2001 Hyundai Accent with '03 Elantra
Posted by brianallmotor
Brian
Brian Ferus
none
Re: 2001 Hyundai Accent with '03 Elantra
November 25, 2009 09:08PM
I now have a 2004 Elantra and they both have the quirk of not always getting fully into 2cd gear, when clutch is released it'll pop out. Never was able to determine if it was gear box or shifter. On the Accent shifter I moved the pivot point 1/2" replaced the plastic bushings with oilite bronze and the weenie plastic rod ends for the cables withe teflon lined rod ends. The fell was much improved but it would still pop out of gear at seemingly random times.
Brian
brianallmotor
Brian R. Barton
Mazda 323 BP-T
November 25, 2009 10:45PM
need any parts for the 2004 Elantra?? i'm parting out the 2003 Elantra for uber cheap.
brianallmotor
Brian R. Barton
Mazda 323 BP-T
November 25, 2009 10:46PM
ok, thank you. very nice engine btw.
November 26, 2009 08:44AM
Pull that trans off and fix the throwout bearing, might be good idea.
They made it out of plastic and the input snout it rides on is aluminum. The aluminum corrodes, the plastic isn't beefy enough to clean it as it slides past, eventually it stays applied, overheats, melts, and everything comes apart.
The kicker - the snout dealy (name?) is part of the transmission casting, not a replacable part.
We've been seeing a lot of this happening, mainly on Accents, probably because those are the ones that get more manual transmissions. It's an odd import where the automatic is better than the manual!
Edited 1 time(s). Last edit at 11/26/2009 08:45AM by Pete.
Brian
Brian Ferus
none
November 26, 2009 09:10AM
No thanks, My has to use it at times to goto work and said not to touch it!
Brian
November 26, 2009 09:24AM
> Brian
Brian
brianallmotor
Brian R. Barton
Mazda 323 BP-T
November 26, 2009 10:34PM
added to my list. thanks dude. yeah, i'm installing a new timing belt and new pulleys and tensioner, and doing the coolant into the throttle body delete as well. i will have to take some more pictures tomorrow, the car is almost completely stripped. another 4 hours of work to rip off the suspension and it'll be done.
-Brian
brianallmotor
Brian R. Barton
Mazda 323 BP-T
Re: 2003 Hyundai Accent with '03 Elantra
November 27, 2009 09:11PM
the 2001 accent was a shady deal. found on craigslist and the convinced a guy in Mass to sell his car for $600... this one is a 2003 model: 91,000 miles, 5 speed, A/C, recent timing belt, alternator, plugs, wires, 4 snow tires!!! picking it up on sunday.
November 28, 2009 05:03AM
I've kinda wondered about those, how do they handle?
November 28, 2009 10:35AM
Basically they are like any lowline Asian car, lots of room for improvement. Stock the tires are too small and supension too wobbly, The bigger cars handle better. None have a sport suspension from the factory but it is a basic strut and I'm sure it can be easily improved.
November 28, 2009 10:57AM
Is this a RALLY project?
Ted Andkilde
Ted Andkilde
1968 Mini
November 28, 2009 02:09PM
I've seen pics of a, same gen as yours, Accent with a 4wd/4G63 conversion, for a budget mini-Evo, minus 1000 lbs or so.
I imagine it would go like a rocket.
t
November 28, 2009 02:49PM
Oh, thats kind of sad. They're really cheap and newer then my corolla, and look halfway decent, I think. They're (were?) on the list of potential next cars for me, haha
November 28, 2009 08:17PM
> Feisty Peacock?
They're great budget cars. I recommend then to most of my customers. You however should maybe look more at a Toyota Echo...
brianallmotor
Brian R. Barton
Mazda 323 BP-T
November 28, 2009 11:06PM
why would you recommend the Echo versus the Accent?? curious....
