hudson
Andrew McNally
How would you do it? - Steel Fender Flares
October 26, 2009 04:55PM
Ok.. so I'm starting to think through what I actually have to do on the car this winter..
One of the big things, is installing fabulously huge steel flares.
A) I've never done this
cool smiley I've certainly never done it on a structural fendered car.
I will attach some photos...
My thinking has always been.. cut back the original wheel well to the flat horizontal part, cut the fender out to accept the flare... trim the backside of the flare to match the contour of the fender.. tack weld.. make sure the fit is right, lay a couple stitches.. then extend the inner wheel well to the flare.
To recap.. wheel well is attached to flare which is attached the fender..
I suppose the other ways to do this would be to cut the wheel wells and make perfectly horizontal to the fender (no roll in). Cur the flare to match the contour of the fender weld on to the fender. *** will look like crap up close?
With a slight variation of close the void after by extending the wheel well to the flare after you have done the above. *** likely strongest.. if I drill some big massive holes in the fender after then that cavity can vent....
Any thoughts?
Andrew M
Onterrible
30ish
open | download - Fender Off.jpg (87.4 KB)
open | download - front cut fender better.jpg (88.3 KB)
Re: How would you do it? - Steel Fender Flares
October 26, 2009 06:23PM
In the Ford esort rally Preparation book right here somewhere, there is detailed description and drawings on how they did flares onto Escorts.
Or, as they say on Turbobricks "SEARCH, Noob!!
hudson
Andrew McNally
October 26, 2009 06:39PM
> John Vanlandingham
> Sleezattle, WA, USA
> Vive le Prole-le-ralliat
> www.jvab.f4.ca
I looked.. will have to look some more.. I found some scans.
Andrew M
Onterrible
30ish
October 26, 2009 07:28PM
> some scans.
> Andrew McNally
> Hamilton, ON
> 29
Give them books, send them to school and whadda they do?
Never send a boy to do a man's job....
Oh my knees are grey my eyes are bent...
[www.rallyanarchy.com] ..slash.. EscortRallyPrep
(obfuscated to prevent web crawlers from finding it)
There's an HTML version in the html/ directory there.
October 26, 2009 07:37PM
Allright... I'll bite.
~~~nooB WARNING!~~~
Where the fuck are these scans?
I have searched - twice. I have yet to find anything more than a link to another link to a folder hosting 20 pages of said Ford perparation manual. Since then I have heard two references made to this manual that refer to topics and details I did not see int the 20 pages I was able to find.
Where are they?
Thanks
October 26, 2009 07:59PM
http://www.nocoastmotorsports.net/tech.html
Check there. They've been there for over a year now as well. So is the Mazda RX7 one.
hudson
Andrew McNally
Ford Motorsports says option 3! - Thanks Grant!
October 26, 2009 08:34PM
Cheers
Andrew M
Onterrible
30ish
NGTD
Dave Cotie
October 26, 2009 08:59PM
> ~~~nooB WARNING!~~~
> to find.
Daniel, I have them saved on my hard drive, if you can't find them.
DC
> Where are they?
> Thanks
October 26, 2009 09:13PM
where did you find the flares themselves?
hudson
Andrew McNally
October 26, 2009 09:42PM
> "The beatings will continue until moral improves"
Hand made in switzerland is the story, I do konw they're definitely hand made.
If it were at all financially feasable, I would get a bunch punched.
Andrew M
Onterrible
30ish
Ted Andkilde
Ted Andkilde
1968 Mini
October 26, 2009 10:27PM
You could make a mold to do fiberglass copies pretty inexpensively -- though I don't imagine the market for NSU TT parts is strong enough to support much demand in North America...
t
October 27, 2009 12:18AM
They look like they came from spun blanks. I have spun parts made all the time and I can set you up with one for the companies that does it if you want. It's still going to be $1000 for a hardwood tool but miles less than a $15K stamping die.
-Tim
October 27, 2009 03:09PM
Thanks Grant and Dave!
Grant, the download worked.
That is WAY better than what I found before...
October 27, 2009 04:43PM
Grant:
I've got the Vauxhall Sportpart Manual (Chevette) and VW Group A (A2) 16V GTI build manuals if you want to host them.
Wilson
> Grant Hughes
> Denver, CO
mack73
Jason Wine
October 27, 2009 04:58PM
Shoot them to me and I can host them too: mack Seven 30 @ g mail (dot) com
-Jason
