Posted these on the Merkur forum, figured I would post them here.
Front mount is .125 wall 1.5inch square tube, the verticals are welded to a plate, that is welded to the bottom of the frame rails, and the sides of the verticals have weld nuts in them, and are bolted to the JVAB tow hook/ Jack point/ skid plate mount ting, that is thick alloy plate. The plate is bolted to the frame rail in 3 spots. ![]() ![]() the rear skid plate mounts. I made an extension that comes down Vertically from the frame rail, welded a plate to the rail, welded the extension to the plate, capped the open end with a 10x1.5 weld nut on the backside of the plate. That is the black piece (hard to see) The white horizontal part, bolts to the back of the crossmember, and bolts to the vertical. It has a 10x1.5 weld nut in it for the skidplate. ![]() ![]() The skid plate is a Kevlar one that came off of an evo8. it was cracked in the front from a tree impact. I cut out all of the damage, I did not need that part anyway. Trimmed off the vertical side pieces. it is secured with 4 bolts, all 4 are recessed about an inch. It is burly ![]() ![]() And my $80 light bar ![]() ![]() |
eyesoreracing Dave Coleman Godlike Moderator Location: Long Beach, CA Join Date: 05/13/2007 Age: Possibly Wise Posts: 448 Rally Car: Mazda3, SE-R Spec-V, 510 |
eyesoreracing Wrote:
------------------------------------------------------- > See, something good does come from all these EVOs > and WRXs. Cheap leftover parts! If only the silly boys driving them would use tires appropriate to their degree of driving like 15/65 x 15 or 16/64 in stead of the hugest fattest HEAVIEST thing they can find, then there'd be more nice tires for use guys... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Morison Banned Mod Moderator Location: Calgary, AB Join Date: 03/27/2009 Age: Ancient Posts: 1,798 Rally Car: (ex)86 RX-7(built), (ex)2.5RS (bought) |
phlat65 Wrote:
------------------------------------------------------- ...Trimmed off the vertical side pieces. it is secured with 4 bolts, all 4 are > recessed about an inch. It is burly You do realize that the vertical side pieces add a whole bunch of torsional rigidity to the skid plate don't you? Particularly if it is unsupported between the front and rear mounts I think you'll be disappointed in its performance if you ever put it to the test. You'll also want to try and seal your cuts with resin - Kevlar is hugely absorbent and the skidplate will destroy itself in no time if it isn't sealed. The mounting points will be vital. (the kevlar will expand and contract with damp/dry and the resin will come apart making the area weak.) (and before anyone writes this off as the ramblings of just a photographer - I have a lot of experience with light weight composites from my r/c glider hobby.) First Rally: 2001 Driver (7), Co-Driver (44) Drivers (16) Clerk (10), Official (7), Volunteer (4) Cars Built (1), Engines Built (0) Cages Built (0) Last Updated, January 4, 2015 ![]()
Andrew_Frick Wrote:
------------------------------------------------------- > How thick are the JVAB tow hook support things? > > The sumpguard front support/jacking point/tow points are 3/8" thick. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
phlat65 Wrote:
------------------------------------------------------- > it is supported in 2 other places between the > mount holes. Im know the side pieces added > rigidity, they just would not fit in my car. > > BTW, found out that skid plate was $3500.00 new. > hows that for overkill.... Shit, that's more than my whole rally car! How much was it used? -Dave |
Dazed_Driver Banned Ultra Moderator Location: John and Skyes Magic Love liar Join Date: 08/24/2007 Posts: 2,154 |
phlat65 Wrote:
------------------------------------------------------- > it is supported in 2 other places between the > mount holes. Im know the side pieces added > rigidity, they just would not fit in my car. > > BTW, found out that skid plate was $3500.00 new. > hows that for overkill.... Yeah, GOOD composite materials are not cheap. Especially when you get into aerospace grade prepreg stuff. Composites Engineering I would think is pretty lucrative, as well. Welcome to the cult of JVL drink the koolaid or be banned. |
david amor david amor Elite Moderator Location: Stoney Creek Ontario Join Date: 03/22/2006 Age: Possibly Wise Posts: 458 |
$3500 that's silly. Kevlar is cheap (all things being relative. It IS way more than Aluminum) I could make that skid plate for $500 AND make a profit. You should find a local source for Kevlar and GOOD resin. You can sand/grind it down and lay on a couple more layers when it gets even more chewed up than it is.
Gone fishing |
david amor Wrote:
------------------------------------------------------- > $3500 that's silly. Kevlar is cheap (all things > being relative. It IS way more than Aluminum) I > could make that skid plate for $500 AND make a > profit. You should find a local source for Kevlar > and GOOD resin. You can sand/grind it down and lay > on a couple more layers when it gets even more > chewed up than it is. > > "this is certainly not a game for flyweights or > ping-pong players-all arguments to the contrary" > -C.B. design, material, tooling, vacuum bagging, possibly autoclave it all adds up. Welcome to the cult of JVL drink the koolaid or be banned. |
Dazed_Driver Wrote:
------------------------------------------------------- > david amor Wrote: > -------------------------------------------------- > ----- > > $3500 that's silly. Kevlar is cheap (all > things > > being relative. It IS way more than Aluminum) > I > > could make that skid plate for $500 AND make > a > > profit. You should find a local source for > Kevlar > > and GOOD resin. You can sand/grind it down > and lay > > on a couple more layers when it gets even > more > > chewed up than it is. > > > > "this is certainly not a game for flyweights > or > > ping-pong players-all arguments to the > contrary" > > -C.B. > > > design, material, tooling, vacuum bagging, > possibly autoclave > > it all adds up. > > Feisty Peacock? > > Since I already have all that, it's already added up and paid for. You think that skid plate is autoclaved? Really? You don't have to vacum bag it to add a couple of "wear" layers either. Gone fishing |
