SEANT
SEAN TENNIS
SAAB 99, SAAB 96 850, SAAB 99T, SAAB V4
Re: Coil overs in an NSU 1000
October 10, 2009 12:56PM
Revolution Wheels maybe able to help, I had the off set, diameter, width, etc I needed for the R5 Turbo and they were able to help. It could be worth looking over sea's for options. Tire wise there are vintage tires available aside from racing tires, autocross etc..
It would be worth sometime an effort to look at gearing and figure tires in to this equation to get a usable set-up. Remembering that a peaky engine is harder to drive as far as staying in the power band in real world driving. Also that the bigger the wheel & tire package the greater the mass that needs spun up to speed, turned and stopped and will eat up torque and momentum ... Camshaft will effect use of gearing, tire/wheel run out will effect overall axle ratio and RPM drop when shifting ...
NSU were fast in the day, so should be great fun today.
As always IMHO
SEAN TENNIS KF7JJR
SEATTLE, WASHINGTON
SAAB 99, SAAB 850
SAAB V4, SAAB 99T
Edited 1 time(s). Last edit at 10/10/2009 01:16PM by SEANT.
hudson
Andrew McNally
October 11, 2009 11:24PM
> today.
> As always IMHO
> SEAN TENNIS
> SEATTLE, WASHINGTON
> SAAB 99, SAAB 850
Sean,
The Diameter of the 15" tires I've selected is nearly exactly the same as the tires that are on the car now (at most 1" bigger). I think the "ideal" tire would be a low profile 14" job.. but those are even harder to find.
I've always thought that the NSU typ. 67s (1000, tt, tts) look way under wheeled with 13" wheels.. they are small cars, but they aren't THAT small.
I don't believe that some light wide 15" 3 piece rims and low profile 15" rubber will be significantly heavier.
I'm also not aiming to make a really peaky motor.. if I'm going for that, I might as well figure out how to get a 180-200hp bike motor in the thing.
Andrew M
Onterrible
30ish
October 12, 2009 10:04AM
> Turbo.....
> As always IMHO
> SEAN TENNIS
> SEATTLE, WASHINGTON
> SAAB 99, SAAB 850
> Edited 1 times. Last edit at Oct 10, 2009 by
> SEANT.
Holy blu cheese! R5 turbo!!!! Wait a minute! Make with the pictures please.
-AL
hudson
Andrew McNally
R5 Turbo
October 12, 2009 10:37AM
> -AL
Al,
I've bugged him before for pics, AFAIR no dice smiling smiley
Come on !
Andrew M
Onterrible
30ish
Robin Fleguel
Robin Fleguel
Stanley Steamer
October 12, 2009 06:05PM
hudson Wrote:
> Ok, so here's your chance to know more about an
> NSU than you ever wanted to know.
> The suspension is quite modern for a late 50s???
> design..
> My thoughts at the moment:
> Re-design front subframe with a coil over that
> goes to the unibody. This will lighten the
> subframe up a lot as it wont be seeing the same
> loads, my plan is to put a strut between the two
> top mounts and lighten the heck out of what's
> there now.
> Since the rear already loads the unibody, my plan
> is to keep the same rear suspension, but convert
> to a coilover in a good spot
> JVL, anyone.. comments, questions? The rear looks
> a hell of a lot like an XR4TI or a BMW.
> Andrew McNally
> Hamilton, ON
> 29
Hey Andrew,
Have you tracked down the guy with the TT that was at Targa Newfoundland - I think he's from Pickering.
Robin
hudson
Andrew McNally
Targa TT
October 12, 2009 06:16PM
> Pickering.
> Robin
Robin,
No, but I have met the guy who sold him the car. There's a surprising amount of them around when you have your ear to the ground.
I am going to pick up another 1000 just over the boarder if all goes well this weekend. It's a much needed parts car and has totally rotten floors.. so I'm going to do the body drop on that car and the shell that I've got now will be left intact (it's got nice floors winking smiley
Cheers,
Andrew
Andrew M
Onterrible
30ish
JonArmstrong
Jon Armstrong
Rallycross Civic
October 12, 2009 09:49PM
hudson Wrote:
I think the
225/50-14 Toyo R888
http://toyotires.com/tire/pattern/proxes-r888
hudson
Andrew McNally
October 12, 2009 10:46PM
JonArmstrong Wrote:
> hudson Wrote:
> I think the
> but
> 225/50-14 Toyo R888
Those are roughly the same OD as the 15" ones I'm looking at, just a tad bigger..
My trepidations with going 14" are:
- Almost no companies are making rims for this size and many that were have stopped.. I just got word that Compomotive is dumping even there 15" line of 3 piece rims.
- How much longer will good choices of rubber remain in 14"?
Too bad there aren't more shorter 14-15" tires.
Andrew M
Onterrible
30ish
hudson
Andrew McNally
Being more clear on tires and wheels
October 12, 2009 11:41PM
hudson Wrote:
> > I think the
> job..
> > but
> > 225/50-14 Toyo R888
> remain in 14"?
I think the ideal tire OD would be around 21"... AFAIK you can only get that in a 13" tire.. the 15" tires I've found are shorter than those 14" tires and 15" tires & rims are way more popular (obviously).
With the Avon CR500s with an 8" rim, I can run 195/45 R15 for an OD of 21.8" a full inch shorter than those 14" toyos.
Andrew M
Onterrible
30ish
SEANT
SEAN TENNIS
Re: R5 Turbo
October 21, 2009 06:01PM
hudson Wrote:
> minute!
> > -AL
> Al,
> Come on !
> Andrew McNally
> Hamilton, ON
> 29
It's not looking pretty at the moment, I'd don't recall any photo's from the past I took ... I'll look around for some. Tony Lathom may have one he's ridden in it albeit 14 years ago with Vern Johnson at the wheel ...
If I snapped a photo in the current condition there would be a lynch mob at my door soon afterwards. Someone was asking me about it a month or two ago, one of the local rally guys. Adam Crane, caught me when I was in the back yard burning something on the BBQ.
As always IMHO
SEAN TENNIS KF7JJR
SEATTLE, WASHINGTON
SAAB 99, SAAB 850
SAAB V4, SAAB 99T
