuff easily like Nissan's copy of Ford Cosworth BDG 2,0 called the FJ20 Long and short of it, even if there were loads left around in the yards there's better choices to get more wallet friendly motors with LOADS of torque and that's what we want if we want to have fun and not be forced to buy true close ratio gearsets---a whole new can of worms with all older Jap cars. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. Edited 1 time(s). Last edit at 09/22/2009 06:25PM by john vanlandingham. |
so I wake up this morning with this text in my phone:
"So your pretty sure it worth me investing in the xratty?" The Anarchy has you, Alex. And yes I do if nothing else because it has HEADROOM. Acres of headroom. RX-7s suck for headroom. The day they make cages mandatory for the piddly shit I do is the day I switch back to a Golf, or go back to drag racing or something. The whole "Ford rallied them and wrote a book on how to put it together to rally" is an incredibly awesome bonus. Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. Edited 1 time(s). Last edit at 09/22/2009 04:45PM by Pete. |
im mostly in love with the budget aspects since a caged shell in sights for a fair enough price and the easy power product of a 2.3 turbo. I really dont think i care to mess with the heat production of a rotary let alone a turbo rotary. Ill leave them to my street tinkering or other uses. Plus, im 6'. Pretty much a directive on what i can fit into in the first place....
Plus i hate fords so i wont feel bad for smacking it into things. First Rally: 2010 First RallyX: 2004 (a bunch) Driver (0), Co-Driver (7) Organizer (3), Volunteer (3) Cars Built (2.5), Engines Blown (2) Cages Built (0) # of rotations (3.5) Last Updated, Apr 9, 2023 |
