hudson
Andrew McNally
This is too easy, I must be missing something
October 16, 2009 09:55PM
Ok, so I've been thinking and looking and thinking (it's been hell let me tell you! <grin>winking smiley
It looks like I can take my NSU transmission and relatively easily turn it into a motorcycle transaxle c/w reverse and locker.
Check out this link and the general site, lots of cool NSU porn.
http://stefannsu.piranho.de/getriebe_nsu_tts.htm
My idea is to make the transmission have reverse and a straight through and leave the rest alone.. might need to do some modifications for bolting it to the bike engine.. but other than that it seems stupid easy (and cheap)
What am I missing?
Andrew M
Onterrible
30ish
open | download - IMGP2751.jpg (192.9 KB)
hudson
Andrew McNally
The motor that looks like it could be made to bolt up
October 17, 2009 12:30PM
Starting in around 1998 BMW started making a flat 1200cc water cooled 4 banger.. I think K1200 is the general designation.
It appears that if I loose the oil pan and gearbox.. a new oil pan could be fabricated to allow the two to mate. Location of the oil pump might be an issue. CCW rotation could be an issue. It doesn't look like the NSU R&P can be flipped without some work.
It also appears that if I lose the battery box, the whole thing will fit with some monkeying of the mounts.
Here's a picture.. does anyone have any thoughts?
Andrew M
Onterrible
30ish
open | download - Showing Removable Oil Pan and Bellhousing.jpg (127.2 KB)
open | download - 32534.JPG (26.6 KB)
Ted Andkilde
Ted Andkilde
1968 Mini
Re: The motor that looks like it could be made to bolt up
October 17, 2009 02:02PM
My gut feeling on a bike engined car is to simplify wherever possible Andrew. You've already got a lovely 6 speed sequential box that came free with your crotch rocket motor, putting anything in between it and your rear axle adds weight, complexity and additional driveline losses to the equation.
My vote is for a chain driven rear diff like the Taylor Race setup, or the Quaife, or to be cheap, convert an old viscous LSD (mitsu, etc) into a homebrew chain drive rig like DSR and FSAE cars all use (there's a three bolt mitsu pumpkin with LSD and halfshafts in my garage for free with your name on it). If you "must" have reverse, go with a converted starter motor with a a ring gear mounted to the diff, simple, relatively lightweight and isolated from the driveline. Viscous LSD's aren't the greatest LSD's but the self contained design lends itself well to chain drive conversion, no need to seal it up to keep the spider gears lubed, yada, yada.
A couple of pics for inspiration, one is the chain driven setup from MK engineering for a Mini, the other is a twin bike engined autograss car.
open | download - mkmini.jpg (171.4 KB)
Ted Andkilde
Ted Andkilde
1968 Mini
October 17, 2009 02:05PM
open | download - twin.jpg (181 KB)
Ted Andkilde
Ted Andkilde
1968 Mini
October 17, 2009 02:20PM
Is a you tube vid of electric reverse running on a conventional propshaft driven rear diff.
And pic below is a rendering of an electric reverse setup for a chain driven diff.
open | download - reverse.jpg (89.2 KB)
hudson
Andrew McNally
> equation.
I hear you Ted. My thought was to not buy the transmission or sell it if it came with the motor. I know I know.. why the hell would I do that winking smiley I'm not looking to race the thing and without the transmission on that K1200.. the flywheel / clutch are basically in the exact spot I want them to be.
I might rethink this a bit more as it turns out an LSD for my NSU transaxle looks like it's about 900 euros.....................
> yada, yada.
Yeah chain drive would make it easier no doubt. But I'd like to have the most "factory" ish feel when it's done.
Keep in mind I want my wife to drive it! Reverse is a must winking smiley
Thanks for the inspiration.
One guy has mentioned snowmobile engines.. but I'm having trouble with that concept.
Andrew M
Onterrible
30ish
Ted Andkilde
Ted Andkilde
1968 Mini
October 17, 2009 02:28PM
Well, how rough is your parts car?
If the external bits of the shell are salvagable and the underbody is rusty it might make a better candidate for a bike transplant with a semi-tubeframe.
A tuned standard NSU engine makes a pretty potent package as is, and you have a really nice rust-free shell. I know no-one ever thinks "resale" when building a project but a hotted up "real" NSU will be worth more to a collector/enthusiast than a "frankenNSU".
t
hudson
Andrew McNally
October 17, 2009 02:58PM
> semi-tubeframe.
> t
> Pure mathematics is the enemy of every truly
> creative man -- Sir Alec
Ted,
That's just it.. I've got a basically rust free 1000 shell.. which unless I swap some tags, will never be a true TT or TTS.
It however needs a lot of panel replacement.
The parts car I'm picking up tomorrow... it has a really rotten floor.. but looks like the panels are better than the non rusted one.
I don't think I could get my money out of either a faithfully built NSU or a modified one. (can you ever get your money out??)
