Nude Rocker Panels
Posted by PAddy
PAddy
Patrick McVeigh
Student Loans
Re: F%*^ Bodywork!
June 12, 2006 04:57PM
> Are they captive nuts! Can you get to them? One
> of mine is cross threaded and looks like it broke
> free. The bolt hangs out about a cm so I have
> continuously variable castor in the front right
> now, which makes handling, uhh, interesting. Have
> something to look at when I get home. I just said
> fuck it until I got around to worrying about it so
> I could focus on other things.
You can see them in one of the pictures posted above. They're easy to get to...you just need to strip out the tar sheet in the footwell, then use a zipdisc to cut through the floor! Two small rectangular weldnuts held onto the rail by little more than some wishful thinking. I'm planning on welding them on more solidly once I find a brush small enough to sneak in through my hole to clean it up a bit...though compression struts+TCAs would be sexy.
Scott Manley
Scott Manley
XR4Ti
Re: Nude Rocker Panels
June 14, 2006 12:42PM
Grant- It helps if you put a jack under the anti roll bar and lift it into place than put the bolts in. It would be kind of hard to do with studs as they might get in the way. I've found it easier to assemble the control arms to the anti roll bar and then mount the bar to the frame, but you could mount the bar first and use a comealong to pull the bar and get it into the outer TCA bushing.
Scott Manley
Spokane, WA
86' XR4Ti
37
PAddy
Patrick McVeigh
Student Loans
June 18, 2006 04:38PM
You can see them better here, one bolt in, one bolt lost:
PAddy
Patrick McVeigh
Student Loans
June 18, 2006 04:44PM
This photo should make John (and my knees?) happy:
