hudson
Andrew McNally
4 Banger Mopar Power Options?
December 01, 2009 05:20PM
You guys seem to be an encyclopedia on engines..
What, in your opinions would be a good, cheap, LIGHT, some how related to Mopar powerplant?
Do all Mitsu motors count, or did they have to actually be in a Mopar branded product?
Cheers,
Andrew
Andrew M
Onterrible
30ish
jamesp
james phillips
Volvo 242 GT (in progress)
Re: 4 Banger Mopar Power Options?
December 01, 2009 05:38PM
You didn't say whether or not there's a displacement limit, but you can make pretty good power from the DOHC 2.0L mill in the 1GN Neon (also used in other cars: avenger, etc...), also the DOHC 2.4L motor from the PT Cruiser, which is a popular Neon swap.
If you want to go crazy, the 2.4L turbo'd lump from the SRT-4 or PTGT is available.
james phillips
Volvo 242 GT (being built...)
Scooby killing 04 Dodge Neon SRT Rallycross monster
Lincoln, NE
hudson
Andrew McNally
December 01, 2009 06:12PM
Thanks, and good point winking smiley The motor I'm replacing is shy of 1000cc.. 998 I think. All of those are plenty big enough.. won't be competing for quite some time.. so not overly concerned about displacement limits of any kind.
I care most about minimizing weight (it will be in the trunk) and cost winking smiley (I'm a poor ass).. Is/was there any alloy beauties that fell under the mopar tree?
Cheers,
Andrew
Andrew M
Onterrible
30ish
hudson
Andrew McNally
Anyone know about these Gema (Mitsu-Hyu-Chr) motors?
December 01, 2009 07:17PM
What's the good word on these?
They look like they're light at least
Andrew M
Onterrible
30ish
impfected
Alan Petersen
maybe a Hillman Imp
December 01, 2009 07:43PM
Strangely enough, I'm looking for the same thing. A modern Chrysler derived motor that is light and larger/more reliable/cheaper than my 998...
Although, I was leaning towards Peugeot as Chrysler Europe sold off it's stuff to them in the late 70's. Maybe a stretch...
jamesp
james phillips
December 01, 2009 07:53PM
all of these are iron block/aluminum head combos.
james phillips
Lincoln, NE
jamesp
james phillips
December 01, 2009 07:58PM
Now you got me curious smiling smiley
This http://en.wikipedia.org/wiki/Tritec_engine might be what you are looking for. The 1.6L was used in export PT Cruisers and Neons and looks to be an all aluminum combo.
james phillips
Lincoln, NE
hudson
Andrew McNally
December 01, 2009 08:03PM
> This might be what you are looking for. The 1.6L
> james phillips
> 98 Dodge Neon (Gp2 car in progress)
> 04 Dodge Neon SRT (ready for Rallycross NATS!)
> Lincoln, NE
I'm pretty sure the GEMA motors are all alloy as well..
Andrew M
Onterrible
30ish
hudson
Andrew McNally
Andrew M
Onterrible
30ish
hudson
Andrew McNally
December 01, 2009 08:19PM
What will work for you will work for me. I'm not putting it in an IMP tho.. but same diff.
So farthe best bets looks like a GEMA (http://www.allpar.com/mopar/world-engine.html) or the Bini motor that JamesP mentioned.
The biggest problem I see with the GEMA motors is that it's all teh same block from 1.8 - 2.4 just different stroke and thicker sleeves (weight)..
Not sure if you want 2.4l in the back of your imp.. or do you?
Andrew M
Onterrible
30ish
hudson
Andrew McNally
Bini motor
December 01, 2009 10:42PM
Not finding too much good being said about the Bini motor.. not sure how much of that is because it's a chrysler design and not a BMW design..
Also not finding much information.. I'm pretty sure one source was talking about it being a cast iron block
Andrew M
Onterrible
30ish
December 02, 2009 07:40AM
Chrysler used the Peugeot/Simca 1.6 liter in Omnis and Horizons in the '80s. Ironically enough, at the end of the run the models that used that motor were called the Omni America and Horizon America. Don't know is that engine is iron or aluminum block or light or worth a crap or anything but might be something to look into.
hudson
Andrew McNally
Bini is cast iron blocked
December 02, 2009 09:28AM
Opening the MINI lineup are the MINI One and MINI Cooper, both powered by the four-cylinder, 1.6-L Pentagon gasoline engine that was developed jointly by BMW and DaimlerChrysler and is built in South America. For the MINI One, it develops 66 kW (89 hp), and for the Cooper, 85 kW (114 hp). A supercharged version for the MINI Cooper S will be available for MY2002 producing 122 kW (164 hp). The transversely mounted 16-valve engine driving the front wheels meets EU4 emissions legislation but does so without the necessity of secondary air injection or exhaust recirculation. The engine block is cast iron, but the cylinder head is aluminum. The MINI is an international car designed to be sold into many markets, and its engine's anti-knock capability will allow it to run on lead-free gasoline with a RON span of 91 to 98. The engine features an electronic throttle, and a Siemens EMS 2000 electronic powertrain controller manages the engine and continuously variable transmission (CVT),
Andrew M
Onterrible
30ish
hudson
Andrew McNally
Imped - the other angle is Peugeot and hence the new Bini motor
December 02, 2009 09:42AM
Rootes -> Talbot -> Peugeot
Does that not work? (I don't make the rules)
Andrew M
Onterrible
30ish
hudson
Andrew McNally
Re: Imped - the other angle is Peugeot and hence the new Bini motor
December 02, 2009 10:48AM
http://www.psa-peugeot-citroen.com/document/presse_dossier/PK_PSA_BMW1103281940.pdf
Pretty interesting motor.. Direct injection, aluminum 2 piece block, a bunch of other gadgets..
Of course, can't find any weights for it.
Andrew M
Onterrible
30ish