So basically, I'm just looking at options to build a car that will be fun to drive, can be driven daily if you so choose, with usable space.
I'm going to try my hand at body dropping the parts car.. worst case scenario is I fuck it up royally and I take the panels and put them on the non rusted car. At any rate the parts car is nearly worth what I'm paying for the windshield (that I need) alone. So no worries smiling smiley
Back to the BMW motor mated to the NSU transaxle.. I get 120ish ponies which would be insane cash to build the NSU motor to. Looks like it will fit not just as well, but better. It's water cooled so I can have loads of glorious heat.. and if I wanted to turbo charge it for shits and giggles.. it won't be an issue.
One possibility would be to mount the bmw motor mid ship with it's gearbox.. and since it's shaft driven, I would just need to get a diff that made the wheels go the right way.
$1500 bucks right now would buy me a wrecked 2002 K1200RS with 130 ponies. With the nsu motor that would get me the right cylinder head.
Andrew M
Onterrible
30ish
hudson
Andrew McNally
October 17, 2009 03:03PM
I think that's a good solution to the problem.. but imagine parallel parking with that in a busy city. Seems like it could be funny smiling smiley
Andrew M
Onterrible
30ish
Ted Andkilde
Ted Andkilde
1968 Mini
October 17, 2009 04:18PM
Nigh on impossible in a tight city parking spot, but fine for jockeying about in the parking lot at the cone-derby, the paddock at a track-day or at the start line of the hillclimb though <g>.
But, as far as that goes, parallel parking any high strung car with a hot cam isn't going to be much of a treat.
And, while it's sweet (newlyweds are just so darn cute smiling smiley) that you want to have your wife be able to drive the car, the reality is women only tolerate our greasy, smelly, dirty old car habits because old cars are marginally less annoying than the philandering and boozing that we offer as an alternative. I'd just save up and buy her a Fiat 500 Abarth when they're available in a couple of years, peppy, cute, cuddly, reliable (as only a car with a warranty and an 800# for roadside assistance can be) won't fill up with exhaust fumes or spit fuel all over her -- she'll love it.
t
Ted Andkilde
Ted Andkilde
1968 Mini
October 17, 2009 04:32PM
Hmmn, just going back through the whole deal -- what sort of HP and torque does the K1200 put out?
edit: I heart Wiki-pedia...
Power 163 hp (122 kW) @ 10,250 rpm
Torque 94 ft·lbf (127 N·m) @ 8,250 rpm
Compare with the #'s you were expecting from the tweaked NSU mill.
For some strange reason I had it in my head you were looking at using both the bike gearbox and the car gearbox in parallel -- I didn't realize you could separate the bike box.
How sturdy are the NSU boxes?
t
Edited 1 time(s). Last edit at 10/17/2009 04:44PM by Ted Andkilde.
krisdahl
Kris Dahl
Integra, Civic
October 17, 2009 06:09PM
I was thinking of doing something like the YouTube video, but I'm not sure how they are mounting the reverse sprocket. The differential cover would have to be structural if that is where it is mounting to. Not sure if that is the greatest idea, even if it is just for reversing.
I was leaning towards doing a idler gear on the drive chain, and engaged with a starter solenoid-type setup.
hudson
Andrew McNally
October 17, 2009 07:11PM
I hadn't seen numbers that high, but everything has been 120hp+
> tweaked NSU mill.
http://www.nsu-tt.de/motortuning.html
In the middle of the page you can buy anything from 40 HP up to ~140 HP. Watch the cost of the motors winking smiley
$10,000 moose bucks for a little less than 140 hp. Ok, that's extreme.. but to buy a 100 hp motor already built (not lucking out with someone dumping a hot one that's not smoked) .. is still going to run you 4-5 grand plus shipping winking smiley
I had thought that initially.. like using a stripped nsu box with 1:1 and reverse.. but then thought of that idea.
One other option.. is HONDA GOLDWINGZ.. it`s got an electric reverse.. and it looks like all you would need to do is slap a differential on the back of the damn thing. The newer wingz use the engine as a stressed member.. so that can`t be too difficult.. dimensions would be nice tho.
Andrew M
Onterrible
30ish
open | download - mosas_blower_1.jpg (28.8 KB)
hudson
Andrew McNally
Young love
October 17, 2009 07:27PM
> much of a treat.
> cute ) that you want to have your wife be able to
> it.
hehe.. seriously though.. if I make the car `nice` enough that she want`s to drive it every once in a while and enjoys doing it.. then I would likely meet less resistance in the future winking smiley
Andrew M
Onterrible
30ish
Ted Andkilde
Ted Andkilde
1968 Mini
October 17, 2009 07:45PM
> motors
How about a mildly built NSU mill, 8:1 compression, 270 cam and a $200 eBay Cooper S supercharger running around 7 or 8 psi? roughly 125 hp, 120 ft/lbs for cheap.
t
