Windshield removal
Posted by Do It Sidewayz
Windshield removal
October 07, 2009 10:28AM
Anyone have a good method to remove a windshield....hopefully without breaking it?
options other than the biggest/stiffest Alfa utility knife that i can find?
Re: Windshield removal
October 07, 2009 10:33AM
You need one of these.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200334173_200334173
And a whole bunch of patience.
I pay someone to remove my windshields unless they're already broken.
Keep the blade close to the glass and leave the old windshield sealer on the windshield frame.
October 07, 2009 11:05AM
I use this tool I got at Harbor Freight. Came with this spool of what looks like regular wire but is a few wires spun together and quite rough. Has a tool to push the wire through the glue, then two hand pieces to grip the wire. Work it back and forth as you move along, cutting through the glue.
I imagine a little heat from a propane torch would soften up the glue and make it a bit easier, but not too much as you don't want it to rebond right after it seperates.
When we lost the windshield at the hill climb in July, in order to get it out and minimize glass coming in we used a utility knife, a pair of welding gloves to wrap the wire around and a bunch of safety wire. Same idea, but since it's not serated you only make it a few inches to a foot before the safety wire will snap.
October 07, 2009 11:06AM
I love the google.
Here's the Harbor Freight one's instructions.
http://www.harborfreight.com/manuals/96000-96999/96339.pdf
October 07, 2009 11:43AM
I do like grant said but use guitar string, like a D or A string. They're thick enough and wrapped to provide some extra abrasion. Wear gloves, and I use a utility knife to cut through first so I can stick the wire through. First time I tried this I had the windshield out in 10 minutes by myself, no breakies. I dont know why everyone thinks windshields are a black art.
October 07, 2009 12:20PM
i've used both those types of windshield tools with no luck......
The guitar string type thing, i've always ended up cutting into the windshield...smashy
the other one i've had better luck with..but it's still really tough.
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
October 07, 2009 12:24PM
When I had the windshield taken out by a professional he used a blade that he attached to a sawzall motor. All the cutting was done from the inside of the car. He said that someone at their shop made it out of a putty knife and a sander.
The work went really quickly and he wasn't being super super careful. He used a utility knife to cut the trim on the outside and then lifted it out with a suction cup.
Here is a commercial version.
http://www.extractor.ca/
Edited 1 time(s). Last edit at 10/07/2009 12:27PM by Andrew_Frick.
October 07, 2009 12:27PM
Specific to Xratties, the Germans must have melted dpwn old worn out tarmac roads and applied thermo-nuc-u-ler heat to bond that rock hard shit in there..
I've talked with several installers over the years and any that had done Xratties HATED the job. They said normal 'Merikan or Japanese polyurethane sploogie stuff was no problem, but Xratty stuff was hell on earth.
My miserable attemps using piano wire, guitar string, real cutting wire, everything all failed miserably.
4 x4 straight thru worked OK then a hammer and GRINDER with 4" cup brush
October 07, 2009 01:08PM
one more vote for music wire. Infact, later tonight I'm going to snag the windshield and roof skin off a corolla...
Francois
Francois Poirier
Open class Laser RS (RIP), 242 GT on the way!
October 07, 2009 01:09PM
Exaclty what the guy who did my Olds had.
Francois
October 07, 2009 01:11PM
Stop a guy in a windshield truck.
Tell him you'll give him $20 to drop by your house and remove it for you. Most are employees and probably make less than that per hour.
Or tow it around with a 12er of Kokanee in the passenger seat and offer the same.
October 07, 2009 01:22PM
I used an OLFA knife. Use the black blades. Took an hour to get the front windshield out. I didn't harm the glass until I tried to force the plastic allignment clips out of the top corners.
The Black OLFA blades are the key - They are something like 10x sharper.
The rear windshield took less than half an hour. The difference was that I took a 'v' shape out of the urethane first. I didn't try to cut through it until I'd removed a good chunk of urethane. It seemed as though it would take longer, but it went VERY quick. The black blades are also a bit flexible - that saved me. I'm sure I hit the rear windshield once, but the blade just flexed.
Good Luck!
October 07, 2009 01:36PM
the rear windshield is a cake walk...you couldn't brake that thing if you tried....if i do...lexan it is.
RyanHuber
Ryan Huber
2000 Subaru Impreza STi
October 07, 2009 02:33PM
I tried to use that first tool on my car, got about half way down the first side and heard the little "snap" as I went just a tad too far the one way, cracked the inner layer. Got it out the rest of the way with a hammer and screwdriver...
As for the rear, after my car was rebuilt the glass guy used so much glue putting the rear screen back in, I couldn't get it back out with the tool. Going from the inside and then from the outside, I still couldn't cut all the way through the glue. Ended up using the hammer on it too... Though, after hitting it half a dozen times from the outside, I finally had to hit it from the inside to get it to break!
Ryan Huber
VA3AWD
October 07, 2009 04:13PM
> it is.
> Chris
See, and all this time I thought I'd learned something... Ah well... smiling smiley
