Skid plate install
Posted by phlat65
Skid plate install
November 30, 2009 08:37PM
Posted these on the Merkur forum, figured I would post them here.
Front mount is .125 wall 1.5inch square tube, the verticals are welded to a plate, that is welded to the bottom of the frame rails, and the sides of the verticals have weld nuts in them, and are bolted to the JVAB tow hook/ Jack point/ skid plate mount ting, that is thick alloy plate. The plate is bolted to the frame rail in 3 spots.
the rear skid plate mounts. I made an extension that comes down Vertically from the frame rail, welded a plate to the rail, welded the extension to the plate, capped the open end with a 10x1.5 weld nut on the backside of the plate. That is the black piece (hard to see)
The white horizontal part, bolts to the back of the crossmember, and bolts to the vertical. It has a 10x1.5 weld nut in it for the skidplate.
The skid plate is a Kevlar one that came off of an evo8. it was cracked in the front from a tree impact. I cut out all of the damage, I did not need that part anyway. Trimmed off the vertical side pieces. it is secured with 4 bolts, all 4 are recessed about an inch. It is burly
And my $80 light bar
Re: Skid plate install
December 01, 2009 10:00AM
Sean,
You are one productive mofo!
eyesoreracing
Dave Coleman
Mazda3, SE-R Spec-V, 510
December 01, 2009 10:27AM
See, something good does come from all these EVOs and WRXs. Cheap leftover parts!
December 01, 2009 10:30AM
If only the silly boys driving them would use tires appropriate to their degree of driving like 15/65 x 15 or 16/64 in stead of the hugest fattest HEAVIEST thing they can find, then there'd be more nice tires for use guys...
December 01, 2009 11:09AM
phlat65 Wrote:
...Trimmed off the vertical side pieces. it is secured with 4 bolts, all 4 are
You do realize that the vertical side pieces add a whole bunch of torsional rigidity to the skid plate don't you? Particularly if it is unsupported between the front and rear mounts I think you'll be disappointed in its performance if you ever put it to the test.
You'll also want to try and seal your cuts with resin - Kevlar is hugely absorbent and the skidplate will destroy itself in no time if it isn't sealed. The mounting points will be vital. (the kevlar will expand and contract with damp/dry and the resin will come apart making the area weak.)
(and before anyone writes this off as the ramblings of just a photographer - I have a lot of experience with light weight composites from my r/c glider hobby.)
December 01, 2009 02:20PM
it is supported in 2 other places between the mount holes. Im know the side pieces added rigidity, they just would not fit in my car.
BTW, found out that skid plate was $3500.00 new. hows that for overkill....
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
How thick are the JVAB tow hook support things?
December 01, 2009 03:31PM
The sumpguard front support/jacking point/tow points are 3/8" thick.
eyesoreracing
Dave Coleman
December 01, 2009 04:45PM
Shit, that's more than my whole rally car!
How much was it used?
-Dave
December 01, 2009 05:31PM
Free...
December 01, 2009 05:48PM
Yeah, GOOD composite materials are not cheap. Especially when you get into aerospace grade prepreg stuff. Composites Engineering I would think is pretty lucrative, as well.
eyesoreracing
Dave Coleman
December 01, 2009 06:38PM
phlat65 Wrote:
> Free...
I love being on the right side of depreciation!
December 01, 2009 08:05PM
$3500 that's silly. Kevlar is cheap (all things being relative. It IS way more than Aluminum) I could make that skid plate for $500 AND make a profit. You should find a local source for Kevlar and GOOD resin. You can sand/grind it down and lay on a couple more layers when it gets even more chewed up than it is.
December 01, 2009 08:39PM
> "this is certainly not a game for flyweights or
> ping-pong players-all arguments to the contrary"
> -C.B.
design, material, tooling, vacuum bagging, possibly autoclave
it all adds up.
December 01, 2009 11:08PM
Dazed_Driver Wrote:
> things
> I
> a
> Kevlar
> and lay
> more
> or
> contrary"
> > -C.B.
> possibly autoclave
> it all adds up.
> Feisty Peacock?
Since I already have all that, it's already added up and paid for. You think that skid plate is autoclaved? Really? You don't have to vacum bag it to add a couple of "wear" layers either.
