hudson
Andrew McNally
Re: Classing
November 04, 2009 11:42PM
pikespeakgtx Wrote:
> Sounds like you already know the answer to that
> one...
> Michael LeCompte
I never liked that rule.
Andrew M
Onterrible
30ish
Ted Andkilde
Ted Andkilde
1968 Mini
Re: Classing
November 05, 2009 07:19AM
I'm thinking it's kind of academic anyway Andrew, the NSU is more suited to tarmac and hillclimb events which are less picky about drivetrains, and easier on the pocketbook.
You could also call Anders, get a NASA logbook and run everybody else's rallys as long as you don't care about being ineligible for relatively meaningless series points.
t
Francois
Francois Poirier
Open class Laser RS (RIP), 242 GT on the way!
Re: Will I ever sleep again? NSU V8 concept
November 05, 2009 07:22AM
You can always run it in Open class (at least in Canada).
Francois
hudson
Andrew McNally
Re: Classing
November 05, 2009 01:03PM
> t
Well, I will be completely bankrupt for quite some time after I get the car built period winking smiley
On a good note.. I think I've figured out how to mount the engine and transmission in a way that's acceptable & not a billion bucks.
V8 made from I4 motor bikes w/ common flat crank.. then mate that to either a Skyline or a Ford Sierra Cosworth 4x4 tranny.. point the tranny at the front of the car and put the whole assembly as far towards the front as possible then block off the driveshaft out put that's going to the front (hey could make it 4x4 one daywinking smiley and then run a diff to the back which would have been the one going to the front wheels..
As long as that setup can handle 250-300 ponies.. I've got no worries.. and I've seen skyline trannies on the cheap..
Andrew M
Onterrible
30ish
hudson
Andrew McNally
Driveline concept
November 09, 2009 08:52PM
Ok.. so this is my latest driveline concept.
I have no intentions of finishing this project over night btw smiling smiley
I am however interested in comments as to feasability and if anyone see's a better/cheaper way to do it.
Thanks for any and all feedback as always.
Andrew M
Onterrible
30ish
open | download - drivetrain concept.jpg (136.6 KB)
Ted Andkilde
Ted Andkilde
1968 Mini
Re: Driveline concept
November 11, 2009 08:24AM
Hmmn, I think the sequential thingy is a waste of time, it's still an h-pattern synchro box with an additional, fragile, lashed up conversion tacked on, it won't shift any faster but it will break easier.
Possibility of 4wd is cool, but the Skyline box looks huge, ungainly and complex, I'd go mid-engined with a VW box, lot's of parts support, cheap, compact, light, available. Second choice would be a Subaru box, but only if you insist on the silly rear-engined config smiling smiley
t
hudson
Andrew McNally
November 11, 2009 11:56AM
> easier.
I was thinking the sequential thingy was the easiest way to get the shift pattern normal.
Things I like about the skyline box
1) It's nearly as cheap as they get
2) I can mount it in the middle of the car (better weight distribution)
I think if I put the flywheel and clutch at the engine then the whole package will obviously be smaller..
But the input shaft would have a lot more inertia.. don't know if that's a major problem? <--- me being a dumb ass winking smiley
Andrew M
Onterrible
30ish
Edited 1 time(s). Last edit at 11/11/2009 06:04PM by hudson.
Ted Andkilde
Ted Andkilde
1968 Mini
November 11, 2009 10:22PM
You can probably get back to a normal H with a couple of simple pivot changes, even easier if it's a cable shift box.
Trivial for the VW box, it's been used rear-engined, and mid-engined by countless buggy makers and kit car makers nearly as long as your' and my combined ages. It also, with numerous mods, is the basis of the early Hewland boxes -- so there's no shortage of people who know how to make it shift with a proper pattern regardless of mounting position.
How common are they in North America?
How much would it cost to ship one from Japan if you were in a jam?
What does it, the diff and attendant mounting bracketry weigh?
Hmmn, mid-transmissioned, eh?
> smaller..
That thing is calling out for a reduced diameter twin or triple plate clutch, they go cheap on eBay, check out the guys from the Carolinas who flog lightly used Nascrap stuff on flea-bay.
I can't see that as being much of an issue. Are you worried about a flywheel effect from the input shaft? Not really an issue on torque-tube and transaxle cars like the 944, Alfas, Ferraris, etc.
t
November 11, 2009 11:26PM
hudson Wrote:
> john vanlandingham Wrote:
> > Oh oh, smack down!
> > I sense a challenge!
> > Checked the pistons, forged Mahles @ 250
> Euros
> > plus post..
> > I could save you 400 Euros or around 600
> > Americanskij Dollars right there.
> John, when I'm looking for pistons I will keep
> that in mind!
> Are you offering the same kind of old school long
> skirted pistons that don't like to show their
> legs.. Or the high wrist pined leggy kind that
> likes to hang around head
> At any rate, not getting pistons for a bit
> regardless.
> Since you asked
> So, far the biggest thing I overlooked last night
> that's come to mind is that the heads are
> directionally nesting, with one end having a
> larger bearing diameter and the opposite a flange.
> That and the camshaft..
> Andrew M
> Onterrible
> 30ish
Adapt some MC inline aircooled 4 cylinder heads.
November 11, 2009 11:32PM
Corvair diff and trans. You can mount the engine at either end, so your layout can be: engine at rear, bolted to diff, diff bolted to trans, or they sell all the mid engine conversion stuff, so you end up with diff, then trans, then engine. Uses a 4 spd, and the 4 spider diffs can handle small block chevy power.
lots out there, cheap, strong.
hudson
Andrew McNally
November 12, 2009 09:10AM
That has been done... it's really trick.
He took a Suzuki head.. cut it in 3 threw out the middle (the gap for the cam drive) welded it back together and made custom bump sticks!
Andrew M
Onterrible
30ish
November 12, 2009 10:25AM
i vote to keep it NSU, its a rad ride in factory form, i could not cut it up and shoehorn a cocksore into one, never.
hudson
Andrew McNally
November 12, 2009 09:23PM
I hear you.. but I've got two and ones got a rotten floor. Cocksore is a new one to me, not really sure what you're driving at.. but it doesn't sound good winking smiley
Andrew M
Onterrible
30ish
hudson
Andrew McNally
November 12, 2009 09:35PM
> mounting position.
I don't think the skyline one is a cable shift box. I did some searching and didn't turn anything up.
I know the VW boxes are easy and done a lot.. but that's a transaxle and as you see I'm thinking mid mounted transmission with a torque tube winking smiley
> you were in a jam?
> bracketry weigh?
> (better
It weighs ~150 lbs apparently.. and I'm thinking of putting it dead smack in the middle of the car torontojdm.com has 4 or more.. although there are different styles and I'd want one with a removable bell housing
http://www.torontojdm.com/lite/cart.php?target=product&product_id=3418&category_id=78#
Gonna have to check that out.. I know the motorcycle motors run big clutch packs.
> etc.
Yeah I realized this after.. for whatever reason it was making sense the opposite way at the time of the post winking smiley
Andrew M
Onterrible
30ish
hudson
Andrew McNally
The shortened MC headed engine
November 12, 2009 09:39PM
This was pretty trick.. The motor lives not far from here.. and it's cool (in pieces, but still cool) Basically the only stock thing on it is the bottom end case.
Andrew M
Onterrible
30ish
open | download - 5849_1084287470157_1315492114_30216311_1448240_n.jpg (22.4 KB)
open | download - 5849_1084287510158_1315492114_30216312_8366751_n.jpg (24.6 KB)
