SgtRauksauff
Jorden
Re: Mounting Rally Tires
December 01, 2009 12:00PM
Greasecar Wrote:
> My other problem is that I have 6"w x 14" rims and
> the center hold down won't thread on,
Sounds to me like a problem we had with our 30-year oald Coats tire changer growing up. Center-post, with the edges of the rim actually resting on the table? With the cone hold-down that threaded onto the center post?
Worked fine for years and years and years, then when everyone started getting FWD-offset rims, the cone was too high on the center post to screw onto the center post. We used vise-grips for awhile, but it didn't work well, either.
I ended up getting an el-cheapo manual changer, and it's design helped me to fix the old Coats one so my uncle can still use it.
Here's the el-cheapo. The part where the rim rests on is only like a 6" diameter plate, so the mounting point of the wheel sits on it. Helps when airing up a tire too, as when the beads pop in, they don't push against the table and try to launch the tire off of the machine.
The center post has essentially a welded-in huge nut in the top. The hold-down is a 2-piece affair: The 4-legged part that sits in the rim, and the part that screws into the center post.
For the part that screws in, there's essentially a threaded rod in the center of the pipe, that spins into the nut in the center post.
I took an old scissor-jack, for the nut and threaded rod part, and a chunk of pipe, and made a hold-down like that for the old coats machine, and now my uncle can keep using it.
Maybe you can modify your center-post with a similar thing, to get the hold-down to work right? That is, if my ASSumptions are correct about the style of changer you've got.
--sarge
Jorden R. Kleier
Baraboo, Wisconsin, USA
1990 Mazdog Protege 4WD
1973
December 01, 2009 12:59PM
> BIG HAMMER!!
> LOTSA LUBE!
That's what she said.
walmart mounts tires for $5? didn't know that....
December 01, 2009 08:11PM
Jon Burke Wrote:
> john vanlandingham Wrote:
> > BIG HAMMER!!
> > LOTSA LUBE!
> that....
> Jon Burke - KI6LSW
> Blog:
> 'Holy Shit!' @ 4:10
Neither did I. We were in a rush to mount some gravels when tall pines decided it wanted to be a gravel event. Only place that could take us was wall mart and when I said wheels are off the car/need no balancing the old guy behind the counter said "I guess I can only charge you $5 for UNMOUNTING AND MOUNTING! I checked the service bay to make sure some 8 year old chinese kid wasn't doing them. Seriously I felt bad for the guys.
December 01, 2009 11:43PM
It'll take some practice but it's pretty easy.
With even a cheapo knock off tire machine. MY GIRLFRIEND and both mounted and dismounted the gravel tires on my car! and before you get smart, she's 5 foot 3, and tiny like a mouse. She's done Yokohama's, Michelins, and Hankooks...no problemo.
