Nude Rocker Panels
Posted by PAddy
PAddy
Patrick McVeigh
Student Loans
Nude Rocker Panels
April 10, 2006 10:32PM
I actually wanted to make some completely new ones out of .100 wall 4x3 box, but the price of steel these days is still kinda high. So, some new reinforcements to replace my rusted-away pinch seam area...
1/8" riser to deal with the undulations in my floor...
So now the real question, how early can I crank up the grinder on the coming holiday Friday? smiling smiley
Re: Nude Rocker Panels
April 11, 2006 08:31AM
I'd say around 6 am. But then again, I'd work on my car at my house all night long with impacts and flood lights if I didn't have to worry about getting mugged. I guess I could just bring Tank out.
PAddy
Patrick McVeigh
Student Loans
April 11, 2006 09:19AM
Yah, but I'm kinda scared of the German lady next door, so perhaps I'll give her until 10. Beauty of living beside an industrial neighbourhood is there's always noise coming from somewhere...
PAddy
Patrick McVeigh
Student Loans
May 22, 2006 04:07PM
So I got a weekend off from school to spend under the car in the rain. My floor jack decided to shit the bed Friday afternoon, so out came the scissor jack from the 'rents Chrysler to keep things moving.
Before:
Patches in addition to the reinforcing beams:
Beams fixtured in place through the floor with bolts:
PAddy
Patrick McVeigh
Student Loans
May 22, 2006 04:08PM
Up she goes:
Driveway craftsmanship at its' finest:
I've decided the *other* side will be the photogenic one:
Now these look like they'll bear a bit better load then the previous swiss cheese sections:
PAddy
Patrick McVeigh
Student Loans
May 22, 2006 04:13PM
I wanted to fill the cavity with spray foam before bondo-ing the seams shut, but it seems my 2 year old can of the stuff has fused into a solid block inside the can. Maybe next month I can get started on the other side!
Incase anyone was wondering, this is NOT the best way to seal the interior gap after making cossie windows:
The driver's side will just have a big flap bent to fit...20ga is too much of a pain to edge weld togather...
May 22, 2006 06:34PM
Good work Paddy.
Sills suffer on modern cars where they turn under like XRs and everything else!!!!--- Except my old Saab where the doors go all the way down!! and the wheels are inset.
I'll start on the chassi rail mount things as soon as I can stand (it's not getting better....)
PAddy
Patrick McVeigh
Student Loans
May 23, 2006 04:34PM
Just sit while you toil. I'm still trying to find a junk block locally to use for mockup...
hudson
Andrew McNally
May 31, 2006 03:54PM
Looks good paddy.. I'll be heading down that route as well at some point I do believe. I'm still probing.. I don't want to get over zealous and end up with a warped unibody (if it's still straight now).
Andrew M
Onterrible
30ish
PAddy
Patrick McVeigh
Student Loans
Re: F%*^ Bodywork!
June 11, 2006 05:16PM
Man tinwork blows. Whoever decided to have so many damn curvy pieces of sheet on the XR should be taken out to the yard and shot. I think I've finally finished all the work on the passenger side, now to spin my car around in the drive and do everything again(!) on the driver's....then maybe some paint before it snows!
Curiously nice weather as of late:
Upper patch on the 3dr window:
Not putting that cladding back on!
First real time using bondo...
Sanded enough for something under the car:
Finished window opening:
WHY ARE THERE 20+ circular holes in the bottom of my car???
mothra
Matt Smith
xr4ti
Re: F%*^ Bodywork!
June 12, 2006 07:42AM
Better question is why are there an addition 100+ tiny oval openings that were sealed until you striped it.
Matt Smith
PAddy
Patrick McVeigh
Student Loans
Re: F%*^ Bodywork!
June 12, 2006 07:51AM
> striped it.
Zee footwell? Once I reweld the swaybar captive nuts, that gets a nice plate as well...
Re: F%*^ Bodywork!
June 12, 2006 12:03PM
Are they captive nuts! Can you get to them? One of mine is cross threaded and looks like it broke free. The bolt hangs out about a cm so I have continuously variable castor in the front right now, which makes handling, uhh, interesting. Have something to look at when I get home. I just said fuck it until I got around to worrying about it so I could focus on other things.
Scott Manley
Scott Manley
XR4Ti
June 12, 2006 01:36PM
I wonder about putting studs there instead. But it would probably make getting the bar back in place difficult.
Scott Manley
Spokane, WA
86' XR4Ti
37
June 12, 2006 01:59PM
Studs would probably be easier than trying to get the holes aligned and cross threading it. I am seriously contemplating going to compression struts and adjustable TCAs in the front. Some people posted some pics in the Sierra forum on PassionFord when I asked about what people do with regards to the anti-roll bar with these setups though.
