It looks like there's a lot of people who know a lot about rotaries.. so I figured I'd ask here.
I had been trying to figure out how I was going to tackle the engine in my NSU.. I want to look at the possibility of putting in a mid mounted rotary with a transaxle. I know it can be done, but what I don't know is: How "compact" can I make a 13B or Renesis motor c/w alternator and say an air conditioning compressor ![]() Could anyone give me a safe ball park space that it would need to occupy? Also, I've heard the hype that the Renesis is a superior design.. has that been born out in reality? Does anyone have any experience here? Thanks for any and all info Andrew M Onterrible 30ish |
The accessories (including water pump) nestle NEXT to the engine not in front of it. You'd not going to make it any shorter than it already is.
The best/easiest/most likely to get mobile way would be to use a VW aircooled transaxle, given that adaptor plates/flywheels/starters already exist for that. There's also just a little bit available in the aftermarket for VW aircooled stuff. For a non turbo engine figure on needing to handle 140-160ft-lb of torque. The RX-8 engine is superior in many ways, but it's held back in others. It makes great power but there is little to be gained in porting because it is basically already maxed out. There's no provision for a distributor, although it APPEARS that an old style front cover and water pump will fit. (The gaskets interchange, and the RX-8 gasket is a neat one-piece rubber embossed metal one) Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. |
Pete Wrote:
------------------------------------------------------- > The accessories (including water pump) nestle NEXT > to the engine not in front of it. You'd not going > to make it any shorter than it already is. > > The best/easiest/most likely to get mobile way > would be to use a VW aircooled transaxle, given > that adaptor plates/flywheels/starters already > exist for that. There's also just a little bit > available in the aftermarket for VW aircooled > stuff. For a non turbo engine figure on needing > to handle 140-160ft-lb of torque. > > The RX-8 engine is superior in many ways, but it's > held back in others. It makes great power but > there is little to be gained in porting because it > is basically already maxed out. There's no > provision for a distributor, although it APPEARS > that an old style front cover and water pump will > fit. (The gaskets interchange, and the RX-8 > gasket is a neat one-piece rubber embossed metal > one) Pete, I was thinking about hanging the motor up front of the rear axle rather than behind.. so AFAIK, I would need a transaxle from a mid engine car, not a rear engined car. So maybe a porsche 914? My understanding is that it's difficult/impossible to mount a rotary transversly.. which, unfortunately would probably be ideal in my situation. I've been looking high and low for actual motor dimensions for either the 13B or 13B-MSP (Renesis) engines for some time now.. with no luck.. the internet is a wierd beast... loads and loads of info and you get used to finding just about anything. You see, I'm not trying to build a race car or anything like that.. I'm trying to build a really fun, reliable, retro car that my wife wants to drive instead of her car. I'm also into building things and if I can flog it at a track day all the better ![]() I want to ensure that I can get a rotary mid mounted and still have some kind of usable rear seats (if that makes any sense). If I go this route, I'd probably be looking for a low mileage Renesis motor as they appear to be what I'm looking for in an engine. Andrew M Onterrible 30ish |
heymagic Wrote:
------------------------------------------------------- > Any chance you could drop either a FWD GM and > trans , like a 3.1, 3.4, 3.8 ? Or maybe a Fiero > trans with a 3.1 or 3.8? Get the supercharged > version out of a Park Avenue... Or a Cobalt SS > Supecharged/turbo charged engine. Or a MR2 setup. I'm ruling out all Transversely mounted V engines, because I don't want to deal with the exhaust plumbing, the engine would come into the passanger compartment big time up high, there would be no CG or balance benefit, and something else ![]() A 4 banger is certainly a possibility... a transverse mid engine setup like the MR2 would in theory work, no CG benefit, but better balance.. I'd probably have to move the rear axle back a bit to fit the thing in without putting the engine too far into the cabin (not a big big deal).. Some sort of removable bulkhead could be devised so I could service the thing. I'm still stuck on a mid mounted rotary.. Things I like: - NSU was the first company to experience the (b)leading edge of wankel technology - I think I can get the drive line in and still put a dog and infant in the back seat - cg and weight balance are majorly improved. - I can use the back of the car as a trunk and engineer a crumple zone. Problems: Might have to move axle back, have to figure out how I'm going to service it. Andrew M Onterrible 30ish |
All locally sourced.. That will at least get me into the mockup stage.. it's looking like the dimensions will work out.. and I can't see why that combo won't work at this point in time. I have machinist contacts so if I ahve to fabricate a plate, shouldn't be the end of the world.. Have to look into if anyone has done this combo.
What's wrong with the motor that came in it?
I don't like the German penchant back then for domes and no quench pads, but according to some, I understand nothing so fuck me, eh? But a 1000cc OHC thing looks like it could be fun with minimal moderisation. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
------------------------------------------------------- > What's wrong with the motor that came in it? > I don't like the German penchant back then for > domes and no quench pads, but according to some, I > understand nothing so fuck me, eh? > > But a 1000cc OHC thing looks like it could be fun > with minimal moderisation. John, good point. I'm just making sure I've looked at all the options.. the car that I'm going to be working on is going to be a patch work quilt, so it's not pretty. Seems like ~1k will get me a good consistant heater, that aint so bad! ![]() Andrew M Onterrible 30ish |
Ted Andkilde Ted Andkilde Junior Moderator Location: Windsor, ON, Canada Join Date: 04/30/2006 Age: Possibly Wise Posts: 329 Rally Car: 1968 Mini |
Ted Andkilde Wrote:
------------------------------------------------------- > Hey Andrew > > I believe you can flip the ring gear to the other > side and run the VW box in a mid engined > configuration. > > I'd ask on the buggy sites. Ted all's youse gots to dos is stink back to Type 901 transaxle aka 911 and or 914 transaxle. In one a dem Portches its motor first, trans last, in da udder one its trans first and motor at the end. They differ primarily in where the shaft the shift linkage attches to emerges from the case.. I's actually looked at dis junk cause I was being talked to about, and had gathered the bellhousing to block adaptuer from Kennedy, and modded flywheel to stick a 911 5 speed into a Saab 96. > > t > > Pure mathematics is the enemy of every truly > creative man -- Sir Alec John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Doivi Clarkinen Banned Super Moderator Location: the end of the universe Join Date: 02/12/2006 Age: Ancient Posts: 1,432 Rally Car: 1980 Opel Ascona B |
Ted Andkilde Wrote:
------------------------------------------------------- > Hey Andrew > > I believe you can flip the ring gear to the other > side and run the VW box in a mid engined > configuration. > > Yes, indeed you can. In fact, the Viking IV research vehicle built by Western Washington University's Vehicle Research Institute (where I got my schoolin') used a VW transaxle with the ring gear flipped and a Mazda Rotory engine to set a class record at Bonneville. ![]() |
Doivi Clarkinen Wrote:
------------------------------------------------------- > Ted Andkilde Wrote: > -------------------------------------------------- > ----- > > Hey Andrew > > > > I believe you can flip the ring gear to the > other > > side and run the VW box in a mid engined > > configuration. > > > > > > Yes, indeed you can. In fact, the Viking IV > research vehicle built by Western Washington > University's Vehicle Research Institute (where I > got my schoolin') used a VW transaxle with the > ring gear flipped and a Mazda Rotory engine to set > a class record at Bonneville. > > Ok...that is seriously neat... |
